Brass or copper???
Cornish Jack01/07/2013 17:01:41
1228 forum posts
172 photos
G'day all.
Having a rummage in the shed and found a large-ish sheet of metal with a paper, hand-written label indicating it's copper. It looks much more like brass - is there any simple way of distinguishing the two, please?
TIA
Rgds
Bill
Bazyle01/07/2013 17:36:28
6956 forum posts
229 photos
If it didn't have a label would you be in any doubt? Did you get it at a boot sale from someone who didn't know the difference?
Brass will be more reactive to acid and if polished and etched with vinegar is likely to show a grain structure.
Is it a bronze which is more likely to be confused with copper by the original labeller? I have bronze door handles which are aged to a copperlike brown but look brasslike where the acid on my hands has 'cleaned' the tarnish.
Cornish Jack01/07/2013 18:34:01
1228 forum posts
172 photos
Thank you, Bazyle - not a boot sale but from an Ebay seller who listed it as copper. This was 6 or 7 years ago and I collected it from his house. I didn't notice any obvious discrepancy at the time or I wouldn't have completed. The label is hand-written but by whom I don't know. Didn't examine it closely as I was in the process of house-moving. Certainly, if it didn't have a label, I would say it was brass.
Not a big deal other than knowing how to deal with it for such things as soldering etc. Are there any/many caveats in dealing with one as against the other?
Rgds
Bill
NJH01/07/2013 19:03:32
2314 forum posts
139 photos
Bill
You could, of course, put your "copper" sheet back on ebay................................devil
N
JA01/07/2013 19:29:25
1605 forum posts
83 photos
Put a bit cut off the sheet in an open pot containing salt water with a small strip of "known" copper. Keep the two apart. Connect a modern voltmeter, set on a low range, between your unknown metal and "known" copper. If there is a voltage your unknown is not copper. If no voltage it is copper. You might have to check both polarities. It may be wise to repeat this with a strip of "known" brass. No voltage would equal brass.
If you don't want to damage the sheet I am sure you could find a way of sitting the salt water on the sheet (plasticene comes to mind).
JA
Cornish Jack01/07/2013 21:21:36
1228 forum posts
172 photos
Thank you, Norman! ...and YOUR Ebay user name is...?wink
Thank you also, JA. Might well give that a whirl. Given our proximity to the North Sea,(approx 20'!) salt water is no problem!!!
Rgds
Bill
Ian S C02/07/2013 12:03:01
7468 forum posts
230 photos
Lay a bit of cloth or paper soaked in the saline solution between the two bits of metal if you don't want to start cutting the big bit up, and procede as per JA. Ian S C
Cornish Jack02/07/2013 14:21:07
1228 forum posts
172 photos
Thank you all ...BINGO!!thumbs up
It Is brass! "Walks like a duck, squawks like a duck ... etc."
That brass/copper test was quite new to me. For anyone else who might need similar identification, I had to go to the AVO Pro meter to get an obvious reading - the smaller Akai wasn't sufficiently definite. Thanks again
Rgds
Bill
Stub Mandrel02/07/2013 20:50:40
4318 forum posts
291 photos
Interesting!
fizzy04/07/2013 00:16:33
1860 forum posts
121 photos
Confused me....thats like comaring chalk with asbestos.....they look completely different!! Now I have been known to pause thought with brass and phos-bronze, but only momentarily!!
