Martin Walsh 1 | 24/02/2012 19:31:18 |
113 forum posts 2 photos | Hello I have just aquired a ellliot 10m shaper. some of the machined surfaces are a bit rusty just a bit of surface rust. what is the best way of removing it Thanks in advance Martin |
AndyB | 24/02/2012 19:45:11 |
![]() 167 forum posts 7 photos | Hi Martin, I use parafin or kerosene with nylon kitchen scourers for flat surfaces and washing up brushes/toothbrushes for slots etc. Cheap as chips and plentiful supply (especially if you are married to my wife! Haha) I have cleaned up several rusty machines like that. Elbow grease with soft materials does not wear away vital metal!
Andy |
Stub Mandrel | 24/02/2012 20:25:55 |
![]() 4318 forum posts 291 photos 1 articles | Very weak acid, such as citric, vinegar or 'value' coca cola. Neil |
mgnbuk | 24/02/2012 20:38:19 |
1394 forum posts 103 photos | ScotchBrite or Fibral non-woven abrasive pads & elbow grease ! There are also phosphoric acid based "metal brightner" products that remove tarnish from machined surfaces.
Nigel B. |
James B | 24/02/2012 22:46:03 |
![]() 101 forum posts 14 photos | Hi Martin, Congratulations on getting your shaper - I have one, lovely machine. If you need a manual for I have a PDF version - if would like a copy, send me a PM with your email address. James |
David Littlewood | 24/02/2012 22:52:07 |
533 forum posts | Martin, When you have removed the rust as suggested above, I recommend that you wipe the surfaces with a rust inhibiting oil. I use Shell Ensis, and have had no rust on my machine surfaces in over 25 years. David |
Martin Walsh 1 | 24/02/2012 23:20:32 |
Posted by James Burden on 24/02/2012 22:46:03:
Hi Martin, Congratulations on getting your shaper - I have one, lovely machine. If you need a manual for I have a PDF version - if would like a copy, send me a PM with your email address. James Hello James I oiled it and had it runnig tonight really pleased I was really lucky because the person I bought it from only lived a short distance away and had a lorry and all the proper lifting gear so didnt have to dismantle the machine. It is in very good cond it has a 3 phase motor but I managed to get it running by connecting a capacitor across the third phase but I will get a coverter thanks for the offer for the pdf manual but I managed to download it from another site. All the Best Martin
Martin Walsh 1 | 24/02/2012 23:26:28 |
113 forum posts 2 photos | Thanks for all the info I will get some scotch brite pads tomorrow and some paraffin Best Wishes Martin |
James B | 24/02/2012 23:30:36 |
Hi Martin, Just in case it might save you some time or effort - mine is 3 phase also, and I was considering swapping the motor for a single phase unit on mine as it looked like a simple swap - however I found out that the original motor is a 6 pole (900 RPM) motor, so the normal 1400 RPM motors are too fast, so I went the phase converter route for mine. Good luck! James |
David Clark 1 | 10/07/2012 20:02:15 |
![]() 3357 forum posts 112 photos 10 articles | This post was by Ian Bartlett 1 and was accidentally deleted. Martin, In case it's a bit more than "a bit of surface rust", try using a steel paint scraper. I have one with the sharp corners rounded off, it's a cheap plastic handle that holds a Stanley knife blade. Slap some old engine oil on the surface to clean (it keeps the dust at bay), start with the scraper too shallow and slowly increase the angle, fair amount of pressure on the blade. You'll find a sweet spot, where the rust suddenly just planes off, without the scraper digging in. Then, a quick rub with Scotchbrite / fine emery etc will finish the job. Here are some pics of an old Wadkin planer undergoing that treatment: Ian |
Cyril Bonnett | 23/07/2012 23:22:27 |
250 forum posts 1 photos |
This works |
_Paul_ | 24/07/2012 00:45:41 |
![]() 543 forum posts 31 photos | Cyril I see from your link Frank uses Baking Soda (Sodium Bicarbonate?) I use Sodium Carbonate (washing soda) with the same effect, I wonder which works faster?
russell | 24/07/2012 05:40:57 |
142 forum posts | neither... electrolytic cleaning is more or less a 'reverse electroplate' process - the soda or whatever is just to make the water conductive. I use Sodium Hydroxide, (caustic soda) on the basis that that was at the front of the shelf. I convinced myself that it would also act to remove any grease/oil on the surface, but at 2 teaspoons to a barrel i doubt it would have any effect anyway.
regards
russell |
Ian S C | 24/07/2012 11:00:36 |
![]() 7468 forum posts 230 photos | When started using electrolitic rust removal, I used Caustic Soda, But soon changed to washing soda for safty reasons. The caustic I suppose is OK for removing paint, although washing soda does that enough for me. Ian S C |
