Member postings for Weldsol
Here is a list of all the postings Weldsol has made in our forums. Click on a thread name to jump to the thread.
Thread: Sufrcae Prep of Aluminium
11/08/2013 09:55:56
Hi Roger talk to Orion alloys as they fairly near to you
Paul
Thread: Headstock raising block, How to make? (accurately)
05/08/2013 14:55:55
How about mounting the block so that where you want the vee is horizontal put your cutter in and cut a vee groove on one side then move the table across and put another vee groove on the opposite side.
So now you have your two grooves opposite one another ( both female ) mount a round bar of the appropriate dia, in one groove to become the male ( held in by socket head screws )
Maybe not what you were after but it would work
Paul
Thread: Feedscrews
26/07/2013 08:44:26
Hi Roger
For slides I use Moore international for ball screws and Marchant Dice for the bearings and rails and make the rest
As for control systems I use Siemens Logo units ( some machines I build I use the Siemens touch screen along with the Logo unit
For motor drives servo's with encoders I use Lojer units
Paul
Thread: Looking for engineers!
23/07/2013 10:00:39
Hi Roger I have sent you a PM
Paul
Thread: Looking for a supplier of 20mm and 25mm hardened and ground shafting
05/06/2013 09:06:16
You could try Marchant dice
I have used these in the past and have had good service from them (usual disclaimer)
Paul
Thread: Enquiry into functionality of NVR (No voltage release) switches for 3 phase and single phase machine tools
25/04/2013 14:56:25
I have used these units so I have start/stop and E stop
Paul
Thread: First firing - disaster
13/01/2013 12:50:12
I agree with Jason my Burrel took three firings before it settled down (especially if you put too much water treatnment in Ooops )
Paul
Thread: Quality R8 Drill Chuck Recommendarion
12/01/2013 20:52:31
Hi there I have used both keyed and keyless chucks on my bridgeport, at present am using a keyless from RDG tools.
For ease of use the keyless is excelent for gripping even a 25mm dia (turned down shank to 13mm) but if you want to use a tap in them then when you reverse turn the chuck will release. What I do now for tapping is to use a small centre in the chuck to line up with the tap holder to which I have put a centre hole in then tap by hand using the tap holder.
Paul
Thread: whats a suitable steel for turning and welding
10/11/2012 09:05:43
EN3B will give you a machineable / weldable steel
Paul
Thread: Arc Euro Trade Ltd. website update
19/09/2012 08:23:01
I went to buy some bearings on Monday morning and the amount box wouldn't let me go past 2 and I wanted 4
Tried changing this to 4 and updating but it kept reverting to 2 so I rang them, it seemed there was a glitch did the deed over the phone and they were delivered in less than 24hrs I was well impressed.
So if in doubt give them a call
Paul
Thread: What DRO to get?
27/08/2012 15:28:41
Hi Aidan I use a Machine Dro on my Harrison lathe , very easy to fit and use
On my Mill I have a Mitutoyo 2axis and on the quill I fitted a vertical vernier from Machine Dro
I never got round to doing the knee axis
Re contacting them I found I got a better resonse by phone
Paul
Thread: Ring making ideas
24/08/2012 12:15:36
You could find a local metal shop that have rollers and they could do them for you, most sheet metal rollers have grooves for wire / rod forming . Well at least mine do
Paul
Thread: Properties of "Key Steel"
05/07/2012 17:02:33
Hi Tom why not cut a short bit off the round bar heat it to cherry then quench if you can't touch it with a file it's very likely to be silver steel
Paul
Thread: plastics to seal high pressure
05/07/2012 11:48:22
Have a look at the Swagelok site I have used their fittings and valves for high pressure
swagelok.co.uk
Paul
Thread: R8
27/06/2012 16:35:27
Can't see any reason why not providing you have ER25 collet chuck with an R8 tail
Paul
Thread: Chuck for Rotary Table
20/06/2012 08:32:54
Hi Terry I would start with the 4 jaw as you can clock round stuff as well as holding odd shapes
The only draw back is the constant clocking, but then a lot of new 3 jaw chucks need the odd tweek
Paul
Thread: New "must see" technology
17/06/2012 12:30:58
Forget 3D and go fast forward to full hollgraphic projection then you won't need the glasses.
Got to ask the question: we used to make stuff using only 2D drawings now it seems everybody wants 3D drawings. Does it make the final product better or is it just a visual thing.
I think they call it progress
Paul
Thread: Bridgeport siting
21/05/2012 08:47:29
Hi David I have mine sited in a corner @45 deg,s which is great for normal use but you will always have a job turn up that that is too long ( hits the wall )
Paul
Thread: Almost engineering!
20/05/2012 10:46:02
Won't be long before they are available from China say at £50 a 100
Thread: Circlip Pliers
14/05/2012 16:59:37
You should be able to find wire forming pliers (the ones with round tapered jaws) these will probably do the job
Paul
