Matts BitsNBobs | 13/05/2013 11:44:46 |
![]() 29 forum posts 3 photos | Hi can anyone tell me the issue number or month and year of MEW magazine that covered Derek Browns conversion of a Myford S7B to cut metric theads? Thanks in advance, Matt. |
Murray Tricker | 22/08/2013 05:09:32 |
10 forum posts | Try Harold Halls index at www.homews-mew-index.co.uk
Brian Wood | 22/08/2013 09:02:24 |
2742 forum posts 39 photos | Hello Matt, The issue you want is June 2011 MEW 177. Regards Brian |
Gray62 | 22/08/2013 09:06:35 |
1058 forum posts 16 photos | Issue 177 has the article Metric Screwcutting without tears by D.A.G Brown Graeme |
John Stevenson | 22/08/2013 09:11:19 |
![]() 5068 forum posts 3 photos | Seems a lot of work to me when you can do the same with one gear to be changed. |
Matts BitsNBobs | 22/08/2013 12:15:30 |
![]() 29 forum posts 3 photos | Thanks for the replies guys, will have a look later,
Regards Matt |
Geoff Rogers | 22/08/2013 16:16:46 |
30 forum posts 4 photos | hi John, I am sure you have said before, but which gear? Geoff |
JasonB | 22/08/2013 16:22:27 |
![]() 25215 forum posts 3105 photos 1 articles | 33 or 34 see here |
Phil P | 22/08/2013 17:18:10 |
851 forum posts 206 photos | Posted by John Stevenson on 22/08/2013 09:11:19:
Seems a lot of work to me when you can do the same with one gear to be changed. John I have just been doing a load of metric threads on some collets and DA chucks for my Boley/BCA jig borer. I had just finished setting up the metric gear train as per the chart inside the cover when I remembered the 33/34 trick, so I changed it all back to that set-up and it works a treat, along with the Meek screwcutting clutch it is so simple and quick to cut metric now. Phil |
Roderick Jenkins | 22/08/2013 19:02:39 |
![]() 2376 forum posts 800 photos | I'm glad to see that there is a least one believer. The maximimum error in any thread using this system is 6 microns, that's 6/1,000,000 metres or 6/1000 millimeteres. Sadly, many people have unrealistic expectations of both their machines and their abilities and believe that any error is unacceptable - hence the oft quoted insistance that the only "correct" way to make metric threads on an imperial lathe is by using a 127 tooth changewheel. Relax, as Phil has shown; it's good enough! cheers, Rod |
Geoff Rogers | 23/08/2013 09:06:23 |
30 forum posts 4 photos | thank you Roderick for the tables in the other post. just the job. 6 microns - easy to work to if you happen to have a couple of millon pounds worth of kit, but not what you would find in the avearge shed. Geoff |
