Shapers (obsolete or not)
Mexican jon24/07/2012 08:12:16
34 forum posts
5 photos
Just a curious question really questionIs there much point to having a shaper these days indecision I've got a Tom Senior universal mill with a slotting head attachment so my way of thinking is that a shaper would just take up space, that is unless someone can enlighten me.
Regards Jon
John Stevenson24/07/2012 08:26:31
5068 forum posts
Shapers are brilliant at holding a section of floor down until you can find a more useful machine.
John S.
Tel24/07/2012 08:54:20
157 forum posts
28 photos
Not at all! My Douglas gets almost as much use as either of the mills, and for some jobs is streets ahead of 'em.
KWIL24/07/2012 10:16:42
3681 forum posts
70 photos
The real question is, if you already have a decent mill is it worth spending any more money and why?
_Paul_24/07/2012 11:53:02
543 forum posts
31 photos
Posted by John Stevenson on 24/07/2012 08:26:31:
John S.
Do you still have one then John ?
cheeky
To answer the OP yes they are worth having and not just to stop the floor flying away cheeky
  • Cutting dovetails with lumps of cheap tool steel & not expensive dovetail cutters
  • Seeing how far you can make the chips fly down the workshop
  • Producing lovely flat surfaces using more lumps of cheap tooling
  • The theraputic aspect just watching the thing work implacably away
I am a little biased tho I have five in total so I guess my floor is safe cheeky
blush
Paul
KWIL24/07/2012 12:27:19
3681 forum posts
70 photos
I could buy an aweful lots of "expensive" dovetail cutters with one shaper and even more with fivedevil
Another JohnS24/07/2012 13:45:53
842 forum posts
56 photos
Not obsolete, but instead of picking up another shaper (had one but sold it when moving 1/2 way around the world) I got a CNC mill instead.
I'd love another shaper, but know that the mills will get the use.
I picked up a Worden cutter grinder to re-sharpen my end mills, and to accurately sharpen flycutter and lathe toolbits (for when carbide is not required)
So, in this case JohnS agrees with JohnS!
Another JohnS.
_Paul_24/07/2012 13:55:21
543 forum posts
31 photos
So if one isn't armed with the equipment & or ability to sharpen say for arguments sake a very expensive dovetail cutter what do you do with it? devil
David Clark 124/07/2012 14:22:48
3357 forum posts
112 photos
10 articles
Hi There
Sharpen it up freehand and use it as a shaper tool?
regards david
KWIL24/07/2012 14:40:07
3681 forum posts
70 photos
I know a nice small commercial outfit which will sharpen them as and when required for a very reasonable sum.smile
_Paul_24/07/2012 15:15:17
543 forum posts
31 photos
So assuming our hypothetical dovetail cutter hasn't any chipped teeth and is suitable to sharpen what might that cost for say a 1" 60 degree item including carriage to mainland UK?
smiley
KWIL24/07/2012 15:43:06
3681 forum posts
70 photos
Around £10 I would guess (now) + post, but then I usually drop them in along with other work and they are then sent back by post. New ones are £35
_Paul_24/07/2012 16:26:03
543 forum posts
31 photos
£10 does sound a very fair price for sharpening something with that many flights.
My cheapest (bought working) shaper is an Alba 1A cost me £70, include say £5 worth tool steel = £75
Your Dovetail cutter £35 and allow say around 2 sharpens? before it's done = £55
My math favours the Shaper
KWIL24/07/2012 16:46:54
3681 forum posts
70 photos
But I do not want a shaper in any shape or form, the workshop floor is concrete so that stays put on its own.
mick24/07/2012 16:57:02
421 forum posts
49 photos
On the 8th day the lord made the shaper and saw that it was good.
There is no finer machine to produce a completely flat surface and with a swan necked shearing tool taking off no more than 0.005'' it gets pretty close to surface grinding, with the advantage of staying completely flat when released from the vice, which is not always the case when the magnetic chuck is realeased!!!!
If anybody has a small bench shaper in need of a good home please let me know
_Paul_24/07/2012 22:27:31
543 forum posts
31 photos
I had almost forgotten about the floor surprise surely it's better to have a good weighty British Shaper holding it down rather than some lightweight import mill? cheeky
(Apologies to the OP for the hijack BTW)
OP
It's not all rosy in Shaper Land tho the old saying is "You can make anything on a Shaper except Money" it's probably true as setups certainly need more consideration and can be harder to achieve than the average mill if you see what I mean.
See if you can get someone to show you one working and perhaps even have a go yourself I am sure you will enjoy.
Paul
Steve Garnett24/07/2012 22:36:57
837 forum posts
27 photos
Posted by Mexican jon on 24/07/2012 08:12:16:
Good for oiling practice, for a start... and stress relief. And yeah, you can do most stuff on a mill and slotting attachment if you want - but having tried it both ways recently, I'd far rather cut dovetails on the shaper.
Nobby24/07/2012 22:54:11
587 forum posts
113 photos
Hi
I love my little Drummond hand shaper & I fit a grinding head on it for light grinding &Brilliant for slotting keyways in gears
Regards Nobby
drummond shaper
John Stevenson24/07/2012 23:01:05
5068 forum posts
Posted by KWIL on 24/07/2012 16:46:54:
Pray tell how you manage that ? Not seen my floor in 15 years.
Seriously everyone and his dog [ and next doors cat ] harps on about doing dovetails.
I have used shapers in industry and at home, had three over a period of time and never had need to do a dovetail on one in all that time.
It's only infernal dovetails anyway that's hard and needs a cutter, the external ones can be done on a horizontal mill with a 60 degree cutter usually in one pass and belt a big stick off at a time.
Owned a vertical slotter until a month or so ago then sold it on. Takes up too much floor space when a slotting head on the back of the bridgy wil do the same job and take up no extra room.
_Paul_25/07/2012 00:24:11
543 forum posts
31 photos
I recently made some "Aloris" type toolholders for the AXA toolpost on my old Boxford and had to do some "infernal" dovetails.
In fact nearly all the facets of these were cut on an Elloitt 10M.
Paul
