Johan Crous | 31/01/2013 20:01:16 |
![]() 41 forum posts 1 photos |
I have seen countless examples where aluminium was used in stead of steel and it worked. Not so hard but working. |
David Littlewood | 31/01/2013 20:08:51 |
533 forum posts | Johan, There are hundreds of varieties of brass, with a very wide range of properties. Some of them have a tensile strength higher than mild steel; some are better than others for casting. A quick Google search threw up this useful looking resource: I'm sure a more careful search would throw up many other informative sources. Hope that may help. David |
Michael Gilligan | 31/01/2013 21:05:10 |
![]() 23121 forum posts 1360 photos | Johan, Many of the "Ornamental Turning" lathes, such as Holtzapffel, made extensive use of Brass for slideways, etc. However; as David says, there are many grades of Brass; so there is no easy answer. As for DIY casting ... please take care. If I understand correctly; very little Brass Casting is now done in this Country -- simply because of the related Health problems. (I will see if I can find some detail, and post later) MichaelG. . This thread is worth reading. Edited By Michael Gilligan on 31/01/2013 21:11:49 |
Stub Mandrel | 01/02/2013 21:06:52 |
![]() 4318 forum posts 291 photos 1 articles | I made a gib strip out of brass I had bought to make free-hobbed gears from. It was so hard the first gear came out one tooth short, and the second one tooth extra, I gave up and got some engraving brass hich was fine for gears. As I say the hard brass went into a gib strip - it was amazingly difficult stuff to work, but I was able to preserve the mirror finish on the bearing surface, which I then finished by flatting it with very fine abrasive paper. the result was silky smooth in use and has shownno visible wear. Neil |
Ian S C | 02/02/2013 10:26:03 |
![]() 7468 forum posts 230 photos | One of the main problems is the cost of brass over as a block of hot rolled steel. Brass is (well it was a yr or so ago) cast in Christchurch, although I had to change foundries, as the one I used to use now only does ferrous castings. Every yr or two I get a hundred or so Horse Brasses cast for the souvenir shop at our museum. I made 8 patterns. Ian S C |
Versaboss | 02/02/2013 12:11:54 |
512 forum posts 77 photos | If it looks like brass but is d@mn hard it could well be Aluminium Bronze. The colour is almost the same. I once gave up drilling a 3 mm hole in this stuff (yes I used a good drill...) Greetings, Hansrudolf |
Stub Mandrel | 02/02/2013 19:44:42 |
![]() 4318 forum posts 291 photos 1 articles | Hi Hansrudolf, Not so much hard, as nasty to work - it grabs toolbits and repels all but brand new files. It was 1/4" thick CZ108 from CES, I re-ordered the leaded engariving brass CZ120 which was much easier to work. Neil |
Gordon W | 03/02/2013 10:30:39 |
2011 forum posts | While clearing up in the w/shop I found a few old nozzles from oxy-acetaline and oxy-propane cutters. They look like bronze of some sort, does anyone know what? IE will they be any use for ,say, bearing bushes ? Or do I just weigh em in? |
Les Jones 1 | 03/02/2013 11:06:34 |
2292 forum posts 159 photos |
Hi Gordon, Les. |
Gordon W | 03/02/2013 14:54:48 |
2011 forum posts | Thanks Les, I've cleaned one up and you are right, of course, the burning does put a nice colour on tho'. They'll come in for something. |
