Spin machine
How to build a Spin Machine
Denise Connie25/02/2012 08:17:35
10 forum posts
Forgive the intrusion but after trawling the internet for answers I came across this sight full of very knowledgeable people and thought this would be the best place to get advice!
My problem is i want to make a spin art machine for my Art project similar to the ones they made in 1960 and copied by other artists since, I have tried using a strimmer engine and a home fan, the strimmer burnt out and the fan was not strong enough.
I need a machine that is speed adjustable and can also reverse, it also needs to be able to take some sort of plywood circular base (was thinking of two different sizes for smaller 20" canvases and a larger one) which I can attach a large canvas/ses measuring up to 5ft.
I would be grateful for any advice given.
Denise
JasonB25/02/2012 08:29:33
I think its usually done with the work horizontal, think of pouring paint onto a record turntable but at higher speed.
J
Denise Connie25/02/2012 09:18:10
10 forum posts
Something I can adapt or maybe a motor of sorts I can can get off ebay. Horizontal, speeds around 900- 1400 rpm maybe but adjustable and reverse if poss. I have seen the potters wheel version which is a good base speed but i'd lke it faster! so something along those lines would be great.
Les Jones 125/02/2012 09:30:56
2292 forum posts
159 photos
Hi,
I would have doubts about the safety of rotating a 5 ft diameter plywood disk at 900 to 1400 rpm.
Les.
Bazyle25/02/2012 09:33:06
6956 forum posts
229 photos
The inertia during start up is a problem and what burnt out your strimmer.
Is it the machine or its product that is the project? You could improvise something in an hour if it was to be disposed of afterwards. Also what is your budget?
One problem is to attach a ply plate to an axle. If you look in the back of a scrap washing machine you will find many of them have a short axle welded into a 3 branch 'birds foot' to attach to the drum. Another possibility is the base of an office swivle chair. Then just hammer a tube into the ground, insert axle and spin by hand.
If you want to go up market, ie pay money, look for a wood lathe like a Record Coronet on ebay which have a detachable head on a tube base. They have several speeds and tough bearings and a 'faceplate' for the plywood. You know where I'm going next....hammer a bigger tube into the ground....
Edited By Bazyle on 25/02/2012 09:34:45
Denise Connie25/02/2012 10:17:18
10 forum posts
Hi, @ Les, the plywood only needs to be big enough to secure the middle bar sections of the canvas to, it doesn't need to be 5ft
http://makeprojects.com/Project/Giant-Spin-Art/482/1
the above is where I the main idea from.
@Bazyle the lathe sounds a good idea does "record coronet" refer to a make of lathe or type? I would like to have control over the speed but think I would build some sort of base for it to sit in as I would like to use it again ).
alan knight25/02/2012 14:10:48
39 forum posts
Record is the manufacturer, Coronet was the model, the speed is adjustable by means of drive belts and pullys in the headstock. I still think that would need a helping hand to spin a 5' dia of ply, the speeds your thinking of really you would need a base made up in a x formation with a rollerbearing ring supporting the ply then a proper hub in the center made up, really that all wants fabricating and then personally I would just stick a 2hp motor with a variable speed contorol in the center. As the momentum built up in spinning a 5' disk at close to 1000rpm would be immense, just expecting it to hover there supported by the headsock bearings of a woodturners lathe is frankly pie in the sky. Do you really need the speeds that high or the area that large? and could you repurpose it afterwards. If you could find a buyer after it may be worth investing. But I wouldent go about things in a half assed manner as 5' of 3/4" ply at 1000rpm could easly break someone leg is not worse and getting it up to 1400rpm is even more precarious as you would really need a machine built to do so, again with a frame and a roller support ring and a central mounting hub and some form of gear box as by my simple calculation if your motor has 1" drive shaft and your board has a 60" diameter then you are getting a 60:1 reduction in face speed based of a 2800rpm motor your board would only be achieveing 46 rpm. So based on that logic you would need a gear box able to convert a 2800rpm spindle speed up by a ratio of 1:21.4 which would lead to a shaft speed of 60000rpm for an inch shaft on the hub base. Leading to a face speed of 1000rpm on your board.
Denise Connie25/02/2012 15:39:40
10 forum posts
@ alan Knight, yes I think your right, a 5ftcanvas is a bit of a dream, maybe 3 ft max would be better. I've tried the drill method on a 3 x 2 ft canvas and that died so i'm looking for something better and don't mind paying for 2nd hand motor, i'm looking at spending upto £100-£150 for something thats going to work for the purpose.
Roderick Jenkins25/02/2012 15:54:30
2376 forum posts
800 photos
Denise,
Just to put it into perspective, at 1400rpm the perifery of a 5' diameter disc will be doing around 250mph. As Alan suggests, you might want to re-think your requirements. A plywood dsc would probably burst at the sort of centrifugal force generated at these speeds. I'd be inclined to stick to the battery drill in your example. You can start the disc spinning by hand which will help overcome the starting inertia.
Cheers,
Rod
alan knight25/02/2012 16:13:27
39 forum posts
Iv yet to find a drill that would handle that kind of abuse, you could get an electric motor off ebay for around £150 that will do 2800 rpm and spin 3' of ply till the cows come home, a slower running 1450rpm even more so. Just a simple collar boss needed to rig board to motor. Then some sort of stand to mount motor to floor. Thats the way i would go.
JasonB25/02/2012 17:03:43
Michael, Some of those alternatives you suggest won't work as the "spin" is used to get the paint to flow outwards by centrifugal force.
A quick google turns up lots of small versions for kids, maybe just get one of those and mount a bigger board to it.
I quite like this bicycle driven version, there is some substantial gearing up going on there
J
Edited By JasonB on 25/02/2012 17:04:34
Denise Connie25/02/2012 17:08:25
10 forum posts
If I was to purchase this http://www.ebay.co.uk/itm/Clarke-Woodworker-20-wood-lathe-chisels-/160741657291?pt=UK_Crafts_Other_Crafts_EH&hash=item256cf30acb would I be able to adapt it.
alan knight25/02/2012 17:57:10
39 forum posts
No as that lathe is tiny and you would get more horse power out of a shrew.
Ian S C26/02/2012 01:26:27
7468 forum posts
230 photos
One place to get a suitable hub could be an auto wreckers yard,look for a front axle and hub assembly, a bit of imagination, and engineering would give a strong base to start from. Ian S C
Denise Connie26/02/2012 08:14:17
10 forum posts
@MikeW, I love the idea of the Harmonograph and CNC but the CNC would be a bit of a challenge, how would I go about making something that would hold paint.
@AlanKnight, I will look for another motor as you suggested and forget the shrew!
I'm off to work now so please don't think i'm ignoring your responses, looking forward to reading them when I get home.
Denise
David Clark 126/02/2012 14:07:55
3357 forum posts
112 photos
10 articles
Hi There
Why not use a vertically mounted airbrush.
You could use one with the add on pot on the side and turn it to suit.
regards David
You could probably control the airbrush trigger as well.
David Clark 126/02/2012 14:39:38
3357 forum posts
112 photos
10 articles
Hi There
I think you are looking at this backwards.
A 5 foot diameter canvas spinning fast is stupid.
You need a spinning arm with an airbrush mounted on it that can move in and out as the arm spins.
This would only be a 2 foot 6 inch radius, easily possible even if you had to use some sort of on board (on arm) controller or remote wireless controller.
regards David
regards David
Ian P26/02/2012 16:01:41
2747 forum posts
123 photos
David
The whole point of the project is to rotate the job!
If the canvas was stationary centrifugal force would be absent so Denise would not be able to create her artwork.
Ian P
Edited By Ian Phillips on 26/02/2012 16:08:12
Denise Connie26/02/2012 18:27:07
10 forum posts
Thank you so much for your help and advice so far, this isn't as easy as I thought Im more of a girlie than I thought! I'm so glad I asked for your help. Im going to take it step by step so first can I have your opinions of the motor only picking the right one is not as easy as it sounds
Are any of these motors any good?
Myford
3 phase
Single phase
Edited By David Clark 1 on 27/02/2012 00:13:57
Ian P26/02/2012 18:52:59
2747 forum posts
123 photos
Denise
All those motors are OK but...
The thing you are building will change and develop as you proceed, if you have a largish revolving disk of some sort then whatever else it needs it must almost certainly have some means of accellerating from a standing start. The motors in your links are all single phase and get up to running speed VERY quickly.
My suggestion would be to definately use some sort of speed controlled motor, probably a 3 phase motor with a VFD (Variable Frequency Drive). With a lightly loaded motor it will probably run slower than 100RPM (just a guess) but more importantly you can set parameters to limit the accelleration, so for example you can set it to take say, 30 seconds to get up to speed from switch on. Stopping time too is controllable.
If you have a variable speed motor then it might give you some artistic scope to get different effects, for example on one canvas you could apply paint (and whatever else!) at both high and low speed. If the unit you build is structurally robust then you might see some useful effect from applying paint whilst actually accellerating or braking.
Ian P
