Here is a list of all the postings Geoff Rogers has made in our forums. Click on a thread name to jump to the thread.
Thread: safety valve problem |
09/03/2020 18:58:07 |
as per Duncan, I am sure Polly will be able to provide a Gordon Smith design valve that will work.
Geoff |
Thread: hydraulic riveting |
21/06/2016 09:53:46 |
KWIL, the cylinder is single acting short stroke and made from SG cast iron. The piston is two part and fitted with a heavy section O ring. The piston/bore sizing is such that an anti-extrusion ring is not needed. The O ring is about 55mm OD and about 5.4mm section. I have used the cylinder to close up to 1/4" steel rivets (the largest I need to close) and it has seen a lot of use so far with the rear wheel strakes and front wheel construction (I am making three engines). To date, no leakage and nothing broken. The dollies are made from mild steel case hardened at the business end .
Geoff |
20/06/2016 11:59:46 |
I form the rivets in two stages; one to set and a second to form. I have found that the 'set' operation is most beneficial for two reasons, firstly to make sure the rivet fills the hole and secondly to stop, or at least reduce the chance of the rivet cocking over during squashing resulting in a very bad head. Rivet and I. Geoff |
20/06/2016 11:33:04 |
hi Andrew, I have a pressure gauge fitted to the hydraulic setup and I take the pressure to about 3000psi for 3/16" rivets. For the cylinder I have made these pressure equate to about 5.3 tons. This gives the formed head as shown in the photos - unless it goes wrong, that is. Geoff |
20/06/2016 11:07:35 |
hi Paul, the rivets are 3/16" steel round head and 3/4" long. The spokes and rim are 6mm, leaving 0.277" for the head. More or less equal to the 1.429D setting allowance specified for a formed round head. Geoff |
20/06/2016 10:31:26 |
I have uploaded some photos showing how I am riveting the spokes to the rims for the 4" scale Burrell traction engines I am making. The photos show the hydraulic cylinder used and the resultant rivet heads. using this tool I can use the as-supplied rivet head on the outside and from a head on the inside, where it is less visible. Hope this is of interest. Geoff Rogers |
Thread: Open thoughts |
15/01/2014 09:44:14 |
Michael, what do you mean by 'engineering ability' ? Geoff |
Thread: Tight thread |
10/01/2014 10:00:55 |
may be worth checking the spigot as well. regards Geoff |
Thread: Cutting parallel tooth gears |
09/11/2013 13:45:56 |
thank you Steve, both files are most useful In case anyone is interested, I have converted Steve's excel spreadsheet to MathCad (Prime, but can easily be produced in a version 15 option). Why - I just prefer MathCad as I can see all the formula.
Thread: Casting Preperation |
10/10/2013 22:20:19 |
Per Andrew, except I then give the not-to-be-machined regions a coat of paint. Makes then nicer to handle and easier to clean.
regards Geoff (currently in Germany for a rail impact test) |
Thread: cylinder material |
08/10/2013 11:51:17 |
as JasonB says, corrosion would also be my main worry. Some aircraft grades of aluminium may be ok, others most definitely not. Steam can be a very demanding fluid.
Thread: Help please - Firebox stays |
26/09/2013 16:52:07 |
I would go with the LBSC option or use 1/8" copper rivets. But either way, I would discuss it with your boiler tester first, as he (she?) will have the last say. Geoff |
Thread: ME/MEW Articles? |
09/09/2013 23:53:56 |
excellent!! |
08/09/2013 16:07:28 |
Andrew, is it a workshop or a factory you have for making your traction engines? |
Thread: myford metric thread cutting |
23/08/2013 09:06:23 |
thank you Roderick for the tables in the other post. just the job. 6 microns - easy to work to if you happen to have a couple of millon pounds worth of kit, but not what you would find in the avearge shed. Geoff |
22/08/2013 16:16:46 |
hi John, I am sure you have said before, but which gear? Geoff |
Thread: May be worth watching? |
12/08/2013 11:36:14 |
I found the programme as expected, but it was interesting. I now know that mine winding engines have a connector rod rather than a connecting rod - so I learnt something. The rivets on the 'barn engine' boiler looked nice and shiny so it must have been ok, unless it was a dummy end of course. |
08/08/2013 09:49:11 |
thanks JasonB lets hope it has more focus on the content rather than the presenters.
Thread: Too shiney and new |
08/07/2013 09:15:53 |
bright and shiney so it can go back into the house after running, I suppose. I have drilled holes in my Myford and cut/bent spanners for restricted access. |
Thread: Trouble getting started |
28/06/2013 10:37:53 |
As with Andrew, I am using 3D CAD (TurboCAD Pro) to draw up the 4" Burrells I am constructing and I have found the need to 'refine' parts to make them fit properly. The CAD program made designing the hyrdraulic rivetter for the rear wheel strakes straightforward. So I find a CAD program is most useful and does not encroach on metal time, quite the opposite. |
