Derrick Watson | 15/04/2011 18:19:47 |
18 forum posts | More a comment for beginners rather than a question but... I had a mini lathe for about a year, learnt the usual stuff and 'attempted' some milling on it with a milling adaptor thing - but was never very successful using it.
Anyway decided to get a 'proper' mini mill and what a total difference it's made. So much easier to use and much quicker, neater and enjoyable than trying to use a saw and file to get simple basic shapes done.
So my point is just that I'm really surprised at the amount of difference it's made and the extent to which I'm finding all kinds of uses for it.
Cheers all, Derrick |
David Costello | 15/04/2011 19:41:26 |
79 forum posts 9 photos | Hi Derrick
What make of mini lathe is it?
Dave |
Derrick Watson | 15/04/2011 21:33:57 |
18 forum posts | Hi, it's an Axminster SIEG SC2 |
ady | 16/04/2011 00:31:36 |
612 forum posts 50 photos | You need a good stiff hobby lathe, engage backgear and a slow feed in my limited experience of lathe milling. I've been hogging out a 4.5x3 inch billet of steel with a hss woodruff cutter on and off over the last couple of weeks, it does fine but it's not quick, (on a project to make a solid steel circular vice) I've never had a carbide slot drill, hss ones are pretty good, the small cutting area means you get a huge amount of torque for munching metal. My motor is pretty old and works away without complaint for hour after hour but without the backgear system I don't think a hobby lathe electric motor would survive for long. Milling -chewing your way through solid steel- is quite hard work compared with turning. Edited By ady on 16/04/2011 00:38:08 |
Ian S C | 16/04/2011 03:19:57 |
![]() 7468 forum posts 230 photos | ady, when there's a lot of metal to remove, I get to work with the hacksaw / bandsaw, and a drill to get rid of as much material as possible before starting with the mill, and that would be more important with the mini mill. Ian S C |
nic | 16/04/2011 06:53:49 |
42 forum posts 1 photos | Hi there, I also have the SC2 from Axminster and attempted some milling on it,
One huge big failure!!!
In my view the lathe is just not rigid enough,
I'm saving up for a Super X3 from Arc,
Cheers Nic |
ady | 16/04/2011 09:19:57 |
612 forum posts 50 photos | ady, when there's a lot of metal to remove, I get to work with the
important with the mini mill. Ian S C I tend to use big jobs as training exercises to try and improve my experience because I've only been at it for just over a year. so I practice getting a feel for "perfect edges" for multi pass cuts etc because I don't get an awful lot of time on the old girl. |
Lawrie Alush-Jaggs | 16/04/2011 11:28:46 |
![]() 118 forum posts 32 photos | Hi Derrick I couldn't agree more about the mill. I have loads of both hand and power tools but since I bought a mill about two and a half years ago, the hand tools are scarely used.
Ian S C | 16/04/2011 12:01:44 |
![]() 7468 forum posts 230 photos | I bought a BIG file yesterday,16" for $NZ2, needs a handle. some times a file is quiter than a mill. Ian S C PS I also got 2 little bags with 10 carbide inserts for $2ea, not bad for a total of $6. |
John Olsen | 16/04/2011 12:56:13 |
1294 forum posts 108 photos 1 articles | If the job is worth doing, there will be a power tool to do it! (Somewhat tongue in cheek...) regards John |
Derrick Watson | 17/04/2011 11:01:00 |
18 forum posts | Yep agree with all the above, plus for me one of the biggest differences between the lathe milling and mill milling is the greater amount of movement in the X and Y, easier movement in the Z axes, and simply being able to see what I'm (trying) to do when the work is flat in front of you rather than at 90deg. |
Chippychap | 27/04/2011 09:39:36 |
![]() 11 forum posts | The current Mrs Chippychap reckons that power tools are a bloke thing.
Need a pencil sharpening? "I'll need a CNC machine"
She's getting bitter and twisted..
Nicholas Farr | 27/04/2011 09:50:09 |
![]() 3988 forum posts 1799 photos | Hi Chippychap, I don't know about the power tool, but a £200.00 gift card to her favorite clothes store and a free hair do might sweeten her up a bit.
Regards Nick. |
Dusty | 27/04/2011 10:04:33 |
498 forum posts 9 photos | Nick
£200-00 of Model Engineering tokens! I nearly had a heart attack when I read that. Maybe stretch to £20-00 but I would need guaranteed results. |
Nicholas Farr | 27/04/2011 10:16:59 |
![]() 3988 forum posts 1799 photos | Hi Dusty, whoops! the decimal point slipped.
Regards Nick. |
Chippychap | 27/04/2011 10:18:22 |
![]() 11 forum posts | For 200 quid I would expect Billie Piper and a running buffet.....................................and NEED a paramedic with a defibrillator |
Gray62 | 27/04/2011 17:46:44 |
1058 forum posts 16 photos | Hi Derrick, Just o get things back on topic ( no offence to any of the quips), which Mini Mill do you have? I have an X2 clone waiting in the wings for a CNC conversion, just for a bit of fun, My primary mill is an AJX AJT4, fully manual, with DRO but will handle anything I throw at it regards CB |
Derrick Watson | 27/04/2011 21:02:44 |
18 forum posts | Hi, it's an Axminster SIEG X1.
I realise it's on the small end of the scale but seems to do everything I've asked of it so far (small stuff mainly in brass, Al and a bit of EN1A).
I was also considering the X2 and X3 but space doesn't allow at the moment and I also wasn't sure just how much use it would get. The cost saving has also allowed a couple of other goodies to be bought (rotary table and a few other odds and ends).
cheers, d. |
