John Hinkley | 18/07/2013 14:03:15 |
![]() 1545 forum posts 484 photos | First, let me say that it's my own fault that I find myself in this position! I have just received an electronic edge-finder from our friends in the orient and am keen to try it out. Unfortunately, by not appreciating its dimensions from the (clearly-stated) sales blurb, I find myself with a 20mm diameter tool to fit into my mill spindle. I habitually use an ER25 collet chuck to hold my cutters and drills, consequently the maximum size of collet is 16mm! Can anybody suggest an alternative means of temporarily holding the thing? I guess l'll end up buying an ER32 chuck and collet(s), but in the meantime I want to play with it! John |
Trevorh | 18/07/2013 14:24:32 |
![]() 316 forum posts 89 photos | why not make a simple reducing adaptor one end at 16mm to go into your collet and the other say 25 with a hole at 20 in the end and use a grubscrew to secure/hold it similar to a step down Morse taper adaptor |
Robbo | 18/07/2013 14:46:42 |
1504 forum posts 142 photos | Or you can buy a straight shank ER32 collet chuck from here **LINK** and then buy a collet to suit. From the same place. Have used them a few times with no problem. Edited By Robbo on 18/07/2013 14:47:42 |
Martin W | 18/07/2013 15:01:53 |
940 forum posts 30 photos | Robbo
How is John going to mount the plain shank of the collet holder as it is also 20mm dia which is the same as the edge finder shank? Cheers Martin PS John
If this is the same as the other electronic edge finders I have seen then the assembly is rigid, unlike the rotating mechanical ones which are spring centred, and if wound in after initial contact can be strained. Just something that is worth being aware of. Have fun with your new toy Edited By Martin W on 18/07/2013 15:16:47 |
John Hinkley | 18/07/2013 15:34:43 |
![]() 1545 forum posts 484 photos | Thanks for replies, chaps. Trevorh - a reducing sleeve might just work, except that there is restricted throat distance on my mill which could "reduce" its usefulness. The edge-finder is a pretty meaty bit of kit as it is! Robbo - I, too have used these suppliers on a number of occasions. In fact the collet set that I use all the time came from there. I feel another vist to their web site coming on! Martin W - You are quite right, of course and it would just exacerbate the lack of throat distance. I also have one of the spring-loaded edge-finders. Works OK but I like gadgets! Problem solved, I think - I'll order a chuck and collets from CTC tonight! John
JasonB | 18/07/2013 17:10:17 |
![]() 25215 forum posts 3105 photos 1 articles | What taper do you have in the spindle? you can get MT3x20mm collets and no excess length issues I found a 1/2" shank electronic finder which easily fits my ER, MT or even the drill chuck |
Phil P | 18/07/2013 17:21:51 |
851 forum posts 206 photos | Jason Where did you get your 1/2" version from, I have been wondering about getting one of those for a while, but my High Speed head collets only go up to 1/2" so I have the same problem. Phil |
Gone Away | 18/07/2013 18:28:10 |
829 forum posts 1 photos |
Posted by Martin W on 18/07/2013 15:01:53:
If this is the same as the other electronic edge finders I have seen then the assembly is rigid, Most of the 20mm dia EEF's that I've seen on eBay from China are the "ball in cup" type: the cup gives location to the ball and it's held in by a spring. If you feed in to an edge and go too far (i.e. clobber it) the ball just lifts and no damage is done. I have one of these (and I use ER32 collets). I also have a 1/2" one that is solid and you do have to be careful with those (I'm on my second at the moment). |
Robbo | 18/07/2013 18:31:49 |
1504 forum posts 142 photos | Martin, I blame the heat - getting my diams mixed up |
JasonB | 18/07/2013 18:40:29 |
![]() 25215 forum posts 3105 photos 1 articles | Mine is a PEC US made one that I got from Greenwood tools about 4 years ago but I don't think they do them now. It has the solid type end 0.200" dia J&L do a 1/2" shank one , just remember they don't work on plastic so you still need the old type for that. |
John Hinkley | 18/07/2013 19:48:47 |
![]() 1545 forum posts 484 photos | Jasonb, Do you know where I could obtain an MT3 collet to suit such as you suggest? I've already spent too long on searching the internet with no luck. John
JasonB | 18/07/2013 20:41:33 |
![]() 25215 forum posts 3105 photos 1 articles | |
John Hinkley | 18/07/2013 21:09:24 |
![]() 1545 forum posts 484 photos | JasonB, I followed those links, but it makes more sense to get a chuck and set of ER32 collets for only about twice the price of one MT3 one! Nonetheless, I appreciate your input. John Edited By John Hinkley on 18/07/2013 21:09:44 |
Martin W | 19/07/2013 00:48:28 |
940 forum posts 30 photos | Sid
Thanks for the update re flexi tip EEFs. I must admit that I have only seen one or two and not used any Cheers Martin |
Gone Away | 19/07/2013 01:15:19 |
"Flexi-tip" is that what they call them. Good name ... one I can identify with |
Lambton | 19/07/2013 08:15:16 |
![]() 694 forum posts 2 photos | Buy a 3 MT blank-end arbor from Arc Eurotrade for £6 and carefully bore the blank end to take the EEF.
Eric |
Martin W | 19/07/2013 10:02:18 |
940 forum posts 30 photos | Hi Sid
Don't quote me on the name 'flexi tip' I just made it up on the spot to differentiate between the solid body EEFs and those having some degree of protection. Any other connotations re the term are, as they say, 'purely in the mind of the beholder/reader' Cheers Martin |
NJH | 19/07/2013 10:24:57 |
![]() 2314 forum posts 139 photos | Eric | "Buy a 3 MT blank-end arbor from Arc Eurotrade for £6 and carefully bore the blank end to take the EEF." Eminently sensible and cost effective suggestion I think. Norman |
Paul Lousick | 19/07/2013 10:30:14 |
2276 forum posts 801 photos | Lambton beat me to it. I also have a 20mm edge finder and going to modify a 3MT arbor to accept the edge finder. Much quicker than changing collets every time you want to use it. |
Russell Eberhardt | 19/07/2013 10:45:26 |
![]() 2785 forum posts 87 photos | It would be interesting to compare the accuracy you can achieve with these gadgets compared to the old cigarrette paper and spit method. Russell. |
