Chris Baetens | 18/09/2012 05:28:04 |
78 forum posts | Hi guys, Where do I get small honing tools. I was thinking of 3/4", and even smaller. I need these to finish stirling engine cilinders. Or maybe there's someone out there using homemade honing tools, and is willing to share his idea..? Thanks in advance Chris |
Versaboss | 19/09/2012 18:15:18 |
512 forum posts 77 photos | For such an application lapping is much easier than (real) honing. Small honing tools are available, but at a price driving water into your eyes!!! Google pemamo. A lapping tool can even made from hard wood, and Chinese diamond pastes are cheap. Greetings, Hansrudolf
Jens Eirik Skogstad | 19/09/2012 20:04:54 |
![]() 400 forum posts 22 photos | For precision lapping such as in model engine or similar, use rod or ring (in case lapping at rod to example) made of copper, brass or cast iron + lapping paste.
David Littlewood | 27/09/2012 23:10:13 |
533 forum posts | Chris, Go to **LINK** and download the Bruce Engineering catalogue. On about page 70 (the pages are not numbered) you will see a 1/2" to 1 1/4" cylinder hone for about £15. Have one, works fine. David
Edited By David Littlewood on 27/09/2012 23:10:59 |
Mike Wainwright | 28/09/2012 07:22:42 |
149 forum posts 8 photos | Chris They are on ebay as well for about £12.00 -£15.00
Phil P | 28/09/2012 09:17:42 |
851 forum posts 206 photos | Those three legged hones that Bruce and others sell are not true hones, they are what used to be called a "Glaze Buster". A true hone will bring a tapered or out of round hole back true again, the spring loaded type will not as they just follow the existing bore. I am not criticising the spring loaded type because they do have their uses, just pointing out that they are not a cheap alternative to a proper Delapena type hone. I agree with the other comments above, just make a split lap and do it that way. Very easy and very cheap. Phil |
JohnF | 28/09/2012 11:31:45 |
![]() 1243 forum posts 202 photos | Also consider a lead lap, easy to make by casting lead into a mould with a BMS rod to hold it--make a fair bit oversize then turn to size and "load" with lapping paste -- cuts like a dream and will produce a round parallel hole. You can also add a tapered pin to expand the lap as required. |
Ian S C | 28/09/2012 11:56:20 |
![]() 7468 forum posts 230 photos | I find a wooden lap is adiquate for my Stirling Engines, I put a cut down the center of it, an either use a little wooden wedge, or a wood screwin the end to expand the lap. When you finish the course grit, change to another bit of wood for the finer stuff, I sometimes go from brass polish to toothpaste to finish, just to get a mirror like surface. I must try the lead lap, got about 200Kg of lead, so that will go a long way. IanS C
Edited By Ian S C on 28/09/2012 11:59:48 |
wheeltapper | 28/09/2012 15:54:40 |
![]() 424 forum posts 98 photos | You been up on the church roof again Ian?
Roy |
