Oliver Lindley | 13/08/2011 12:35:07 |
13 forum posts 3 photos | I recently bought an MT2 25mm end mill from ebay - it is a tang type tool (no drawbar thread). How am i supposed to keep this securely held in my mill? I have had another one of these for a few years and i was able to drill and tap through the tang, however the new one is too hard and blunted a cobalt drill within seconds, so i can't do the same. I was thinking of chopping the tang off and welding on a M10 nut, then fetttling to size. Any other thoughts? It does have a centre hole in the middle of the cutting end - does this imply that it may be for use on a horizontal mill with an end support to stop it falling out? |
David Clark 1 | 13/08/2011 12:44:27 |
![]() 3357 forum posts 112 photos 10 articles | If the shank is too hard to turn down, put it back on Ebay.
Did you know it had a tang when you bid on it?
regards David
Oliver Lindley | 13/08/2011 12:58:50 |
13 forum posts 3 photos | I could probably turn it down with a carbide tool, but holing it securely without damaging the cutting edges would be a problem. Also, the reason why i bought it is because it is a much shorter solution than a conventional cutter in the collet chuck. I did realise that it had a tang, but as i had managed to drill and tap one before, i didn't think that it would be a problem - the markings suggest that it is plain HSS, but it does seem to incredibly hard. Does anyone know how one of these should be used? or are non-chinese morse tapers sufficiently good that it won't get pulled out? |
Tony Pratt 1 | 13/08/2011 19:54:44 |
2319 forum posts 13 photos | I have seen them in museums and god knows how they were used safely, seems a recipe for disaster. I wouldn't rely on a morse taper to hold a milling cutter securely and really a draw bolt is the only way to go!
Tony |
Michael Cox 1 | 13/08/2011 20:08:08 |
555 forum posts 27 photos | Could it be intended to be a drill for producing flat bottomed holes?
Mike |
JasonB | 13/08/2011 20:25:04 |
![]() 25215 forum posts 3105 photos 1 articles | Sparey shows this type of cutter being used to mill in a lathe and makes no mention about retaining it in the spindle. Less likely to drop out of a lathe than a vertical mill but could get pulled out by a heavy cut though it does have a much shallower helix angle than the usual end mills & slot drills we use today.
J |
Andrew Johnston | 14/08/2011 09:40:54 |
![]() 7061 forum posts 719 photos | Personally, I'd never use a milling cutter relying just on the Morse taper to hold it in place. However, my newest copy of Machinery's Handbook shows both T-slot cutters and endmills with Brown & Sharpe tapers and tangs. The B&S taper is similar to Morse tapers. Not a word about how they are used though. The mystery deepens. Regards, Andrew |
Gordon W | 14/08/2011 10:07:50 |
2011 forum posts | Might it be a core drill, for boring cored holes in castings? |
Ian S C | 14/08/2011 13:03:07 |
![]() 7468 forum posts 230 photos | I,d proberbly cut the tang, plus a bit more off, maybe with the angle grinder, square it up, then weld on a cylinrical nut, I don't know if your suposed to weld HSS, but I'v done it and it worked. You can then use a draw bar.
Amoung my colection of old books is a copy of "Millers" by Emanuele Stieri, it dates back to 1943, and is based on information from Brown and Sharpe Co, it shows end mills, T-slot cutters, fly cutters all with (I assume) Brown & Sharpe tanged tapers, I thought that perhaps it might tell about using them, without them falling out, not a word!.
Ian S C |
David Clark 1 | 14/08/2011 13:14:59 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
I think Brown and Sharpe are much shallower tapers so would hold better.
Still not a good idea though.
regards David
Andrew Johnston | 14/08/2011 13:24:15 |
![]() 7061 forum posts 719 photos | I had to look it up, but you're right, B&S tapers are shallower, albeit not by much. Morse tapers are about 0.6" per foot, while B&S tapers are about 0.5" per foot. As far as I'm aware B&S tapers are pretty much obsolete now, presumably being largely limited to Brown & Sharpe machine tools. Regards, Andrew |
Nicholas Farr | 14/08/2011 15:30:45 |
![]() 3988 forum posts 1799 photos | Hi Oliver, I think Michael Cox may be on the right track. Below is an avert from a 1963 George Hatch general catalogue, showing HSS MT counterbores with a tang, and a photo of three tanged 1 MT counterbores by F.B. TOOLS, that I aquired amoung some other cutters some while ago. You will notice the helix more akin to a reamer than an end mill.
I have never used these myself BTW.
Regards Nick.
Edited By Nicholas Farr on 14/08/2011 15:36:53 |
JasonB | 14/08/2011 16:48:24 |
![]() 25215 forum posts 3105 photos 1 articles | I'd say the ones in your photo are machine reamers as they have a negative helix.unless the picture has been reversed.
The ones in Sparey's book are definately mills as there is a picture of him using the vertical slide to mill a hornblock.
J |
Oliver Lindley | 14/08/2011 18:50:13 |
13 forum posts 3 photos | Hi all
thanks for all the comments. The cutter is definitely an end mill. I decided to chop the end off and weld on a bit of M10 tapped 1/2" bar. Photos below for your enjoyment....
Nicholas Farr | 14/08/2011 19:38:49 |
![]() 3988 forum posts 1799 photos | Posted by JasonB on 14/08/2011 16:48:24:
J Hi Jason, I think you may be correct about the ones in my photo. I must admit I didn't pay any attention to the negative helix, as I've said I never used them.
The one in the foreground is 7/16" dia' and the cutting edges are 15/16" long and they all have speedicut H S. 18 stamped on them.
Regards Nick. |
Ian S C | 15/08/2011 02:56:41 |
![]() 7468 forum posts 230 photos | If the ones in Nicks photos are ramers there will be no cutting edges on the end . If they are end mills, they may be left hand cutting, or I just had a thought, with a reverse hellix, would that tendto push the cutter into the mandrel, rather than trying to pull it out as in a normal cutter? Ian S C |
