Member postings for Denise Connie
Here is a list of all the postings Denise Connie has made in our forums. Click on a thread name to jump to the thread.
Thread: Spin machine
27/02/2012 22:29:38
Hi Ian, I've been offered a mechanical variator with a speed from 200-1000 for £200+vat, which I cannot afford, so buying a motor and drive seperate would be the only possible answer for me. I can get measurement and weights of the canvases but the rotating parts would have to be a guess until I have them.
26/02/2012 20:05:42
@Wolfie, can I get a variable speed motor to run off household electric?
@ Les thank you but that looks too technical for me.
@Ian P, you have read my mind as regards to the art effect i'm after!
26/02/2012 19:33:07
@wolfie thats right, the disc does not have to be 5ft but then a 5ft canvas seems dreams away now, I never even thought of finding a group nearby!
26/02/2012 18:27:07
Thank you so much for your help and advice so far, this isn't as easy as I thought Im more of a girlie than I thought! I'm so glad I asked for your help. Im going to take it step by step so first can I have your opinions of the motor only picking the right one is not as easy as it sounds
Are any of these motors any good?
Myford
3 phase
Single phase
Edited By David Clark 1 on 27/02/2012 00:13:57
26/02/2012 08:14:17
@MikeW, I love the idea of the Harmonograph and CNC but the CNC would be a bit of a challenge, how would I go about making something that would hold paint.
@AlanKnight, I will look for another motor as you suggested and forget the shrew!
I'm off to work now so please don't think i'm ignoring your responses, looking forward to reading them when I get home.
Denise
25/02/2012 17:08:25
If I was to purchase this http://www.ebay.co.uk/itm/Clarke-Woodworker-20-wood-lathe-chisels-/160741657291?pt=UK_Crafts_Other_Crafts_EH&hash=item256cf30acb would I be able to adapt it.
25/02/2012 15:39:40
@ alan Knight, yes I think your right, a 5ftcanvas is a bit of a dream, maybe 3 ft max would be better. I've tried the drill method on a 3 x 2 ft canvas and that died so i'm looking for something better and don't mind paying for 2nd hand motor, i'm looking at spending upto £100-£150 for something thats going to work for the purpose.
25/02/2012 10:17:18
Hi, @ Les, the plywood only needs to be big enough to secure the middle bar sections of the canvas to, it doesn't need to be 5ft
http://makeprojects.com/Project/Giant-Spin-Art/482/1
the above is where I the main idea from.
@Bazyle the lathe sounds a good idea does "record coronet" refer to a make of lathe or type? I would like to have control over the speed but think I would build some sort of base for it to sit in as I would like to use it again ).
25/02/2012 09:18:10
Something I can adapt or maybe a motor of sorts I can can get off ebay. Horizontal, speeds around 900- 1400 rpm maybe but adjustable and reverse if poss. I have seen the potters wheel version which is a good base speed but i'd lke it faster! so something along those lines would be great.
25/02/2012 08:17:35
Forgive the intrusion but after trawling the internet for answers I came across this sight full of very knowledgeable people and thought this would be the best place to get advice!
My problem is i want to make a spin art machine for my Art project similar to the ones they made in 1960 and copied by other artists since, I have tried using a strimmer engine and a home fan, the strimmer burnt out and the fan was not strong enough.
I need a machine that is speed adjustable and can also reverse, it also needs to be able to take some sort of plywood circular base (was thinking of two different sizes for smaller 20" canvases and a larger one) which I can attach a large canvas/ses measuring up to 5ft.
I would be grateful for any advice given.
Denise
