Circlip Pliers
The Merry Miller14/05/2012 16:13:43
484 forum posts
97 photos
Before I splash out on a decent set of circlip pliers I have a question.
I have a very large internal circlip to remove from a motorised gearbox.
The clip is about 2.5" dia and the two pin holes for removing the clip are about 0.1"dia on a pitch of 7/8".
Would the pliers in a standard set be capable of removing a clip this size or would I have to go for one of the larger sets?
Len. P.
Mike14/05/2012 16:53:32
713 forum posts
6 photos
I was faced with a similar problem a few years ago and, as it was a one-off job, didn't want to splash out on circlip pliers. Bought the cheapest pair of long-nosed pliers I could find in a DIY shed, heat bent the tips and filed them to the right profile, then re-hardened them. Worked a treat!
Weldsol14/05/2012 16:59:37
74 forum posts
You should be able to find wire forming pliers (the ones with round tapered jaws) these will probably do the job
Paul
The Merry Miller14/05/2012 17:31:53
484 forum posts
97 photos
Mike,
I've spent so much time in my life improvising tools that I thought I'd treat myself for a change as I'm now running out of time!!!
Come to think of it I am continually treating myself according to her indoors.
My grandson will no doubt feel happier no when he gets all of my proper tools eventually.
I don't think youngsters will know how to improvise until they have got a bit of time and experience under their belts.
Len. P.
Edited By The Merry Miller on 14/05/2012 17:35:00
Sandy Morton14/05/2012 17:33:12
104 forum posts
I have a pair of circlip pliers which I purchased from CPC for £1.99 and they work fine up to almost an inch. I never needed larger ones but they might be worth a look.
Clive Hartland14/05/2012 19:29:04
2929 forum posts
41 photos
It is possible to buy a set of circlip pliers that do both internal and external clips and they come with a set of different size pins.
These can be bought from motor tool factors, as you can guess they would be invaluable to a motor mechanic and any other engineer needing circlip pliers.
I think I got mine from Sealey's.
The Merry Miller14/05/2012 20:06:28
484 forum posts
97 photos
I've gone for the Sealey set Clive.
Len.
The Merry Miller14/05/2012 20:06:54
484 forum posts
97 photos
Don't know how it managed to double post?
Len.
Edited By The Merry Miller on 14/05/2012 20:07:52
Springbok15/05/2012 00:00:35
879 forum posts
34 photos
There are shedloads of both types going on fleabay for pennies.
Gordon W15/05/2012 09:40:41
2011 forum posts
On a clip that size I would use a small screwdriver or similar to start the key out of the groove and confirm that it is free. Usually can then "peel" the clip out without the pliers, should use a new clip anyway.
The Merry Miller15/05/2012 09:50:07
484 forum posts
97 photos
I tried to get it out that way Gordon, half successful due to very limited access and help from the missus!!
Len.
