Case hardening
Eyes of a small link
David Haynes17/10/2012 16:54:12
168 forum posts
26 photos
Hi Folks,
I want to case harden the eyes of a small link, 5/8" C/Cs with 0.096" dia holes. I understand that I heat to red/ pack hardening compound in and repeat a few times before quenching in water.
How will I know I have done enough treatment and will I need to re-drill to return to original hole size, but will this remove case hardening?
Thanks
Clive Hartland17/10/2012 17:13:05
2929 forum posts
41 photos
Dave, its the length of time it stays at the red heat that matters and if you have an idea that you will have a size problem then allow for it but I dont think you will.
Perhaps two sessions will give you about 5 to 10thou. depth of hardness. The surfaces will be glass hard and almost untouchable by drills etc. You could perhaps lap out the holes.
I personally have never had size change yet !
David Haynes17/10/2012 17:52:24
168 forum posts
26 photos
How does the inner bearing surface become adequately hardened without losing bore?
colin hawes17/10/2012 17:52:56
570 forum posts
18 photos
It is unlikely to change dimension. If a small distortion is apparent you could easily lap it, as already suggested, with a suitable pin and lapping paste. Colin
David Haynes17/10/2012 19:21:29
168 forum posts
26 photos
Thanks for these thoughts. I have case hardening compound but not enough old shoes or belts to make up the leather carbon source. I did wonder if I had enough steel plate I could spare but I realised it may be okay to use a tin can. We only recently had corned beef so the box tin might do the job.
But, is it work waiting for some leather scraps?
I will try the process on a drilled bar stock before I try it on the machined links.
Also, for lapping compound, I suppose a fine grade grinding paste would do?
Thanks again
Edited By David Haynes on 17/10/2012 19:23:09
JohnF18/10/2012 23:14:40
1243 forum posts
202 photos
Hi David, search this forum with "Case Hardening" and you will see a couple of posts from me on this subject.
If you use the corned beef tin, fine but you must seal the lid with fire clay to prevent oxidising you work.
With hardening compound and a torch you will only get a very thin case unless you hold it in the flame for a great deal of time --- penetration is usually in the order of 0.005"per hour for pack hardening but there are several factors that affect this.
Good luck John
JohnF18/10/2012 23:19:50
1243 forum posts
202 photos
Good luck John
roy entwistle20/09/2013 11:43:01
1716 forum posts
Doe's anyone know if it is possible to case harden plated bolts I don't know what the plating is
Thanks Roy
Russell Eberhardt20/09/2013 12:09:52
2785 forum posts
87 photos
Posted by roy entwistle on 20/09/2013 11:43:01:
Thanks Roy
Not without removing the plating first Roy. Why would you want to do this?
Russell.
roy entwistle20/09/2013 13:56:41
1716 forum posts
Russell They are square headed for my tool post
Roy
ega20/09/2013 14:11:22
2805 forum posts
219 photos
My Oxford arc welder has a 12V tapping which can be used with a carbon rod in the electrode holder to heat and solder, etc. The brief instructions also claim that the carbon can be used to harden steel. I had never tried this until very recently when I found that it seemed to work after a fashion.
Has anyone any experience of this method or helpful comment to make?
jason udall20/09/2013 14:28:22
2032 forum posts
41 photos
Well if only zinc plated...pickle.
If cadmium plated , then I don't want to know what you do with pickle
During and after...
But the heat might be used to remove plating..heat.pickel ..case..
jason udall20/09/2013 14:29:42
2032 forum posts
41 photos
Btw..plated parts are made "under size" to allow for plating to size
Russell Eberhardt20/09/2013 16:52:01
2785 forum posts
87 photos
Roy,
I would leave them as bought. If they are working on hard tools it isn't a good idea to harden them. Just turn the thread off the end for a short distance to stop them jamming.
Russell.
ega20/09/2013 17:15:23
2805 forum posts
219 photos
Russell Eberhardt:
I agree that hard on hard seems wrong and, in any event, suspect you know more about this than I. However, one authority (the late Cliff Bower) said "clamping screws for tool-posts should always be made of high-tensile and case hardened material and the lower ends bevelled neatly". He went on to suggest drilling the ends and inserting a standard (presumably, hardened) steel ball-bearing making the interesting point that screws treated in this way do not tend to shift the toolshank when tightened.
I personally use standard HT capscrews treated as you suggest and try to avoid overtightening.
Stub Mandrel20/09/2013 17:22:25
4318 forum posts
291 photos
The supplied M6 cap screws in y 4-way toolpost burred over at the ends and some of the sockets were worn after 14 years of abuse with mixed metric and imperial allen keys.
I replaced them with cheap stainless ones from Screwfix which come with nicely finished ends that are much less likelty to burr. I also use these on my QCTP holders.
colin hawes20/09/2013 20:09:45
570 forum posts
18 photos
I have an old oilcooled Arcmobile welder which has a 200 amp tapping for brazing and case hardening using a carbon rod. I have only used the hardening facility on the ends of a push rod and got a good case but rough result. Stoning it produced a satisfactory finish. Colin
ega21/09/2013 09:45:48
2805 forum posts
219 photos
colin hawes:
Thanks for your post. What intrigued me about this method was that I had always understood that case hardening was a two-stage process - first introduce the carbon under heat then quench to complete. I seemed to get some kind of effect without quenching. Tubal Cain (WPS1) is very good on this subject and makes a good argument for choosing case hardening mild steel over through hardening silver steel, etc.
Stub Mandrel21/09/2013 10:14:48
4318 forum posts
291 photos
If you quench, you shopuld get a near glass-hard case. If yoiyu don'[t, but it cools quickly, you will just toughen the steel somewhat by turning the surface into an annealed high-carbon steel.
colin hawes21/09/2013 16:40:45
570 forum posts
18 photos
ega, It is some time since I used my welder's case hardening facility but i'm pretty sure I would have either quenched it quickly in water or reheated it with a propane torch and quenched it. Colin
