How are they cured?
M R | 26/06/2011 11:04:47 |
3 forum posts | To cure the small leaks in a boiler,Stan Bray suggests that the holes be drilled and filled with a tight fitting plug where possible and although soft solder is mentioned,he sounds as if this is not an ideal solution:Martin Evans book on model boilers,states that soft solder can be used but,it must not be the ordinary plumbers grade.Henry Greenly’s book “Model Engineering” mentions using oatmeal (within reason).How is this used,is it mixed with the water to be used to fill the boiler and then heated-will oatmeal used to make porridge do the job? This method reminds me of the old trick of putting an egg in a leaky car radiator. In an (oldish catalogue) Blackgates Engineering list a lead solder melting at 296 degrees centigrade is this suitable for use on a copper boiler which is already soldered with a 610-620 degree melting range silver solder.Work on my engine is at a standstill so any information will be much appreciated |
JasonB | 26/06/2011 12:56:20 |
![]() 25215 forum posts 3105 photos 1 articles | Talk to your boiler inspector first but you may be able to use a high temp soft solder like Comsol which is what Blackgates sell, Reeves also do it.
Jason |
Jens Eirik Skogstad | 26/06/2011 15:31:51 |
![]() 400 forum posts 22 photos | Inn old days the leaking boiler was cured with horse dung ![]() |
Roderick Jenkins | 26/06/2011 18:40:41 |
![]() 2376 forum posts 800 photos | Alec Farmer in "Model Locomotive Boiler Making" recommended the use of high temperature soft solder for sealing small leaks. From what I remember though, you cannot then go back and do any silver soldering, the soft solder will alloy with the hard solder and form a brittle compound. My "Jenny Lind" project stalled at this point many years ago with a pin hole in the firebox crown. I never could decide how to fix this - it's still waiting. Rod |
KWIL | 26/06/2011 21:56:37 |
3681 forum posts 70 photos | Rod you are correct, once you introduce lead there is no going back. A good boiler maker may be able to fix it with silver solder. How big a leak and where?
Edited By David Clark 1 on 27/06/2011 21:00:40 |
M R | 27/06/2011 19:14:56 |
3 forum posts | JasonB In an (oldish catalogue) Blackgates Engineering list a lead solder melting at 296 degrees centigrade is this suitable for use on a copper boiler which is already soldered with a 610-620 degree melting range silver solder.Work on my engine is at a standstill so any information will be much appreciated
Thanks for taking the time to reply will most likely use Consol.Not in touch with a boiler inspector unfortunately. Edited By David Clark 1 on 27/06/2011 21:00:23 |
David Clark 1 | 27/06/2011 21:01:40 |
![]() 3357 forum posts 112 photos 10 articles | Hi Maurice
Please click on the past from Word button or paste into notepad then copy and paste into here.
Otherwise you mess the format up.
regards David
Terryd | 27/06/2011 21:25:01 |
![]() 1946 forum posts 179 photos | Posted by M R on 27/06/2011 19:14:56: Jens Eirik Skogstad An Interesting fact,horse dung appears to have been very useful item in the pastie;................ Maurice Rhodes Edited By David Clark 1 on 27/06/2011 21:00:23 I prefer swede, onions and minced beef in my pasties. Still, each to his own, so to speak. ![]() Best regards Terry |
Stub Mandrel | 28/06/2011 20:00:55 |
![]() 4318 forum posts 291 photos 1 articles | I'm a vegetarian, so as long as it's herbivore dung in my pasties... Neil |
M R | 29/06/2011 09:54:28 |
3 forum posts | Past ie-What a difference a space makes.Think I'm good enough to get a job journalism ?
MR |
