Ed Duffner | 27/09/2011 22:29:09 |
863 forum posts 104 photos | Hi Everyone,
I am new to the Model Engineer forums and also to machine tools. I've recently purchased a milling machine and a 2MT collet chuck set to go with it. I've included some photos below.
The issue I have is, if I rotate the collet so that it slides further into the chuck, the clamping nut will screw on all the way without tightening the collet and the collet spins around freely.
The only way I can get a collet to tighten onto a cutting tool is to put the collet in so that "Side A" (in the bottom photo) rests against the grub screw. But this seems a very insecure way to hold a collet.
Could somebody kindly explain how this particular chuck is supposed to hold its collets please? I can take more photos if necessary.
Many thanks,
Ed.
![]() Inside view showing the side mounted grub screw.
Phil P | 27/09/2011 23:04:22 |
851 forum posts 206 photos | Can you confirm that you have inserted a screwed shank cutter into the collet ?
The idea is that the centre hole in the back end of the cutter bears against the male centre in the chuck. The grub screw is there to prevent the collet turning when you tighten it up, and the shoulders should go down past the grub screw.
Edge A should never touch the chuck body, all the end load is through the actual cutter and onto the male centre.
Have a google for "Clarkson Autolock Chuck" and you will find more info.
Phil
michael cole | 27/09/2011 23:05:50 |
166 forum posts | Hi Ed
I use the same collect chuck. The end of the cutter is ment to be supported by the point in the chuck body. What i normally do is screw in cutter is threaded end is just short of coming through the threads in collect. Insert collect in body so your Edge A is as inserted as far as it can. tighten up nut hand tight give the cutter a final turn then tighten nut with wrench. Does not have to be very very tight. The grub screw is to stop the shoulders on the collect rotating..
Mike |
Steambuff | 27/09/2011 23:29:39 |
![]() 544 forum posts 8 photos | I have the same collet system.. it's a Quick Release Collet, I got mine from Axminster in the UK. It will only work with screw shanked milling cutters ... Axminster also sell these. (I have yet to find another UK source at a reasonable price)
I was told that you screw the cutter into the collet a few turns and then insert into the body and tighen up the body nut by hand, then finish screwing the cutter in and then pinch up the body with the spanner supplied. (If you screw the cutter all the way in first, you won't be able to tighten it in the body)
Ed Duffner | 28/09/2011 00:02:44 |
863 forum posts 104 photos | Phil, Mike and Dave,
Many thanks for your replies and help, I understand now
![]() Regards,
Ed. |
Ian S C | 28/09/2011 14:06:00 |
![]() 7468 forum posts 230 photos | I made a holder for plain shank cutters that fits in a 3/4" collet in my chuck. It consists of a bit of steel (from the junk box) turned to 3/4" dia and screw cut and center drilled at one end, then turned around in the chuck and drilled to fit the shank of the cutter, the cutter has a flat gound on the side, so a hole was drilled in the side of the holder to correspond with the flat, thiswas tapped 1/4" UNF. I can also fit a HSS countersink in it. Itr was made to cover an emergecy when I did'nt have a cutter with a screw shank. Theres usually a way of doing these things if you have to. Ian S C |
David Littlewood | 28/09/2011 18:30:02 |
533 forum posts | Posted by Steambuff on 27/09/2011 23:29:39:
Tracy Tools sell sets of screwed shank milling cutters at quite low prices. They are very readily available, though normally not as cheap.
David |
Steambuff | 28/09/2011 18:59:57 |
![]() 544 forum posts 8 photos | Many Thanks David ... I'll take a look |
Ian S C | 29/09/2011 10:26:44 |
![]() 7468 forum posts 230 photos | A threaded extention, a size larger in dia could be silver soldered on to the plain shank in a similar way to the one that I made held together with a grub screw, just an idea if you must use that collet chuck. Practical??? Ian S C |
Steambuff | 29/09/2011 12:00:53 |
![]() 544 forum posts 8 photos | Thats an idea .... or even tap the ends ... oouch !!!
I prefer that collet chuck as I don't have to keep removing the taper & drawbar when I want to change cutters (i.e from 6mm to 10mm to 16mm etc)
Never have liked hitting the end of the drawbar with a hammer. (Yes I have a small Sieg Mill)
Ed Duffner | 29/09/2011 17:56:52 |
863 forum posts 104 photos | Thank you guys for the great ideas.
I did have an idea of making a cutter extension, threaded at one end, with a boss on the other. I'd grind a flat on the end of the cutter's plain shank which would be secured by a grub screw or two through the side of the boss.
At the moment though I'm very much a novice with machine tools and a few other skills e.g. silver soldering. Until I build up my skill set I'll err on the side of safety and not try to make an adaptor, I'd always be thinking... is it going to hold? or, will it break?
![]() Thanks again,
Ed.
PS. I have now ordered a 2MT ER25 collet chuck and collets which takes threaded or plain shank cutters. |
NJH | 29/09/2011 19:03:34 |
![]() 2314 forum posts 139 photos | Hi Ed Posted by Ed Duffner on 29/09/2011 17:56:52: Thank you guys for the great ideas. I did have an idea of making a cutter extension, threaded at one end, with a boss on the other. I'd grind a flat on the end of the cutter's plain shank which would be secured by a grub screw or two through the side of the boss. This is just what I did to hold those mini - cutters (less than 1/4" and come with a flat on the shank) in my Posilock chuck. It works well but you must be sure that the shank of the holder and the hole for the cutter are concentric. Regards Norman Edited By NJH on 29/09/2011 19:04:30 |
Tomfilery | 29/09/2011 19:36:27 |
144 forum posts 4 photos | Steambuff makes an interesting point re hitting the drawbar with a hammer.
To avoid doing this on my Axminster MicroMill, I drilled the top part of the mill spindle (which is soft, unlike the morse taper part) using my pistol drill and tapped it M12. This allows a short bar to be inserted (obviously after the long one has been removed) and an M12 bolt screwed down against the bar, forcing the chuck out of the taper - saving hammering which always feels likely to damage the machine.
Regards Tom |
Ian S C | 30/09/2011 11:15:55 |
![]() 7468 forum posts 230 photos | I did tap a thread onthe end of the shank of a 1/4" drill, and put a center hole in it, then resharpend it to work as an end mill. With a drill you can do this as the shank is not hardened, but an end mill is hard all over. Ian S C |
Geoff Theasby | 30/09/2011 11:53:27 |
615 forum posts 21 photos | My Warco milling machine recommends the use of a rubber hammer to help extract milling cutters and collets from the taper. I haven't bought one yet, so I don't know how effective one would be, but perhaps you shouldn't screw down the drawbar too much either. Regards Geoff |
Ed Duffner | 02/10/2011 01:26:42 |
863 forum posts 104 photos | Hi Geoff,
I use(d) a rubber mallet on my WM-16 and find that I cannot loosen the drawbar with it even with moderately heavy blows and not having the drawbar overtightened in the first place. I may switch to an aluminim dolly and regular hammer or a nylon hammer.
Ed. |
David Littlewood | 04/10/2011 18:03:03 |
533 forum posts | My Emco FB2 mill has an external thread on the upper end of the spindle. The drawbar is a very long hex socket capscrew; to remove, there is a threaded cap (with a hole in the end big enough for an Allen key) which screws on the external thread, then with a big Allen key in the drawbar and a spanner on the flats on the cap, you can force the drawbar up against the cap, which pushes out the 2MT tooling.
One problem is that half the tooling you buy has an M10 thread, the other is 3/8" BSW. I got overt this by making a 3/8" BSW drawbar, with a hole in the upper end, into which I Loctited a turned-down M10 capscrew. Rather to my amazement and gratification, this has survived about 20 years of use.
David Edited By David Littlewood on 04/10/2011 18:03:59 |
Mark P. | 04/10/2011 20:19:23 |
![]() 634 forum posts 9 photos | Posted by Ed Duffner on 02/10/2011 01:26:42:
Hi Geoff,
Ed. Hi Ed,I have a WM16 mill,I use the self-ejecting method ie.wind the drawbar out of the chuck / collet against the drawbar retaining nut.
regards Pailo. |
Ed Duffner | 05/10/2011 16:56:56 |
863 forum posts 104 photos | Hi Pailo,
Many thanks for the tip, I will give it a try.
![]() Regards,
Ed. |
