Fleabay
Takeaway | 17/02/2013 20:43:54 |
108 forum posts | As I am in the market for a new lathe and milling machine I will often search on ebay with "lathe -wood" (lathe minus wood) but get all sorts of rubbish that is lathe related but NOT lathes. Do you know of any search technique that will deliver "lathe" - "lathe" and nothing but a lathe? Stuart |
Gray62 | 17/02/2013 20:53:57 |
1058 forum posts 16 photos | All depends on what you are looking for but try searching for Myford, Boxford, Colchester, Harrison, Warco, Chester, these are just some of the lathe manufacturers. If you can expand on what type/size of lathe you are looking for I am sure we can assist in refining your search terms.
Do you want a large (6" + swing) or small (<5" What type of Mill are you looking for, bench top, Vertical turret, horizontal,Universal etc etc. The more info you can give is better. cheers CB |
Takeaway | 17/02/2013 21:07:21 |
108 forum posts |
Thanks CoalBurner - but I'd be quite happy with specific search results based on just "lathe" or "milling machine". I get the distinct feeling that I am stretching ebay search engine to breaking point - gives me a nice warm feeling inside |
Andrew Johnston | 17/02/2013 21:39:24 |
![]() 7061 forum posts 719 photos | In a word, no. I think that it is against the Ebay rules to post items such as generic cutters, which then include words like 'Myford' in the title. But unfortunately it is all too common, and a right royal PITA. The best you can do is search for specific models - say 'Harrison M300' or 'Myford ML7'. In a sense that is no bad thing, as it forces one to think a bit more about exactly what it is that one is looking for. Regards, Andrew |
speelwerk | 17/02/2013 22:14:44 |
464 forum posts 2 photos | "Lathe -wood" on eBay.co.uk gives, without setting advanced search options, ca. 8000 results. If you then set "Auctions only", and loose much of the trade, you get around 800 results, then you sort by "price: highest first" and you will have lost most of the rubbish. Niko. |
Mike Clarke | 17/02/2013 22:16:08 |
![]() 95 forum posts 2 photos | Hi Stuart. You can filter results a little. You say you're after a new lathe - do you mean new or used (new to you)? If it's a secondhand lathe you're searching for then filtering for used lustings will help considerably. The other way to further refine results is to select the appropriate category (on the left you will see a long list of categories where your "results" have come from. Good luck in your search. Mike.
Bazyle | 17/02/2013 22:51:29 |
![]() 6956 forum posts 229 photos | If you just select 'newly listed' and look at it every day after about a week all have passed through the system anyway. If there is a particular day when loads of cutters or inserts come up you can take them out. Also select auctions and UK only too. It only takes a few minutes to go through the new stuff and whack interesting ones into your watch list. I look at this everyday specifically to find the odds and ends that are not actually lathes as I have one of those. After a while you get to know what rarely comes up and what is overpriced. You might as well do this as once you have the lathe and mill you are going to want the other stuff so you might as well get familiar with it now. I do find it sad how many sales are by friends and relatives who have no idea what the item is that possibly grandad loving ly made or cherished.
Ed Duffner | 18/02/2013 01:56:56 |
863 forum posts 104 photos | This one shows more results without wood turning; lathe -(wood, woodworking, woodturning, wood turning)
Edited By Ed Duffner on 18/02/2013 01:57:15 |
Paul Lousick | 18/02/2013 02:25:17 |
2276 forum posts 801 photos | Search for metal lathe (not lathe-wood) |
Ian S C | 18/02/2013 09:07:16 |
![]() 7468 forum posts 230 photos | Got a good responce when I went into google with:- wanted engineers metal lathe. Ian S C |
Alan .204 | 18/02/2013 19:17:08 |
304 forum posts 14 photos | You could try model making metal lath, possibly add small the same for the miller.
Al. |
