Jen Cirencester | 13/03/2012 10:18:23 |
5 forum posts | I am brand new to this forum in the hope of being able to find someone localish to Cirencester, Gloucestershire who would be up for machining some aluminium This is to make a lance for use on horse back, but requires a tapering end for the lance head and probably a slight taper to fit the end section and finally a screw joint so the 2.2m lance can fit in a normal car!
Apologies if this is totally the wrong place!! Edited By Jen Cirencester on 13/03/2012 10:22:46 |
Springbok | 13/03/2012 12:23:03 |
![]() 879 forum posts 34 photos | Hi Are you into some historic enactment society
Ady1 | 13/03/2012 13:01:16 |
![]() 6137 forum posts 893 photos | I would use wood or bamboo Seven feet of ali will bend easily, and look pretty silly after you've tried to straighten it up.
Bamboo may have the best combination of lightness and strength. It's tough stuff Remember those fishing nets we used as kids to catch minnows? |
Jen Cirencester | 13/03/2012 14:28:27 |
5 forum posts |
This is for modern tentpegging, rather than dressing up The aluminium solution is a lot easier to organise than carbon fibre (tried a net pole, but too much flex, currently also have a bespoke rod maker on the case). Australians have been using this with 1" tube with no bending !
Jen Cirencester | 13/03/2012 14:34:56 |
5 forum posts |
To add I have a bamboo lance, however the problem is if you don't have a 4x4 you try fitting a 2.2m+ lance in your car (usually 7ft 6" Below is a bamboo nail head lance on the left and my carbon fibre net pole lance on the right witha 1868 lance head Sadly my nail head lance is now slightly bent following training at the weeekend!
Edited By Jen Cirencester on 13/03/2012 14:36:50 Edited By Jen Cirencester on 13/03/2012 14:37:28 |
Peter Hall | 13/03/2012 15:47:18 |
115 forum posts 1 photos | Blimey!
You'll have someone's eye out with that. |
Ady1 | 13/03/2012 16:07:52 |
![]() 6137 forum posts 893 photos | Dont forget you can put a ferrule on a bamboo pole too, just like with a fishing rod.
gl |
Deltic007 | 13/03/2012 20:39:25 |
![]() 131 forum posts 12 photos | Bloomin eck do you have to have a licence for that sort of equipment?
Mike |
Wolfie | 13/03/2012 21:22:49 |
![]() 502 forum posts |
Thats a hell of a tent-peg Edited By Wolfie on 13/03/2012 21:23:50 |
Jon | 13/03/2012 21:28:19 |
1001 forum posts 49 photos | Shame Jen was within spitting distance Saturday of you.
Nice easy job what diameter we talking about 22mm (7/8"
Springbok | 14/03/2012 00:57:33 |
![]() 879 forum posts 34 photos | I live near you but would not be willing to manufacture a weapon like this it looks lethal if something happened it would be "Oy guv where did you get that weapon"
Bob |
Mike | 14/03/2012 09:09:09 |
![]() 713 forum posts 6 photos | I think Jen takes part in a much misunderstood sport. Go to http://britishtentpegging.com/ for the facts. |
Jen Cirencester | 14/03/2012 10:07:30 |
5 forum posts |
Thanks for the responses! Although still no offers yet I am going to talk to a local engineering firm this week and see if they will do it
Deltic007 - no licence required, if you wanted to do damage to others, I assure you a car would be more effective!! Here's me in action with sword (I'm the fat one!)
Bazyle | 14/03/2012 10:11:24 |
![]() 6956 forum posts 229 photos | You could make the joint out of brass drain rod joints and epoxy them into tube from B&Q. My rod joints seem to be 20mm dia. You will probably find someone at a car boot selling some damaged ones as the current cheap sets use such thin plastic for the rod that they are next to useless for their intended purpose. If you can find an old bamboo set even better. |
Jen Cirencester | 14/03/2012 10:35:14 |
5 forum posts | I'm not sure bamboo will tolerate having joints in it though? I am going to India next week, so hoping to bring back some more bamboo lances depending on how much weight allowance I have left! Also one of the Glos pegging crew also has bamboo growing in the UK, but it's taking a while to dry it out properly. This also needs to be worked on a lathe to take out the knobbles! |
Mike | 14/03/2012 10:51:28 |
![]() 713 forum posts 6 photos | I am old enough to remember building bamboo fishing rods, and I seem to remember the strongest, hardest bamboo canes were called Tonkin poles, from China. Push-in ferrules were always the weak point, and also had the annoying habit of sticking. Can't remember how many times I came home with a long length of fishing rod poking out of the window of my dad's car. I think a screw thread would be far superior. |
Craig WRENN | 14/03/2012 22:05:33 |
1 forum posts | Now that looks fun. Fantastic skill to do that but I can't see Panda the fat cob I ride allowing me to try anything like that while in the saddle.
Good luck
Craig |
