starting almost from scratch
jason udall | 27/08/2013 12:55:34 |
2032 forum posts 41 photos | Ok so I have been given the incomplete works of a french clock. Vallet suspention Count wheel Half and hour chime Bell rather than gong .has been wd40'd or simular...eek! No case. No pendulum. ..ok I have degreased all wheels etc. Now will tick... too fast but not violently so.. Q1.lube? .. All drive train pivots 1in3..just for now..left escape ment dry at mo. Q2 without case can't even guess on pendulum weight/length...?.. |
NJH | 27/08/2013 13:34:56 |
![]() 2314 forum posts 139 photos | Hi Jason Clock oil see HERE ( Meadows and Passmore) - not cheap but pretty much anything you need for clock work. ( the bottle will last you for the rest of your life!) When you apply the oil use VERY little, put just a drop ( from the end of a cocktail stick maybe) into the hole where the wheel arbours run in the plates. DO NOT apply to the wheels themselves. Regards Norman |
David Jupp | 27/08/2013 13:39:07 |
978 forum posts 26 photos | Any simple pendulum has a period of T = 2 π SQRT(l/g) where l is pendulum length and g is acceleration due to gravity. Weight doesn't directly influence the period. BTW The character after the 2 was Pi when it was input - doesn't seem to display well after submission. Edited By David Jupp on 27/08/2013 13:40:31 Edited By David Jupp on 27/08/2013 13:40:56 |
jason udall | 27/08/2013 14:39:14 |
2032 forum posts 41 photos | Thanks guys.. As to oil..yes certainly intend to order some..but for one clock seems extravagant. .and yes minimun to "fill" the oil sink..mostly using 1:3 as protection until other oil.... Pendulum length. .thanks I first need to establish period required...was looking for inspiration .. As to bob mass (weight) well I guess as?long as bob dominates rod ..otherwise things become more complex |
JasonB | 27/08/2013 14:46:07 |
![]() 25215 forum posts 3105 photos 1 articles | Don't tell me about pendulum length earlier this year I made a clock and matching hall table for a client and spent the best part of £1000 on a kieninger movement and could not get it to keep time it was always running slow no matter how I tried the adjuster on the pendulum. Eventually after lots of e-mails and me asking for a replacement the supplier realised they had sent the wrong length suspension rod so it was always going to be about 3" too long. |
Russell Eberhardt | 27/08/2013 15:18:55 |
![]() 2785 forum posts 87 photos | Hi Jason, Oil, as Norman says, use proper clock oil from M & P. Don't fill the the "oil sink". Just introduce enough to fill the minute radial gap between the pivot and the plate. A drop on the end of a small needle is enough. The oil sink is just an aid to getting the oil into the pivot. Pendulum mass; the more the better. The pendulum Q factor is directly proportional to the mass of the bob. The higher the Q the less the period is affected by variations in friction and driving force. Of course you have to take account of the strength of the suspension. Probably best to make something that just looks right for the length. As has been said don't oil the wheels, they should be completely dry, the only exception being a tiny amount of oil on the escapement pallets which of course is transfered to the tips of the escape wheel. Russell. |
jason udall | 27/08/2013 16:03:25 |
2032 forum posts 41 photos | Again thanks guys.. ....without the original case what "looks" right is the whole problem.. The crutch is about 50 mm and I would hope the pendulum length to be at least double that. .guess I need to guess the impulse train and derive the desired period from that... learnt much from this project already. ..not least the calibre of work done by the mass producers of this piece....I belive it is an ebauch (?) Clock thus the parts were mass produced and assembled by various local clock makers. .the latter work is of a different grade. .but I am still impressed with the finish in non critical elements for what I would have expected to be made with hand tools ...in what was in effect piece work ... |
Russell Eberhardt | 27/08/2013 17:05:20 |
![]() 2785 forum posts 87 photos | Posted by jason udall on 27/08/2013 16:03:25:
guess I need to guess the impulse train and derive the desired period from that... learnt much from this project already. No need to guess, multiply the number of teeth on the third wheel pinion by the number on the escape wheel pinion and by 3600 then divide by the numbers of teeth on the centre (hour) wheel, on the third wheel, and on the escape wheel. That will give you the full period for the pendulum. Russell. |
RJW | 27/08/2013 17:52:44 |
343 forum posts 36 photos | Jason, on the back plate there will be a couple of numbers stamped, find those and input them on the link below which is Meadows and Passmore's site, it's an on-line calculator which will give you the correct length according to the numbers on Your movement, saves fannying around doing calculations! If you have just dunked the movement in degreaser without stripping it, you will not have got rid of the WD40, nor the muck and grit you will have successfully washed into the pivot holes in the process! As previously said, no lube on any wheels, a small spot on each oil sink, not forgetting the single cock on the motionwork intermediate wheel! I've just ruined a batch of Horolene cleaning out a Comtoise wall clock which had been liberally sprayed with WD40, and I'd previously cleaned every single part by hand soaking and brushing with acetone, even then I had to final clean every component with lighter fuel to totally rid them of the vile stuff! I have several cases here that would house a similar orphaned movement, but a good conversion for you would be to turn it into a 'Skeleton Clock', in which the movement is mounted on pillars or into a brass frame of your design, loads you can do with it! John. |
RJW | 27/08/2013 17:59:30 |
343 forum posts 36 photos | BTW, I also have a box full of pendulum bobs for those movements, they are invariably heavy brass units if you've never seen one, but the main variant to this is a decorative grid iron type used on Napoleon III Portico or Empire clocks, they use the same style movement, but the gearing is slightly different as the rod is much longer and why the numbers on the backplate are important! Also take a good look on the backplate for any stampings, if there is one (usually a circular or oval stamp) it will be the maker's mark and you'll need a loupe to read it! I may have a few rods kicking around too, I'll dig them out later and see what types there are! I'd also recommend Not using cocktail sticks anywhere near a clock movement, the wood contains acids that are detrimental to longevity, use boxwood (pegwood) sharpened to a point for pegging out pivot holes, and if you don't have a set of clock oilers, a steel needle or bit of small diamter blued pivot steel with a small flat on its tip for placing oil in the sinks, needless to say it should be spotlessly clean, also keep any oil pots covered when not in use as it will soak up dust like a magnet! John.
Edited By RJW on 27/08/2013 18:15:33 |
jason udall | 27/08/2013 19:24:59 |
2032 forum posts 41 photos | Re pendulum length..so the cunning guys write the pendulum length on the clock...how very sensible. .I continue to be impressed by these guys.. Stamp says 4.6..this leads to 112..brilliant! The suspension is ( from my reading)..vallet..again the internals are beautifully milled. .the input wheel is over meshing in the suspension adjuster wheel..thinking about remaking that.. thinking thats is .. As to strip down...yeah..was afraid of that. .will try ultrasonic cleaner first repeat until bath runs clear. ..(does not leave residue on micro scope slide ) keeping spring barrels out of solution ....really afraid of taking it apart that far ( wuss.).. . Edited By jason udall on 27/08/2013 19:27:36 Edited By jason udall on 27/08/2013 19:28:52 |
jason udall | 27/08/2013 20:31:20 |
2032 forum posts 41 photos | Ok. "Makers" stamp Found on works side of front plate. .near the stamped 1212. . in a 7 mm dia circle "G:B" or possibly"B:B" or "8:8" ..doubt not my eyes but the stamp a bit blurry not crisp .. " |
roy entwistle | 27/08/2013 20:32:58 |
1716 forum posts | The age of that movement it will probably need new springs anyway DON'T try to remove or replace them without a spring winder Roy |
Stub Mandrel | 27/08/2013 20:40:10 |
![]() 4318 forum posts 291 photos 1 articles | Prrops used to sell clock and watch oil in tiny containers for very few bucks. Neil |
RJW | 27/08/2013 21:00:48 |
343 forum posts 36 photos | Those French drum movements are about as good as it gets for any clock movement, the quality of manufacture and finish is consistently superb across the entire range whether countwheel (yours), rack striking or timepiece, and whether unsigned or bearing trademarks of Japy, Marc or Marti! Can't argue about the 'Vallet' suspension, never bothered to research them, I only fix them when they've been inconsiderately abused (butchered), but the adjustment device is by Brocot, which is what I generally refer to them as, you'll probably find the name stamped into the gear wheel! Hmmmmmm, Please forget an unstripped cleaning Jason, it's a shit way of cleaning a clock to be frank and what cheapskate dealers do to get one up and running sufficient to get rid of what was a non runner, even leaving the barrels out of the solution! No matter how well you clean it, even in an ultrasonic, you will also Not get crap out of the mainspring leaves or the barrels if you do dunk them, or get the congealed oil out of the holes, and as sure as God made little apples, you'll end up with a slurry gathered in whichever part of the barrel is lowest when sitting in the tank! Use it as a learning experience, they're not that bad to do unless you're into serious re-bushing where the top pivots are getting on for pocket watch sizes when it all gets a bit tedious, but if you just strip it to clean and inspect and forget repairs at this stage, they're quite nice to work on! Nothing to be afraid of, just make sure you let the mainsprings down first before stripping it otherwise you'll be nursing Very warm and tingly fingers for a while John |
NJH | 27/08/2013 21:15:03 |
M & P oil at less than £4 for a supply that will last the occasional clockmaker a lifetime is hardly a problem surely? This is the pukka stuff after all. For John, who presumably does a lot of clockwork, then a "homebrew" is probably the best course. BTW John I'm a bit surprised about the cocktail sticks containing acid - luckily I don't drink cocktails ( or much else) these days! . As you suggest , when I've occasionally worked on clocks, I've used pegwood but I thought that might be an unfamiliar term to Jason. Jason - I afraid the way to make a job of the cleaning IS to take it apart. If you are unsure why not visit a car boot sale, junk shop or such like, seek out a cheap clock, and practice. You'll probably find it much easier than you fear. Do heed Roy's warning about springs though. Norman
RJW | 27/08/2013 21:15:50 |
343 forum posts 36 photos | I appreciate the concern some have about spring removal, and in some circumstance it's advice to be well heeded, but spring removal on these is a piece of cake, no winder needed and frankly, overkill for a 'one off' job, just gently pull the spring out from the centre and when it releases (you'll feel it want to go), keep the spring cupped in your hand (use a glove or thick rag if need be) and let it gently unwind, keep a good grip on the barrel though otherwise it will do a zebedee across the room from the recoil, there's not really that much power in them unless you try flicking the click of the rathet pawl when fully wound!! John Edited By RJW on 27/08/2013 21:19:55 |
speelwerk | 27/08/2013 21:34:44 |
464 forum posts 2 photos | If you take it apart do check if the barrels are marked for which train they are, they look very much the same but should go back at there original place. Springs from these movements are not a great problem if you know what you are doing, the weakest spring is usuall for striking. I cannot remember ever using a special springwinder, normaly they are of no use for the springs I work with. The largest I remember was from Kalliope musical box with a length of 10meter, heigth 60mm and thick 1.10mm. Even this you can do by hand, it makes it more interesting, but using a lathe is safer. Niko. |
RJW | 27/08/2013 22:48:43 |
343 forum posts 36 photos | Norman, I don't think the acid content in a cocktail stick would do much damage to you, but if pushed into a brass pivot hole, there could be some sap residue left behind which could damage the brass and hence steel, especially if oak, they're not designed or manufactured for pegging out clock plates under pressure anyway, and impurities would most likely be depositied! Niko makes a very good point about marking barrels, and something I do regardless! For anyone recoiling in horror about yanking out a spring on Jason's clock and to help put things into perspective, they are almost invariably approx 80mm diameter on the plates, and both maninspring barrels approx 32mm diameter externally, they're pussys compared to most springers! John |
jason udall | 27/08/2013 23:29:33 |
2032 forum posts 41 photos | welll, as a child(7-10 ish)..I took apart gramophone motors..even got a few back together,,Once..ONCE.. opened a broken spring drum...enough residual rage to put me off until now...those drums are 3-4 "dia. and 2-3 " wide...much springness. ... so it looks lke nothing for it...shame clock strikes and fast ticks(no pendulum ) fine.. letts see if I can at least make it no worse. btw this is what I have.come to understand as vallet suspention Edited By jason udall on 27/08/2013 23:35:21 |
