Bill Phinn | 30/07/2023 15:48:02 |
1076 forum posts 129 photos | Six months ago I bought two non-spill pots like this. When new, their push-on lids were tight-fitting. I put Ilocut cutting oil in one of them and used it for about three months before I noticed that the lid had become very loose, to the point where it could be lifted off the pot with just the weight of the empty pot pulling down on it. Since this non-spill pot had now become a "spill pot" I deployed the second pot, whose lid was still nice and tight at this point, as it was when originally purchased. Three months later,though, the lid on this second pot is just as loose as the first one was after three months. I don't understand the chemistry of why putting oil in the pot makes the plastic shrink, but if anyone can recommend a specific non-shrinking non-spill pot I'd appreciate it. |
Michael Gilligan | 30/07/2023 15:55:34 |
![]() 23121 forum posts 1360 photos | A couple of questions, Bill
MichaelG. . Edit:__ and a third question … is this the relevant oil ? … it appears that there are several numbers/grades of Castrol ilocut Edited By Michael Gilligan on 30/07/2023 16:05:46 |
Maurice Taylor | 30/07/2023 16:05:51 |
275 forum posts 39 photos | Hi , Make one from a glass jam jar ,make a hole in the lid for your brush. Maurice |
Michael Gilligan | 30/07/2023 16:51:04 |
![]() 23121 forum posts 1360 photos | If you go the glass route, and if it’s big enough … the Colman’s Mustard jar is a good relatively-stable shape MichaelG.
Edited By Michael Gilligan on 30/07/2023 16:52:18 |
Baz | 30/07/2023 18:00:16 |
1033 forum posts 2 photos | Wife bought half a dozen of these non spill pots in The Works, used them for the grandkids when they were painting, I nicked a couple for the workshop and they have had neat cutting oil in them for over a year with absolutely no problems, don’t know the spec of the neat cutting oil but it is the stuff that Warco sell |
Bill Phinn | 30/07/2023 18:41:19 |
1076 forum posts 129 photos | Thanks for the replies. Michael, it's Ilocut 154, yes. I don't know whether the lid has expanded or the pot shrunk, but I assume the latter from that fact that, most of the time, significantly more oil is in contact with the pot than with the lid. Either way, the pots are now unusable, as two accidental spillages have already attested. ETA: I don't know whether the two plastics are the same, but the lid is coloured whilst the pot is translucent. Posted by Maurice Taylor on 30/07/2023 16:05:51:
I tried that, Maurice. Access to the oil through a simple hole wasn't quick enough for me, though, even when I bonded an inverted shower cord pull in the lid to guide the brush down into the oil.
Edited By Bill Phinn on 30/07/2023 18:52:43 |
Michael Gilligan | 30/07/2023 19:04:15 |
![]() 23121 forum posts 1360 photos | The twelve page MSDS is available here: **LINK** https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/3D072EBD71E80B75802585FF0053ACA4/$File/2663615.pdf I can see no specific reference to an incompatibility with unspecified plastics, but reading between the lines, the reference to gloves might give us a hint. MichaelG. |
Bill Phinn | 12/08/2023 02:15:39 |
1076 forum posts 129 photos | Thanks for that, Michael. The second of my mysterious shrinking pots/expanding lids is now in the bin. I have replaced it with something of older vintage. |
jimmy b | 12/08/2023 02:55:02 |
![]() 857 forum posts 45 photos | I just hot glued the lids in place after dropping them a couple of times, not had an issue since!
Jimb |
Michael Gilligan | 12/08/2023 06:19:09 |
![]() 23121 forum posts 1360 photos | Posted by Bill Phinn on 12/08/2023 02:15:39:
Thanks for that, Michael. The second of my mysterious shrinking pots/expanding lids is now in the bin. I have replaced it with something of older vintage. . That’s classy, Bill … MichaelG. |
Nick Hughes | 12/08/2023 14:24:31 |
![]() 307 forum posts 150 photos | Dropping a decent sized button magnet into my simple plastic pot, has prevented accidental knock over spills for me (obviously only when the pot is on a ferrous surface though). |
Bill Phinn | 12/08/2023 14:58:57 |
1076 forum posts 129 photos | Thanks for the further replies. Jimmy, gluing the lid in place wouldn't be much good if I wanted to clean the swarf out that inevitably accumulates in the bottom of the pot. Nick, the magnet idea is a good one, though again I wouldn't want to have to clean the swarf off it each time I come to renew the oil. I suppose you could put it in a small ziplock bag. |
DMB | 12/08/2023 18:12:06 |
1585 forum posts 1 photos | You may have a problem removing the magnet from the bag and preventing the swarf following the strong magnet pull. How about a ferrous oil pot with that powerful magnet stuck to the bottom, on the outside, then in turn stuck to the mill table or wherever? |
Chris Mate | 13/08/2023 07:23:58 |
325 forum posts 52 photos | From a gift shop: They handle easy by hand and don't tip over easily. Edited By Chris Mate on 13/08/2023 07:29:25 |
