capnahab | 23/04/2012 20:58:15 |
194 forum posts 17 photos | I have scored a quick LA/KF knurling tool from the bay. http://www.brw.ch/shop/produkte/index.html here it is at enormous cost. I need some rollers. Can anyone direct me to the type for a bog standard diamond knurl. I may be doing titanium so I thought these http://www.brw.ch/shop/produkte/detail/index.html?t_ProduktNr=475240 not sure about the division or the version tho. Tips on how to use it would be good too. |
Ian S C | 24/04/2012 02:43:21 |
![]() 7468 forum posts 230 photos | Just been looking on google,quite a bit there, had a look through a catalogue, very interesting. The rolls are made from poweder metalurgical high speed steel, they require special bushes and side cheeks, and that tool of yours will knurl fron 1.5 to 12 mm dia, the pitches are; 0.3/ 0.4/ 0.5/ 0.6/ 0.8/ 1 mm. The rollers are 8.9 mm dia. Ian S C |
capnahab | 24/04/2012 06:42:43 |
194 forum posts 17 photos | Thanks Ian. yes, other than finding it needs a decent flow of coolant to wash the cut material away I am not sure how to use it. It seemed an attractive alternative to form knurling. it was a lot less than €880 !. I wonder if the bushes and side cheeks come with the rollers.
JasonB | 24/04/2012 07:25:34 |
![]() 25215 forum posts 3105 photos 1 articles | John Stevo on here has a couple of the quick tools worth contacting him. There was a thread about 2-3 weeks ago about a similar knurl bit of info there. http://www.model-engineer.co.uk/forums/postings.asp?th=67267 J Edited By JasonB on 24/04/2012 07:28:27 |
Terryd | 24/04/2012 08:23:27 |
![]() 1946 forum posts 179 photos | From your photograph the side cheeks and rollers appear to be there. The 'Knurl Rollers' on the site appear to be priced each (I presume you have clicked on to the English translation of the page) without any additional parts. BTW the prices are in Swiss Francs not Euros and as Switzerland is non EU, UK VAT would have to be added to the prices. So a pair of knurls from the manufacturer would be around £46 +VAT. T |
capnahab | 24/04/2012 08:56:42 |
194 forum posts 17 photos | So , in laymens terms the pitch is going to determine how far apart the high points of the knurl are ?. What about the angle ?, - they seem to be 90 degrees or 15 or 30 left and right. Is this something to do with the set up angle on the lathe ?. If so , how will it affect the knurl ?.
Ian S C | 24/04/2012 12:02:07 |
![]() 7468 forum posts 230 photos | The angles are 15* L&R, one of each required, or straight two required. Ian S C |
capnahab | 25/11/2012 19:52:54 |
194 forum posts 17 photos | At last I have sourced the knurling wheels. In putting them on I have upset the (very complicated) set up for adjusting the wheels. the instructions for use are here http://industrieprodukte.swarovskioptik.com/en/gb2_infos-news-information But there are no isntructions for setting it up. I have two problems , the screw in the side of the main body (arrowed) is stuck and has a narrow shallow slot.
once I get it out I am not sure how to reassemble it so the rotating the adjuster nut works with the cams on the knurling wheel sleeve. |
AndyB | 25/11/2012 20:40:32 |
![]() 167 forum posts 7 photos | Hi, As Switzerland is not in the EU there is no VAT but you will have to pay import duty which is usually sorted out by the courier and you once it arrives in the UK. Royal Mail has a very good online system for payments when I have stuff come from the USA. Andy |
Versaboss | 25/11/2012 23:31:36 |
512 forum posts 77 photos | Capnahab, if you need a setup description you can find one here for the similar Ifanger tool. A bit fiddly with the size of the tool I have; maybe yours is somewhat bigger. Greetings, Hansrudolf
John Stevenson | 26/11/2012 00:31:11 |
![]() 5068 forum posts 3 photos | Why did you strip it ? The wheels just fit on the ends of the axles.
It's a bitch of a job to get these back together and timed up, as you feed the worm shaft in it rotated the axles so you have to set them 5 teeth advanced to start with. |
capnahab | 26/11/2012 16:02:51 |
Thanks John , I know I didn't purposefully strip it , - the adjustment was jammed . |
