Gary Brooke | 08/11/2011 16:00:53 |
28 forum posts | Hi all it's me again they just get worse. After a good day in the workshop.(shed)I was tidying up when dropped my square on the floor. The question is there any way test if it's still square . Regards Gary |
Terryd | 08/11/2011 16:11:34 |
![]() 1946 forum posts 179 photos | Hi Gary, Get a piece of material, preferably steel plate or the finished side of an angle plate etc., with a good straight edge on one side. Use your square to draw a line using the straight edge, flip the square over and check your square against the original line you drew. Regards Terry |
Nobby | 08/11/2011 18:19:55 |
![]() 587 forum posts 113 photos | Hi Gary Have you or do you know anybody who as a hardened & ground bottle square ? . what size is it ? 2 questions sorry Terrys idea is good We learn something new every day Nobby |
JasonB | 08/11/2011 18:42:44 |
![]() 25215 forum posts 3105 photos 1 articles | I've always been taught and used Terry's method quick & easy particularly on larger squares.
Nobby I've not heard of a Bottle square is that what I know as a cylindrical square - length of ground tube with accurately ground ends. Though if you also know someone with a square that has not been dropped that should be OK to check against.
J Edited By JasonB on 08/11/2011 18:43:59 |
Gary Brooke | 08/11/2011 19:50:26 |
28 forum posts | Thanks once again you steer me in the right direction. Using Terry's method everything seems ok.shame the learning curve is not that easy. Regards Gary |
Stub Mandrel | 08/11/2011 20:03:43 |
![]() 4318 forum posts 291 photos 1 articles | Glad the squares's OK. How's your foot? Seriously, I have a very old patent square, which looks wonderfully well made. It's about 88-degrees. I have no idea what sort of forces must have been applied to put it so far out without otherwise damaging it. Perhaps I will have a go at milling the blade true one of these days. Neil Edited By Stub Mandrel on 08/11/2011 20:05:36 |
Ian S C | 09/11/2011 01:40:50 |
![]() 7468 forum posts 230 photos | Rob, where do you keep it, and how many mates do you have to lift it, 40 mm X 100m weighs a fair bit! Do you use it vertically, that must be fun? Ian S C
I suppose you ment 100 mm |
