Plain bearings in orbit
Looking for the term to describe a noisy bearing
Sam Stones04/04/2012 00:06:21
922 forum posts
332 photos
Gentlemen,
What is the term usually used to describe the condition when a shaft begins to whirl or orbit (instead of sliding smoothly), inside a plain bearing?
It’s a noisy condition which is often cured with just a drop of oil, or a new bearing with a better fit.
Sam
Springbok04/04/2012 02:11:02
879 forum posts
34 photos
Shafted...!!
Doddy04/04/2012 09:24:50
72 forum posts
103 photos
Eccentricity may manifest itself as shaft to bore mis alignment (STBM) and/or dynamic run out (DRO).
Even with a good oil supply, high speed turbine shafts can suffer "oil whirl" leading to major vibration issues
Eccentricity and dynamic run out a usually due to mis alignment, more a "sloppy fit" in this case
Ian S C04/04/2012 12:35:53
7468 forum posts
230 photos
The term here would be "Munted", which is another way of saying "stuffed". Ian S C
Nicholas Farr04/04/2012 20:36:26
3988 forum posts
1799 photos
Hi Sam, maybe it could be termed as Axial Oscillation.
Regards Nick.
blowlamp04/04/2012 21:16:08
1885 forum posts
111 photos
Could be Oil Whip, Whirl or Bearing Flutter.
Martin.
Bazyle05/04/2012 01:10:17
6956 forum posts
229 photos
The correct term is "Precession". A secondary definition to the more common association with gyroscopes and planets.
Stub Mandrel05/04/2012 22:03:02
4318 forum posts
291 photos
In my workshop I call that a 'precision running fit'
Ian S C06/04/2012 08:43:05
7468 forum posts
230 photos
Sounds like the big end on some of my hot air engines, I just call it free running, sometimes it does get a bit extreme, one did get to .020" on a 1/4" crank, Brass bush very little wear, unknown grade steel pin took all the wear. Ian S C
