Clive Hartland | 16/04/2013 21:49:06 |
![]() 2929 forum posts 41 photos | I have been trying to purchase a reverse dovetail milling cutter but cannot find any of about 15mm diameter. Do any members have a suggestion? Clive |
Stub Mandrel | 16/04/2013 21:54:15 |
![]() 4318 forum posts 291 photos 1 articles | > reverse dovetail milling cutter Do you mean a bevel cutter? Or a standard dovetail cutter (biggest at the far end?) Mine is about 3/4" / 19mmdiameter - from Tracy Tools - is that too big for your needs? Neil |
M0BND | 16/04/2013 21:56:56 |
81 forum posts 9 photos | Try this ..... http://www.mscdirect.co.uk and search for Inverted Dovetail Andy. Edited By M0BND on 16/04/2013 21:58:32 |
M0BND | 16/04/2013 21:57:37 |
81 forum posts 9 photos | Oops, has that displayed ok? Andy. |
Michael Gilligan | 16/04/2013 22:02:02 |
![]() 23121 forum posts 1360 photos | Andy, No ... definitey not displaying O.K. Can you please insert your hyperlinks using the icon on the toolbar of the message editor. Thanks MichaelG. . Edit: Your shortened version displays O.K. but it's still a risky way of posting. ... There are numerous threads on this site about this problem. Edited By Michael Gilligan on 16/04/2013 22:06:13 |
M0BND | 16/04/2013 22:03:19 |
Posted by Michael Gilligan on 16/04/2013 22:02:02:
Andy, No ... definitey not displaying O.K. Can you please insert your hyperlinks using the icon on the toolbar of the message editor. Thanks MichaelG. I have deleted and just inserted the site and what I searched for now.... Andy. |
Clive Hartland | 16/04/2013 22:04:05 |
![]() 2929 forum posts 41 photos | Yes, a bevel cutter 45 Deg would be fine. Correctly called, 'Inverted dove tail cutter' mscdirect, the prices make my eyes hurt !! I did have one but it has dissapeared. A very desirable item and I am sure someone has filched it. Clive There is one on Ebay but is needing bidding for. Edited By Clive Hartland on 16/04/2013 22:04:55 |
Michael Gilligan | 16/04/2013 22:08:49 |
Posted by M0BND on 16/04/2013 22:03:19
I have deleted and just inserted the site and what I searched for now.... Andy. . Cheers, Andy [Please see my edited post, above] MichaelG. Edited By Michael Gilligan on 16/04/2013 22:09:10 |
Clive Hartland | 16/04/2013 22:09:02 |
![]() 2929 forum posts 41 photos | I will try Tracy tools again, As you say European tool firms will have them. I will try Brutsch|Ruegger. Clive |
Michael Gilligan | 16/04/2013 22:14:31 |
![]() 23121 forum posts 1360 photos | Clive, Here is one in 13mm ... but I see what you mean about eye-watering prices. Note to self: take good care of your Dovetail Cutters !!! MichaelG. |
JohnF | 16/04/2013 22:38:07 |
![]() 1243 forum posts 202 photos | Hi Clive, Depends how much work you need to do but why not make one from silver steel? I have made several over the years, not reverse ones, but no reason why not. Mine were small ones to machine dovetails for rifle/pistol sights and quite small diameter, about 6mm O/D. They worked very well providing you keep the cutting speed at a suitable level for carbon tools. Regards John. |
John Haine | 17/04/2013 02:30:02 |
5563 forum posts 322 photos | What's the application? For chamfering Ali I find that a standard countersink works very well, even making quite aggressive cuts. I think with slow feed and light cut it would do mild steel ok too. |
I.M. OUTAHERE | 17/04/2013 06:57:02 |
1468 forum posts 3 photos | Hi Clive , Type inverted dovetail cutter into Ebay (search the world option) and you may see what you want and also try countersink cutter. It depends on what you want it for - if it is a true dovetail shape you need then the countersink cutter won't do as it has a shoulder above the cutting teeth but if it is to cut a bevel then maybe it could work.
Ian Edited By SLOTDRILLER on 17/04/2013 06:59:28 |
John McNamara | 17/04/2013 08:31:56 |
![]() 1377 forum posts 133 photos | Hi Clive Google the following: Inverted dovetail cutter images or Inverted dovetail cutter images .uk One of the better Google secrets for finding things. Just click on the images not all will link but many do. It beats trawling through websites. Cheers John
KWIL | 17/04/2013 09:41:43 |
3681 forum posts 70 photos | Not a problem, Sussex Tools have all sizes metric and imperial, usually british made. 16mm available. Just a satisfied customer. |
Clive Hartland | 17/04/2013 10:09:30 |
![]() 2929 forum posts 41 photos | Thank you lads, I have now ordered one from Kwils information. Clive |
Stub Mandrel | 17/04/2013 19:49:18 |
Well I learned something today (alongside "don't drive over bricks in the road" Neil |
