Supplier Required.
howard wilcox | 06/03/2010 12:03:18 |
3 forum posts | I'm after some unplated mild steel B.S.F. full nuts with single chamfer in sizes 1/4", 5/16", 3/8", 7/16" and 1/2". Does anyone know of a supplier as most firms I've contacted only supply double chamfer nuts.
Thanks,
Howard.
Circlip | 06/03/2010 12:25:00 |
1723 forum posts | Double chamfer is to stop the untrained from putting the nut on upside down. Some of the material suppliers have standard hex sizes, easy to make yer own.
Regards Ian |
JasonB | 06/03/2010 16:48:56 |
![]() 25215 forum posts 3105 photos 1 articles | Try EKP all their smaller nuts are singel chamfer and looking at the pics in their paper catalogue the BSF look the same, but they only go upto 3/8"
Jason |
Ian S C | 07/03/2010 01:31:24 |
![]() 7468 forum posts 230 photos | A lot of nuts these days are washer faced, I don't suppose you'd put one of those on upside down! Ian S C |
howard wilcox | 07/03/2010 09:38:43 |
3 forum posts | Thanks for the responses so far. Unfortunately EKP cannot help me. I need large quantities of the nuts therefore making my own is not a viable option.
A source of single chamfer nuts still required!
Cheers,
Howard. |
Circlip | 07/03/2010 11:00:53 |
1723 forum posts | OK, serious answer. If you check on either the interweb or a trade directory and search for "Bolt and Nut Manufacturers" you will probably unearth someone who is able to supply to your requirements, BUT, no whinging about the "Excessive" costs involved.
Non conformity COSTS
Regards Ian.
And No Ian S C, the only answer would be a L/H thread in one half. ![]() |
howard wilcox | 08/03/2010 18:11:13 |
3 forum posts | Circlip,
I've spent literally hours trawling the internet to find suppliers and cannot locate anyone who stocks them any more at any price. Before having a large batch munufactured I thought I'd try this forum for leads,
Cheers,
Howard.
DMB | 08/03/2010 18:26:41 |
1585 forum posts 1 photos | Try yellow pages @ library, for Worcester area. I believe a number of nut n bolt makers in that area.
John. |
David Clark 1 | 08/03/2010 18:27:59 |
![]() 3357 forum posts 112 photos 10 articles | Hi ther
What about buying double chamfer and skimming one side?
regards david
DMB | 08/03/2010 18:28:04 |
1585 forum posts 1 photos | I believe that a number of nut nbolt makers are in Worcester area - try yellow pages @ Library.
John |
macmarch | 08/03/2010 19:19:18 |
147 forum posts 1 photos | Howard, Had a quick look round for you. You say you require large numbers so perhaps these people could help.
This page specifies Full nuts to BS spec machined. On other pages they quote forged so they should be single sided.
ray Edited By David Clark 1 on 08/03/2010 20:45:11 |
Circlip | 08/03/2010 19:20:27 |
1723 forum posts | Wasn't suggesting a stockist Howard as you already know hens teeth are easier to find, no, it means a manufacturer or DIY. Problem with Thinning a double chamfered nut is the finished thickness David. I remember (???) the single chamfers, but that's LOTS of years ago.
Regards Ian. |
Circlip | 08/03/2010 19:20:41 |
1723 forum posts | Hiccup Edited By Circlip on 08/03/2010 19:37:01 |
Circlip | 08/03/2010 19:24:37 |
1723 forum posts | Flamin long links screwing it again. Perhaps the new web master can get the web designers to sort this ongoing problem out Edited By Circlip on 08/03/2010 19:38:50 |
Circlip | 09/03/2010 10:17:46 |
1723 forum posts | Wasn't having a pop at you Ray, but this is a constant re-occuring problem and I would have thought the web designers would have sorted it out by now without David having to dive in every time.
They seem to make sure the ads. work ok.
Regards Ian Edited By Circlip on 09/03/2010 10:18:15 |
chris stephens | 09/03/2010 12:21:52 |
1049 forum posts 1 photos | Hi Howard,
Could you get away with castellated nuts, they often/used to have a single chamfer?
chriStephens
macmarch | 09/03/2010 21:47:44 |
147 forum posts 1 photos | No offence taken circlip. Just trying to help. I do aggree with you, some of these addy's do get a bit long. I've seen the way it is now after David changed it. Wish I new how to do it.
cheers
ray
David Clark 1 | 10/03/2010 08:39:38 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
Look at the editor box.
There is a chain.
Highlight some text
visit here
click the chain, insert link in the box, click open in new window box.
job done.
regardsDavid
macmarch | 10/03/2010 09:46:58 |
147 forum posts 1 photos | As I always say. You learn something new every day.
cheers
ray
