Here is a list of all the postings phillip gardiner has made in our forums. Click on a thread name to jump to the thread.
Thread: Building a car from scratch |
07/09/2023 22:30:42 |
Steve ,without tarmac layers you wont be able to enjoy driving your great effort,, Just kidding. As people ask me with some of my projects how do you do it , i simply say one day at a time. |
Thread: What Paint |
13/08/2023 00:49:01 |
Paul Lousick To powder coat gal wouldn't you have to clean first with some degreaser type product , as you and others have pointed out weathering is really the best. |
Thread: Sealing between skirting and floorboards |
13/07/2023 23:56:59 |
Selleys butyl mastic skins but remains flexible for years,. |
Thread: So what do readers want to read about? |
23/06/2023 06:14:20 |
Ralph Lauran can give me some of his fortune so i can build another model loco mate i think he is fantastic. |
Thread: Flash-Flash-Flash... Turn The *&^&%$ Thing Off! |
11/04/2023 22:55:26 |
It's working it has got your attention, that is what it us supposed to do. |
Thread: Pocket Sundial |
25/03/2023 05:27:46 |
Georgineer Tell me would it work of a night?. |
Thread: Gas fired engines |
20/03/2023 21:26:54 |
Converting model locomotives to run on propane is really not that difficult all i changed was remove the grate and ash pan and replaced them with the burners fitted in the old ash pan ,i did not change anything in the smokebox . The gas lines were made large enough so you do not get freezing of the pipes , this system is used in the USA they seem to be less regulated than us and they have massive burners in there settups. |
19/03/2023 21:08:25 |
I have fitted an arch in the firebox and also fitted turbulators in the tubes to slow the flow and get the maximum heat and find that you need the blower turned up to help draw the flame so you get a nice blue flame and a complete burn it is a bit of a learning curve ,but you do not have any ash plus you wont have to clean the tubes constantly ,i also run a separate carriage dedicated for the gas bottle only. |
19/03/2023 04:37:44 |
In Australia or at least in NSW all of the fitting must be approved by the AGA and you must have a blowback valve also a thermocouple in the instalation. |
18/03/2023 00:58:36 |
Duncan I have built a three truck shay loco ,it is 1.5 inch scale but i made it to run on 5 inch gauge track, so the firebox is 8 inchs by 5 inchs rectangular with Marty burners |
17/03/2023 21:12:02 |
Noel Shelley I used [Marty's burners] look it up ,the drawings are there for anyone interested and i have eight burners in the firebox ,they work a treat and are easy to make. |
17/03/2023 20:47:27 |
I have converted to propane in Australia , the governing body here is the AALS for model loco.s the have rules on propane firing , the completed setup has to be passed by a licenced LPG gasfitter however every state in Australia have different rules just to confuse everyone, i only run on one to two psi ,so the whole instalation is low pressure from the gas bottle. |
Thread: Lake Macquarie Live Steam Rally |
09/03/2023 20:49:27 |
This is my great friend's Shay ,he took just on seven years to complete it ,including designing and building the steam pump that works , i only took five years to build my Shay and Trevor also built a working steam pump for my shay we both belong to the same club and help one another out running our loco's, recently i converted mine to run on propane because of unreliable supply of good coal and yet Newcastle has one of the biggest coal loaders in the world. |
Thread: Why is the world of model engineering still imperial? |
05/03/2023 20:59:45 |
Baldric 4x2 in Australia was always3 7/8 x1 7/8 of the saw unless it had to be dressed then it was 4x2 |
Thread: Sweet William |
26/01/2023 03:51:42 |
i run Martys burners in my shay the firebox is about 200mm x 125 i have made and fitted eight burners that run on two pound pressure never run out of steam and never have to clean the tubes. i live near newcastle in australia and cannot get decent burning coal. |
Thread: MIG welder |
14/01/2023 21:11:16 |
Oldiron where are we of to this time.? |
Thread: An interesting trick with balls. |
27/10/2022 21:32:54 |
Sometimes you just have to think outside the square, must keep this idea in my head ,you never know. |
Thread: To Old |
13/10/2022 22:49:07 |
Will Prince Charles be to old to be King? |
Thread: Electric boiler feed pumps |
03/09/2022 23:27:46 |
Here at our club in Australia they are popular with quite a few members, however at our last public day one failed due to a flat battery, i rely on an injector and axle pump ,but even then they can let you down. The electric pumps are good for 150 psi and are reliable ,just remember to have a good battery. |
Thread: You think you've seen it all |
31/07/2022 02:53:48 |
What is wrong with organic drinking water, what get's me is the use by date on bottled water. |
