chris j | 21/11/2012 19:01:01 |
338 forum posts 17 photos |
Hi
Has anyone availed themselves of this installation service.
I am wanting to fit a DRO to a lathe and am a little nervous about doing it on my own.
Best Chris
Gray62 | 21/11/2012 20:09:42 |
1058 forum posts 16 photos | Hi Chris, Not used their services but I have fitted a DRO system to my Warco GH1330, used the glass scale for the Z0 and magnetic scales for Z1 and X axes. All were purchased from Allendale (machine-dro.co.uk) and were supplied with comprehensive installation instructions. What make of lathe are you installing on? I am sure there are many here that can give advice etc as to the best way to install
It is not a difficult job, just one that needs a little patience and care CB |
chris j | 21/11/2012 21:18:32 |
Posted by CoalBurner on 21/11/2012 20:09:42:
It is not a difficult job, just one that needs a little patience and care CB Proaby a 1322 or a 1330. Why did you go for glass & magnetic I wonder ? Also what is Z0 , Z1 & X ? Thanks Chris |
chris j | 23/11/2012 09:02:33 |
Stub Mandrel | 23/11/2012 16:47:36 |
![]() 4318 forum posts 291 photos 1 articles | X is left to right motion, Y is back and forth. Z1 and Z2 refer to vertical motion (presumably the knee or head and the quill in machine with two vertical motions. Other axes would be likely to be rotation around one of the three (X,Y,Z) primary axes. Neil |
chris j | 23/11/2012 17:44:25 |
Posted by Stub Mandrel on 23/11/2012 16:47:36:
That is what I understood on a Mill but this applies to a Lathe so I'm lost a bit ( as usual Chris |
chris j | 02/12/2012 20:41:30 |
I have decided to fit a DRO myself.
Does anyone have one fitted to their Warco lathe.
A photo or two would be appreciated
Chris
mechman48 | 10/12/2012 06:30:26 |
![]() 2947 forum posts 468 photos | Hi Chris J I also have a Warco lathe..WM250-VF, would also like to see pics if anyone has fitted DRO to similar lathe, what DRO system do you have? George |
mgnbuk | 10/12/2012 07:41:51 |
1394 forum posts 103 photos | That is what I understood on a Mill but this applies to a Lathe so I'm lost a bit X = Cross slide Z0 = Saddle Z1 = Compound slide Regards, Nigel B.
chris j | 10/12/2012 11:26:50 |
Posted by mechman48 on 10/12/2012 06:30:26:
Hi Chris J I also have a Warco lathe..WM250-VF, would also like to see pics if anyone has fitted DRO to similar lathe, what DRO system do you have? George I got mine from Allendale. He does have some photos of various installs, so wing him an email maybe.
SDS6 3 Axis Universal Display Console |
chris j | 10/12/2012 11:33:36 |
Posted by Nigel Barraclough on 10/12/2012 07:41:51:
Thanks Nigel |
Gray62 | 10/12/2012 13:37:34 |
I will try and get some photos sorted but if you need advice, PM me and we can talk about the install. I am In East Hampshire so If I am close, I would be happy to assist I went for the Glass scale on the Saddle essentially because it was cheaper at the time. I also considered it would be more robust over the travel distance on a GH1330. The magnetic scales on the cross and compound slides were chosen because they are more compact than the equivalent glass scales. I used the 2 part scale mounts as that was all that was available at the time. I have since changed to their 'One Part' mounting kit and have to say, that is what I would use on future installs, reduces the install profile by around 5mm. I used the budget readout head from Machine-DRO and this has proved more than adequate for the lathe. It has a Z0+Z1 combine facility which has proved very useful at times. My primary reason for installing a DRO was that I have difficulty in reading small scale divisions caused by a visionary defect, ( I have Kerotaconus). Having a DRO on the lathe has transformed my machining ability. (Had one on the mill for ages!) Regards Graeme
chris j | 10/12/2012 18:47:44 |
Posted by CoalBurner on 10/12/2012 13:37:34:
Hi Chris,
I will try and get some photos sorted but if you need advice, PM me and we can talk about the install. I am In East Hampshire so If I am close, I would be happy to assist Graeme
Thanks Graeme I'll look forward to photos.
I wish you were in E Norfolk I'll send you a PM in a bit when Strictly Dancing comes on, I need something to do!! Chris
Cornish Jack | 10/12/2012 22:11:59 |
1228 forum posts 172 photos | Chris Can't help with the DROs (have a half dozen basic, wire activated, not yet fitted) but also in E Norfolk - Bacton ... if moral support needed!! Rgds Bill |
chris j | 10/12/2012 23:08:52 |
Posted by Cornish Jack on 10/12/2012 22:11:59:
Chris Can't help with the DROs (have a half dozen basic, wire activated, not yet fitted) but also in E Norfolk - Bacton ... if moral support needed!! Rgds Bill Thanks Bill I have sent you a message Chris
