Skarven | 27/11/2011 08:09:27 |
![]() 93 forum posts 11 photos | Hi, I have a slitting saw 125x27x2 72T and I feel that for cutting purposes, it could be thinner. At 600 rpm and lots of oil it cuts 25mm aluminum beautifully, with an almost polished surface. The sound though is frightening, with hearing protection, even in the next room a must. Is there an optimum thickness for slitting saws? At CTC Tools they sell the 125mm with thickness from 0.8mm to 6mm. |
JasonB | 27/11/2011 08:25:59 |
![]() 25215 forum posts 3105 photos 1 articles | I think its more the optimum speed thats your problem, sounds too fast to me, I usually use 3" to 4" ones at about 200rpm.
J |
Skarven | 27/11/2011 08:44:41 |
![]() 93 forum posts 11 photos | I tried 75, 180 and 280, but they all gave a lot of vibration. This might be a resonance problem. I have ordered two VFD's, one for my lathe, and one for the mill, mostly because I want to make lower speeds possible, but maybe they can be used to tune away some vibrations? Is there a problem with a thickness of only 0.8mm? Will it break easily? |
Hugh Gilhespie | 27/11/2011 09:45:12 |
130 forum posts 45 photos | Hi Skarven
This link has some useful information on slitting saws on page 13.
Regards, Hugh |
Andrew Johnston | 27/11/2011 13:06:47 |
![]() 7061 forum posts 719 photos | The problem is unlikely to be resonance, as it occurs at a series of unrelated frequencies. Running at 600rpm is prehaps a little fast for aluminium; 400rpm may be better. There is no way the slitting saw should be making the kind of noise you describe. I suspect the problem may be too low a feedrate. What feedrate are you using? Best Regards, Andrew |
JasonB | 27/11/2011 13:20:31 |
![]() 25215 forum posts 3105 photos 1 articles | The VFD will help, I find that if I'm doing something that starts to resonate then slightly modulating (fancy name for turning up and down) the speed knob you can stop it before it gets too bad.
Nothing wrong with using a thinner cutter but there is a slight risk of them going astray.
I have heard of people using TCT saw blades made for cordless circular saws to cut alloy on the mill, the advantage of the tips is there is more clearance behind and they had quite a narrow kerf about 1.4mm.
J |
Skarven | 27/11/2011 14:50:52 |
![]() 93 forum posts 11 photos | Hi, Thanks for the link Hugh, There was a lot of info there. Martindale gives a rpm of 950 for a 4" saw in aluminum, this should be app. 760 for a 5" saw. Andrew, I think You are right. The feed was very slow. In fact it was as slow as I could get it, about 0.5mm/s or 30mm/minute. This is 30mm / (72x600) = 0.0007 mm/tooth. Martindale recommends 0.0002" - 0.002 per tooth or 0.005 - 0.05mm / tooth. I will try a few more cuts with a higher feed rate and report back the result.. I hope my saw has survived the 400mm cut 25mm thickness at snail pace ![]() JasonB, I have also noticed that sometimes both decreasing and increasing the speed will avoid chatter, so I look forward to test the VFD's on both the mill and the lathe. |
Steve Withnell | 27/11/2011 16:51:18 |
![]() 858 forum posts 215 photos | I'm not an expert on using slitting saws but...I've not used a saw above 100m x 1.5mm and would run below 400rpm. Also I only take light cuts, on a 3 inch saw with 60ish teeth I've been doing 0.5mm per pass in aluminium and just keeping up the feed rate so the saw is always cutting. I use parafin as a cutting fluid to stop the ally sticking to the teeth. It all starts getting unhappy when I get beyond a 1mm deep cut and I'm 10mm or more into the workpiece. I also cut by pushing the work into the oncoming tooth, rather than pushing into the going away tooth, if that makes sense. (a la climb milling)
I use slitting saws only where I need a precision slot (say making collets, or a new butterfly bar for a carburettor), or maybe to part a component cleanly into two (eccentric straps for steam engines). Everything else is a hacksaw (or angle grinder with a thin cutting disc) as I don't have a bandsaw.
I also don't think you need loads of tech to get a slitting saw to work well. I only have a limited number of speed choices on my round column chinese mill, but it's perfectly adequate.
Steve Withnell | 27/11/2011 16:51:20 |
Skarven | 27/11/2011 17:15:31 |
![]() 93 forum posts 11 photos | Higher feed rate did the trick. 125x2x27 72T, 600 rpm and a feed-rate of 4mm/s or 240mm / minute. No vibration, almost no sound, just a healthy sawing one. I had my fingers on all three stop buttons while cutting ![]() |
Skarven | 27/11/2011 19:04:15 |
![]() 93 forum posts 11 photos | Finnished cutting of dove-tailed blocks for BXA QCTP. Each cut was about 10 seconds, although the setting up took much longer! |
Stub Mandrel | 27/11/2011 20:40:56 |
![]() 4318 forum posts 291 photos 1 articles | What grade of alloy are you using Skarven? I want to make a QCTP one day and chopping up alloy seems much more appealing than working through a few feet of mild steel. Neil |
Skarven | 28/11/2011 06:21:56 |
![]() 93 forum posts 11 photos | Hi Neil, I have 3 plates 370mm square and 25.4mm (1") thick. They are marked "ALLA PLUS PLATE" and "P1115". From what I can find out, the 1115 means that it is essentially pure aluminum. This is what I had from the scrapyard, so that's why I'm using it. If you make holders for AXA or BXA, the dimension for the dovetail is very critical. Even a cut of 0.02mm makes a real difference to the fit. |
ady | 28/11/2011 07:14:16 |
612 forum posts 50 photos | I've found that cutting discs are far less scary than slitting saws. Stiffness for the disc and the work, a decent speed and a careful feed rate seem to be pretty essential to a decent job. Heat can be a major issue, especially aluminium, because the slitting saw gap can close as the aluminium heats up. There are various sources for cutting discs. Edited By ady on 28/11/2011 07:17:31 |
Ian S C | 28/11/2011 09:34:57 |
![]() 7468 forum posts 230 photos | I find the best aluminium alloy to work with in places where strength is required, and ease of working is 7075 T651 tooling plate, the place I get it from say in their ads that its "strong as steel", also the sell scrap bit at a reasonable price, its definitly harder, and srtonger than ordenary extruded bar. Ian S C |
John Stevenson | 28/11/2011 09:40:03 |
![]() 5068 forum posts 3 photos | Posted by ady on 28/11/2011 07:14:16: I've found that cutting discs are far less scary than slitting saws. Stiffness for the disc and the work, a decent speed and a careful feed rate seem to be pretty essential to a decent job. Heat can be a major issue, especially aluminium, because the slitting saw gap can close as the aluminium heats up. There are various sources for cutting discs. Edited By ady on 28/11/2011 07:17:31 Care to link to what cutting disks are suitable for aluminium ? John S. |
Gordon W | 28/11/2011 10:17:32 |
2011 forum posts | I've found that stone cutting discs work better on ally, and on copper. Found out by accident when cutting up scrap. Please note I am not recommending this! just mentioned it. |
ady | 28/11/2011 13:00:50 |
612 forum posts 50 photos | Care to link to what cutting disks are suitable for aluminium ? Sorry. I just use what I've got. No names to name. Fleabay specials, extra thin, can be used on stainless. You've GOT to mount stuff properly, both the cutting disc and the workpiece. Those hand held things are a dangerous joke. Edited By ady on 28/11/2011 13:05:48 |
Billy Mills | 28/11/2011 13:20:41 |
377 forum posts | Ady , you might like to read this:-Grinding Aluminium. As far as I know most workshops go the same way as MIT and ban aluminium grinding- too many accidents.
With a very thin cutting disk you can still get the melt-stick-shatter process which does not help at all.
Billy.
John Stevenson | 28/11/2011 13:48:53 |
![]() 5068 forum posts 3 photos | From the bit of experience I have had with grinding aluminium you might as well use a hatchet, the finish and accuracy is far better. John S. |
