Jacobs Gear Hobber
Robert Wallace 109/05/2010 09:41:46
10 forum posts
Hi
Has anyone made the Jacobs type gear hobber from the castings sold by CES. Many years ago there was and article published in Model Engineer in 1976 on making one ,any help would be greatly appreciated
Chris Hembry09/05/2010 10:39:00
52 forum posts
Hi Robert
I have a set of castings and am at an early stage in construction. There was also a series published in MEW issues 58-60. The ME articles were for a slightly different version although the principles were the same.
Regards, Chris
Robert Wallace 109/05/2010 11:52:07
10 forum posts
Hi Chris
Many thanks, could I obtain the back issues  as mine only go back 6 years
Bob
John Stevenson09/05/2010 14:42:03
5068 forum posts
Bob, drop me an email at
john [at] stevenson-engineers.co.uk
John s.
Steve Wan09/05/2010 17:01:59
131 forum posts
Hi Robert and Chris
Very interested in your venture in making gear hobber and seen those
cast pieces at CES...but am quite confused between a gear hobber
and pinion cutting machine...ain't they the same???
Also I know that CES stated that their cast includes a tech. drawing
to assist the build up...any difference from ME articles??
I hear from both of you, tks!
Steve Wan
Robert Wallace 110/05/2010 10:06:27
10 forum posts
Hi Steve
I am hoping to cut both pinions and gears on the hobber when finished but if I am wrong I am sure a kind hearted soul out there will let me know I have yet to lay my hands on the ME and MEW articles
Bob
Steve Wan10/05/2010 11:25:17
131 forum posts
Hi Bob
Thanks! Possible we get in-touch by email?
This gear or pinion cutting machine is my next project. Perhaps we can exchange more design ideas...see my gallery photos, I was successful in making the tool and cutter -Quorn more simple for light users. Tested, work like a Charm!
I do have other pictures of gear cut machines, yet to re-design and make it
smaller and simple to build. The basic foundation is of a horizontal mill before
more stuff are added...indexer, tailstock etc.
Steve
GoCreate25/07/2010 09:27:39
387 forum posts
119 photos
As far as I know, a pinion is just a gear cut integral on a shaft and in use engages with a rack, i.e. rack and pinion, otherwise it's a gear.
I notice the CES gear hobber uses a vertical slide, are castings for this included in the kit? I am also interested in building one of these well, it's on my list of projects.
Nigel
Richard Parsons25/07/2010 10:24:26
645 forum posts
33 photos
Some moons ago I wrote a challenge to the Editor on a similar topic. I what it said was that if you could read the rotational speed and (position) of a shaft (say of my milling machine) and factor this into a stepper motor which could then drive a shaft with a gear blank on it. Behold you have a gear hobbing machine.  The problem for me my ‘electronic’ stopped with the introduction of the pentode valve. Any one out there want to design the black box to do it?
The advantage of hobbing is that you only need one hob for each Module/Diameteral pitch and that is cut as Rack’. With gear cutting you need several cutters for each Module/Diameteral pitch depending on the number of teeth you are cutting.
KWIL25/07/2010 11:04:51
3681 forum posts
70 photos
The Jacobs device works very well and was demonstrated at the Midland ME Exhibition (as well as Harrogate I believe)
John Stevenson25/07/2010 21:35:01
5068 forum posts
Posted by Richard Parsons on 25/07/2010 10:24:26:
Already been done.
Read MEW 108, article by Brian Thompson  also includes the circuritry.
John S.
Richard Parsons08/08/2010 10:44:28
645 forum posts
33 photos
Hello John,
Thanks for that reference. Although I have been subscribing to MEWS since 2004 here in Hungary (and before that in the U.K.) MEWS No 108 is missing.
This would have been about October 2005. In 2004-5 the publishers of ME/MEWS were using a Swiss distribution company for the Euro Post. Summertime distribution in 2004 was bad –well there were holidays, so they would be short handed and the batch for Hungary was very small! It was forgotten –dimmed-. The same thing happened in 2005.
Later in 2005 the distribution company was involved with a nasty swindle involving an Italian outfit. The Swiss authorities just cancelled the distributor’s licence and dumped on them from a great height. They should be ‘out’ in a few years time (with good behaviour). The Swiss are very strict.
I cannot get a copy of MEWS No 108 as there are none left. The Swiss just shredded the blooming lot and the publishers had to use up their surplus to satisfy demand.
That is why I did not know about this article.
If any one could scan in and message me a copy of the article I would be delighted.
John Stevenson08/08/2010 12:00:23
5068 forum posts
Richard, drop me an email to [email protected] and I'll forward a copy of Brian's article on with added extras.
I can do this as I was involved in the project to the point of getting a dedicated circuit board made up and have Brian's full permission to share anything so copyright doesn't come into this.
Brian transposed the circuit to veroboard so it would be easier to build and there was a mistake in MEW108 which didn't get corrected until MEW110 if I remember for anyone using the original articles.
I have this setup on a Victoria U2 and it runs as a dedicated hobber, it's probably done over a 1,000 gears to date as most of them done are in sticks of 10.
John S.
Ejaz Ahmed10/03/2013 16:46:45
HOME MADE GEAR HOBBER (BIG HEAVY DUTY)
I am looking for complete plan(casting drawing, machining etc.) to make home made GEAR HOBBER (swing 175", Module 45, Face 48", Can hold weight up to 40 Ton). I really appreciated if Some one help me. Ejaz.
(Please send Ejaz a PM. Ed.)
Edited By Diane Carney on 11/03/2013 10:27:26
joey14/05/2013 19:31:47
31 forum posts
Can someone please help with some instructions on how to the determine gears needed to cut spesific counts of teeth in the CES Jacobs type gear hobber?
Joey
Douglas Johnston14/05/2013 21:33:31
814 forum posts
36 photos
John S. - I have just fished out MEW 108 and the gear hobbing system looks very interesting, I must have flicked past it at the time without thinking too much about it.
I am interested in trying it out and was wondering if the layout for the PCB you mentioned is available, since I don't like veroboard. I could do my own layout but it would save me a lot of time if one was already available.
Doug
John Stevenson14/05/2013 23:42:20
5068 forum posts
Doug,
I do have some pictures and PM sent.
Stub Mandrel15/05/2013 14:40:26
4318 forum posts
291 photos
I visited CES several weeks ago. I expressed intedt in the hobber, apparently it is quite a popular projecty. They are quite happy to supply part-sets of castings as the machine has parts which potentially have several other applications, not least a vertical slide.
Bazyle15/05/2013 17:24:45
6956 forum posts
229 photos
Note that the design appears to have been updated by an American. 'simplified and improved' to make it more ridgid. However his kit is rather expensinve and only available in USA.
Getting interested in the electronic version and of course the relevent MEW has decided to hide itself somewhere, probably in a pile of MEs.
joey15/05/2013 17:52:54
31 forum posts
Doug, I have done the pc board for the electronic synchroniser for the gear hobber on my Mach 3 controlled Optimum mill. if you are interested and can use it, I can mail you the G-code and Autocad 14 drawing or dxf files. I am trying to fit the unit to a Jacobs type hobber and it should then run without the use of lots of gears.
Joey
