JC Uknz 1 | 14/01/2013 05:20:33 |
![]() 54 forum posts |
I am getting a ME 1/4 x 40 taps so in the first place need to know the tapping drill size for them but also wonder about a link to a site giving all ME tapping sizes. Hope you can help |
Thor 🇳🇴 | 14/01/2013 05:26:18 |
![]() 1766 forum posts 46 photos | Have a look at Harold Hall's website. Regards Thor |
JC Uknz 1 | 14/01/2013 05:59:47 |
Thankyou Thor for that quick reply ... you have given me a link to a very valuable site |
Terryd | 14/01/2013 07:26:29 |
![]() 1946 forum posts 179 photos | Hi (sorry to be impersonal but I don't have a name to address you properly), It would be worth installing a copy of Alan Munday's Model Engineers Utilities on your PC. It has a lot of extremely useful data (including data for most screw threads you are likely to need). I cannot recommend it highly enough. best of all it is a free download from here. Best regards Terry Edited By Terryd on 14/01/2013 07:27:06 |
HomeUse | 14/01/2013 10:11:25 |
![]() 168 forum posts 12 photos |
Hi Terryd - I had a copy of the Utilities on my Old PC - Now I have been updated to A MAC |
Terryd | 14/01/2013 10:46:54 |
![]() 1946 forum posts 179 photos | Hi H,
( a proper name would be nice Terry |
Ziggar | 14/01/2013 10:56:13 |
![]() 115 forum posts 1 photos | asking a Mac user to install anything MS on their machine is like asking a vegatarian to chomp down on a chicken sandwich ..... probably the main reasoon for swapping from a PC to a Mac is to get away from MS
Ziggar | 14/01/2013 10:58:56 |
![]() 115 forum posts 1 photos | and to asnswer the opening question :--
there are _many_ websites and webpages dedicated to giving you the needed tapping sizes if you use Google to search for them
HomeUse | 14/01/2013 12:06:50 |
![]() 168 forum posts 12 photos | All is not lost as the OLD PC is still in use - Still have to use it for TurboCad - MAC version is like running up the down esculator - That is unless any Mac user out there can enlighten me.??? |
Terryd | 14/01/2013 14:09:42 |
Posted by Ziggar on 14/01/2013 10:58:56:
and to asnswer the opening question :-- there are _many_ websites and webpages dedicated to giving you the needed tapping sizes if you use Google to search for them Hi Z, With Mr Mundays Utilities it is possible to calculate gear ratios, spring sizes, pcd, sine bar calcs, sheet metal bending data, compare drill sizes, cutting feeds and speeds, as well as easily get thread data, and very much more, all with a couple of clicks in one place with no need to Google anything. perhaps I'm just lazy For the record, I am a MAC user (+iPhone, iPad, etc) but when I need to run programs that are only available for Windows I am quite willing to use an emulator - which is definitely not the same as using Windows. Best regards, Terry Edited By Terryd on 14/01/2013 14:16:49 |
Russell Eberhardt | 14/01/2013 14:44:33 |
![]() 2785 forum posts 87 photos | Install "Wine" on your MAC. It will enable you to run most Windoze programes directly. Failing that you could install VirtualBox which will enable you to actually install Windoze on an emulated virtual computer. Works fine here on my Linux computers. Russell. |
Michael Gilligan | 14/01/2013 15:39:12 |
![]() 23121 forum posts 1360 photos |
Posted by HomeUse on 14/01/2013 12:06:50:
I suggest you leave TurboCad where it is, and install DraftSight on the Mac. MichaelG.
HomeUse | 14/01/2013 16:00:33 |
![]() 168 forum posts 12 photos | Hi M G - ? Is DraftSight any good for Architectural Drawings |
Michael Gilligan | 14/01/2013 17:05:03 |
Posted by HomeUse on 14/01/2013 16:00:33:
It's only 2.5D ... but is remarkably like a legacy version of AutoCad. Definitely worth a try at the price If you need full 3D presentation; have a look at SketchUp MichaelG. |
thomas oliver 2 | 16/01/2013 19:40:01 |
110 forum posts | My reference handbooks show that since the thread size of ME x40tpi is constant, the tapping drill will in all cases be 1/32in less than the nominal size, and this will give 97% engagement. TomOl |
Ian Sugden | 23/01/2013 20:14:13 |
7 forum posts |
Posted by Terryd on 14/01/2013 07:26:29:
Anyone got this program to run on windows7? All comes up with black shaded squares
Steambuff | 23/01/2013 20:30:29 |
![]() 544 forum posts 8 photos | Runs fine on Windows 7 here ..... remember to install as administrator
Roderick Jenkins | 23/01/2013 20:35:04 |
![]() 2376 forum posts 800 photos |
Posted by thomas oliver 2 on 16/01/2013 19:40:01:
My reference handbooks show that since the thread size of ME x40tpi is constant, the tapping drill will in all cases be 1/32in less than the nominal size, and this will give 97% engagement. TomOl 97% engagement is asking for broken tap! 5.7mm gives 80% or 5.8mm 65% (from Tubal Cain's "Drills Taps and Dies" Rod |
Ian Sugden | 23/01/2013 23:12:21 |
7 forum posts |
Posted by Steambuff on 23/01/2013 20:30:29:
It only unzips the file and not installs |
Steambuff | 23/01/2013 23:48:02 |
![]() 544 forum posts 8 photos | Ian, Unzip the file (as administrator) into any folder you wish .... Once it it has unzipped it is ready to use ... using Windows Explorer, navigate to the folder you unzipped the files into .... Then double click on the ModelEngineersUtilities.exe file. If you want an icon on your desktop then right-click, select 'Copy' and then hover over your desktop, right-click and 'Paste short-cut' Dave
