mark mc | 14/11/2012 08:39:31 |
92 forum posts 16 photos | So this is the first time i have ever needed to cut a gear and its a 53 tooth one, i have a rotary table with dividing plates but no 53 plate. So i was thinking i have a mill with a dro that can do pcd's, so i could use this to make a 53 plate. Now here's my question my rt is 90/1 so after alot of reading i think i need 1turn and 37 holes ? does this sound right ? I have no engineering training at all apart from books ie workshop practice series. thanks |
Andrew Johnston | 14/11/2012 09:25:15 |
![]() 7061 forum posts 719 photos | Mark, I agree. The rationale is as follows. To make one full turn of the rotary table takes 90 turns of the handle. To divide a single turn of the table into 53 equal parts we need to turn the handle by 90/53 each time. Since 53 is a prime number we cannot simplify the improper fraction. However we can express it as 1 and 37/53. If we have a 53 hole plate then it is simple! Here's a picture of a 63 and 69 hole plate I made for my dividing head, to cut 63 and 69 tooth gears, because I was too idle to set up the gears for differential indexing: Remember that any errors in the dividing plate will be divided by 90, which is good. Regards, Andrew |
mark mc | 14/11/2012 09:41:28 |
Thanks Andrew, I'll give it a whirl and see what comes out .We never did any fractiions/prime numbers etc at school, takes abit of getting yer head around. Edited By mark mc on 14/11/2012 09:42:00 |
RICHARD GREEN 2 | 14/11/2012 09:41:51 |
329 forum posts 193 photos | Hello Mark, Your calculations are correct, 53 hole plate, 1 full turn and 37 holes, will give you 53 divisions on a 90-1 rotary table. Here is a picture of a 95 tooth 6DP gear I cut last week, on a rotary table. Richard. Edited By RICHARD GREEN 2 on 14/11/2012 09:44:28 |
mark mc | 14/11/2012 09:47:42 |
Good lord Richard that's scary looking to me, but looks very nice too. thanks for replying. Off now to make a 53 hole plate, hopefully.... |
jason udall | 14/11/2012 15:03:25 |
2032 forum posts 41 photos | Sorry to sound thick but if you need to make 53 tooth gear and can cut 53 hole plate well whats the problem?. but if you mean 37 hole plate ok but how is that easier? sorry but not completely familiar with RT and dividing heads 90/53 ok get that 90/53 = 1 + 37/53 -- ok here too how does a 37 hole plate help..?
JasonB | 14/11/2012 15:09:37 |
![]() 25215 forum posts 3105 photos 1 articles | You don't use a 37 hole plate its one full revolution and 37 holes of the 53 hole plate 1 rev =53 plus the 37 equals 90 So 90/53 gives the fraction needed
Another way to look at it.
360 divided by 53 means each tooth is 6.792degrees. with a 90:1 ratio on the table, one turn gives 4 degrees add that to 37/53 of a turn (0.698x4) = 2.772 and that gives you the desired 6.792deg rotation I don't think mark has a problem just wanted his calculations confirmed J
Edited By JasonB on 14/11/2012 15:16:10 |
Michael Cox 1 | 14/11/2012 16:14:51 |
555 forum posts 27 photos | If you only want one gear it is hardly worth making a dividing plate. As Jason has pointed out the angular rotation between teeth is 6.792 degrees = 6 degrees 47 minutes 31 seconds. Just make a table of the angular rotation required for each tooth ie 6.792, 13.584, 20.376.......etc until you hav done a complete revolution. Convert this table into degrees, minutes and seconds. Then just increment the rotary table to the required angle for each tooth. It requires a little concentration but is perfectly doable. Mike |
jason udall | 14/11/2012 16:23:12 |
2032 forum posts 41 photos | Ahh JasonB (this might get confusing).. so he can "do 53" with the dro ...... thus 90/53 = 1 +37 holes of 53 plate......but if you have 53 plate why not index one hole per tooth? Michael .. coming to this from CNC land thats how I would have done it ( with a suspecious eye on rounding errors..).... .... Ahh well , it is to learn that we live.
JasonB | 14/11/2012 16:47:49 |
Posted by jason udall on 14/11/2012 16:23:12:
You can't do that with a rotary table as you need to take into account the 90:1 reduction, going one hole at a time would give a 4770tooth gear. If you were using teh plate for direct indexing on say the lathe spindle then it would work |
Stub Mandrel | 14/11/2012 20:05:39 |
![]() 4318 forum posts 291 photos 1 articles | I agree, don't get too hung up on exact dividing. My home made rotary table is geared 60:1 and has 60 graduations on the dial. I use excel to produce a table of the readings and work around a gear using that. The maximum error is half a division or 0.05 of a degree. For a 2" diameter blank that's 0.00087" or less than a thou. When I had to read maps or use burettes I had to estimate tenths of a division. If you can do that the error approaches a tenth of a thou or about five wavelengths of red light... In other words a division plate is NOT required to work within industrial tolerances for typical model engineering gears. Neil Edited By Stub Mandrel on 14/11/2012 20:07:59 |
Andrew Johnston | 14/11/2012 21:21:47 |
![]() 7061 forum posts 719 photos | The OP says that his rotary table has provision for dividing plates, so why not use them? Also, we do not know the diameter of the gear to be cut; the bigger it is the more accurate the division need to be. I will be cutting my traction engine final drive gears on a rotary table, as per Richard's setup, as at 14.8" diameter they will not quite fit under the milling machine arbor. I am budgeting for an error of 2 thou at that diameter and will compensate for it by cutting the teeth slightly deeper. That's accuracy of course, not resolution, which is quite a different thing. Regards, Andrew |
mark mc | 14/11/2012 22:05:35 |
92 forum posts 16 photos | The gear is for a small worm drive inside a single drive unit for a wheel chair, it's only around 62mm dia and some bright spark thought it would be great idea to make it from plastic with teeth that have no profile at all, the look as if they have been cut with a hack saw, dead straight no kidding. Didn't get much time in the cave today but I'll get the plate finished tomorrow, again thanks all for the help. |
Gone Away | 14/11/2012 22:45:01 |
829 forum posts 1 photos | Posted by Stub Mandrel on 14/11/2012 20:05:39: ...... tenth of a thou or about five wavelengths of red light... .... oh, I don't think so. 5 x 700 nm ? |
Andrew Johnston | 14/11/2012 23:08:02 |
![]() 7061 forum posts 719 photos | More like green light? - Andrew |
Bazyle | 14/11/2012 23:37:58 |
![]() 6956 forum posts 229 photos | You can make an approximate plate for reuse to make a better one using any existing plate, or a change wheel by the multi-turn method. Say you have adapted a 60 tooth change wheel to fit the rt which gives 60 x 90 = 5400 steps all round the circle.. You want 53 so you need to count 5400/53 steps = 101.887 steps. But you can't step a fraction. So miss the first tooth (or hole) and see if you can do the second ie 2 * 101.887 = 203.774. Still no good but keep going and you get to No 9 = 916.981. Ok so do 917 steps and you have only a slight error. Repeat the process and you eventually fill in all the teeth with a bit of an error by going round multiple times. the error is spread all over the target not built up progressively. But when you use that as the index device the error gets reduced. This is what the stepper motor dividing gizmos do. Some combinations work better than others but basicly any existing plate can make any new plate. |
jason udall | 14/11/2012 23:45:34 |
2032 forum posts 41 photos | 380 to 760 nm (400-790 TeraHertz) is generaly accepted as visable light so for rock and roll 500nm or 0.5 um (microns) will do. anyway OP seems sorted and I will work on my problem of gettinng comfortable with division as required in the future {if required}..though I am sure to find a application {not an app} somewhere Thanks anyway.
Stub Mandrel | 15/11/2012 21:28:43 |
![]() 4318 forum posts 291 photos 1 articles | You're right. I had about 450nm in mind as a typical 'wavelength of light', so perhaps I should not have guessed the colour. Even so, it always surprises me that the difference between the small you can relate to (i.e. working toa a thou or less) and the small you can't quite grasp (wavelength of light, size of animal cells or even bacteria) is not really very much at all. Neil |
Ian P | 15/11/2012 23:14:34 |
![]() 2747 forum posts 123 photos |
Posted by Andrew Johnston on 14/11/2012 21:21:47:
The OP says that his rotary table has provision for dividing plates, so why not use them? Also, we do not know the diameter of the gear to be cut; the bigger it is the more accurate the division need to be. <snip> Andrew Just been thinking about this and still cannot see why greater division accuracy would be needed if the gear is larger. Angles are angles, but if this gear is 'large' then the one it meshes with will be larger by the same proportion so the angular error will be the same. If there are errors of spacing beween the teeth causing varying backlash or binding this would actually be more problematic on very high DP gears like in a watch, than it would on ultra large gears on say a traction engine.
Ian
Stub Mandrel | 16/11/2012 20:57:30 |
![]() 4318 forum posts 291 photos 1 articles | From my old Machinery's Handbook tooth-tooth tolerance barely increase as gears get bigger, but gets bigger more or less in proportion to tooth size. It will upset the clockmakers, but the recommended gear quality for clocks is in the lowest category with milking machines and kitchen blenders, below hair and hedge clippers, with gun data computers and gyroscopes at the top. Neil |
