What Paint
Harry Wilkes12/08/2023 16:10:54
1613 forum posts
72 photos
Visited a friend yesterday who due to his disability had some handrails fitted from his front door to his car, they are finished in a smooth bright galvanize his wife wishes to paint them but I suggested for her to hold off saying 'you can't just use any old paint' so any suggestion how best to paint them and with what ? My first though was Hammerite but then thought maybe needing to be etched first.
H
Thor 🇳🇴12/08/2023 16:30:12
1766 forum posts
46 photos
Hi Harry,
When painting galvanised steel proper cleaning/degreasing with for instance an alkaline cleaner is the first step. Make sure the rail is dry before the next step. Next a primer for zinc coated steel, then paint using for instance an acrylic-latex exterior paint or an oil-based paint. You may want to let it dry and apply a second coat.
Thor
Edited By Thor 🇳🇴 on 12/08/2023 16:30:50
Bo'sun12/08/2023 18:21:25
754 forum posts
I'm not sure if "T-Wash" is the correct name, but it turns the bright galvanized finish a sort of black colour ready for painting.
If I remember correctly, Hammerite have such a product.
On the other hand, the cheap way, and if you're not in a hurry, would be to wait and let it naturally oxidize for about 6 months before painting.
noel shelley12/08/2023 18:32:58
2308 forum posts
33 photos
I'm with Bosun, let nature do the weathering it will do it far better but leave it much longer than 6 months. Why paint galvanised finish ? I have seen properly etched and primed galv just flake off. It will weather to a light grey. Noel
Harry Wilkes12/08/2023 19:03:24
1613 forum posts
72 photos
Thanks for suggestions so far Noel you ask Why paint galvanised finish ? Well as I said it's a friend of mine if it were me I would just leave it as is but at the moment it's very bright and really stands out
H
Peter Tucker12/08/2023 19:28:38
185 forum posts
Hi Harry,
My suggestion is powder coat.
Peter.
Grindstone Cowboy12/08/2023 20:08:14
1160 forum posts
73 photos
+1 for leavig it to weather naturally - it's a bit like painting brickwork, once you start, you have to keep on maintaining it.
Rob
Paul Lousick12/08/2023 23:26:11
2276 forum posts
801 photos
As suggested. Leave gal finish to weather naturally and the bright shine will disappear and will allow for a better bond with paint if you still want to go that way. Any painted surface will chip. How do you powder coat an already installed handrail without pulling it apart ?
phillip gardiner13/08/2023 00:49:01
22 forum posts
Paul Lousick To powder coat gal wouldn't you have to clean first with some degreaser type product , as you and others have pointed out weathering is really the best.
Stephen Harris 513/08/2023 06:59:46
19 forum posts
The correct primer for painting a galvanized surface is "Calcium Plumbate". It's available at some DIY outlets as I have seen it.
I live near Droitwich and the DIY place "Wigleys" near Stourport used to have it on their shelves.
How do I know about this primer??
Well, I used to work at a steel fabricators/ erectors and Dave , the boss, would take on anything.
The Severn bridge taking the M50 over the river was galvanized steel and when first erected it was just painted over.
The paint came off "in sheets" he said. So he took on the job of stripping and repainting said bridge.
Calcium plumbate was the primer specified for the job.
Nigel McBurney 113/08/2023 09:23:58
1101 forum posts
The old rule with galvanised corrugated sheet was to allow the galvanise to "weather" for a year before applying a paint finish, though nowadays there may be suitable primer paints,could they be powder coated?
Harry Wilkes13/08/2023 16:16:03
1613 forum posts
72 photos
Hi and thanks for all the replies Stephen "Calcium Plumbate". rings a bell with me but I can't think why, Peter can't powder coat the handrail is concreted into the pathway
H
Craig Brown13/08/2023 20:03:45
110 forum posts
57 photos
Bedec MSP (Multi Surface Paint) is a paint I use on external joinery. It can be painted directly onto pretty much anything but in the details it states it can be painted onto galvanised steel after it has been left to weather
