jon hill 3 | 19/06/2023 22:30:32 |
166 forum posts 40 photos | I was reading a piece on making a 'finger plate' which is basically a low profile v block with clamp and was wondering what was the best way to cut the v channel? The artical recommended using an end mill re-ground to a 90deg point or commercial cutter. I discounted the first option as it might be too advanced for my skills and the second possibly very expensive. So that leaves setting the work at 45deg and using a normal end mill, something I havent done before. The other option I thought of was using a gear hobbing cutter in the lathe mounting the work to the cross slide, effectivly making the lathe a horizontal mill. Has anyone done this on a speed 10 or similar machine? |
Peter Cook 6 | 19/06/2023 22:48:16 |
462 forum posts 113 photos | Posted by jon hill 3 on 19/06/2023 22:30:32:
So that leaves setting the work at 45deg and using a normal end mill, something I havent done before. Click spring does exactly that about 2 minutes into this video. Finger Plate Clamping Tool (clickspringprojects.com) |
Chris Mate | 19/06/2023 22:51:54 |
325 forum posts 52 photos | I'Ive done it with 12mm endmill milling head at 45 angle. The with of grove cut by cutter not more that cutter with in this case 12mm, the lenght of endmill cut one side, no problem for depth, but the bottom of cutter limit to 12mm, if you go deeper at angle it gets tricky to maintain smooth end result on one side. You could swop the block around so it cuts on lenght of cutter both sides, groove in centre provides relief space. |
Nigel Graham 2 | 19/06/2023 23:46:17 |
3293 forum posts 112 photos | If using a commercial vertical-milling profile cutter is too expensive then using a gear-cutter ( not a gear-hobbing cutter, a totally different beast) certainly would be - even if a gear-space section channel does not matter. You don't quote the finger-plate's thickness. They are not usually very thick, and you could well at least rough out the Vee by saw to leave just a thin surface layer to mill to a tidy finish. Even, since a Vee finger-plate is not normally a precise thing like a Vee-block, saw and file to a effective shape with reasonable quality finish, in not much more time than it would take to set up and machine it. Either way I would drill a small root-hole ( 3- 5mm dia) centred on the Vee intersection first. |
Hopper | 20/06/2023 01:46:23 |
![]() 7881 forum posts 397 photos | A gear cutter is not a straight-sided 90 degree V profile as needed for the finger plate. It will give you an involute shaped deep V.. You could do it perhaps with a fly cutter held in the lathe. Grind the end of the flycutter tool bit to the required 90 degrees. |
Thor 🇳🇴 | 20/06/2023 05:42:55 |
![]() 1766 forum posts 46 photos | Hi Jon, I simply used a rotary file to mill the V shape since I had one, see here. I have also used a multiflute contersink. Thor |
Nicholas Farr | 20/06/2023 06:46:41 |
![]() 3988 forum posts 1799 photos | Hi Jon, I did two, one about 11mm wide and one about 6mm wide, in a 500mm long piece of 50 x 50mm square block of steel. I just clamped the block down into a couple of Vee blocks, and used an end mill. This is used for folding sheet metal. Regards Nick. |
JasonB | 20/06/2023 06:52:02 |
![]() 25215 forum posts 3105 photos 1 articles | Depends what you call expensive and how big a groove you want but something like the 6mm here (size I tend to use) one should do and then you have a tool that will do quite a few other things as well. Work at an angle is easy enough too |
Speedy Builder5 | 20/06/2023 08:28:54 |
2878 forum posts 248 photos | Sometimes a simple wooden jig will suffice. Choose a hard wood like oak or ash. These are a couple of door stops I made for an older Toyota jeep where I had to mill out a section on the slant. To stop things moving about, I put a bolt through one of the holes and a tool makers clamp to stop the component lifting off of the jig Edited By Speedy Builder5 on 20/06/2023 08:29:35 |
jaCK Hobson | 20/06/2023 08:41:06 |
383 forum posts 101 photos | As the fingerplate is small, I just clamped in vice at 45 degrees. But I don't know any better. |
Mike Hurley | 20/06/2023 09:59:28 |
530 forum posts 89 photos | No matter how you end up doing it, remember it needs to be an reasonably accurate 45% (or as near as practical). If not, when you use it for drilling via the guide bush your holes may not be as centralised as you thought they may be! A 90deg cutter could be reasonably sourced if you shop around, and you will probably find it useful in the future. However, if you have some decent angle setting device then setting it at 45 in a vice etc and using and ordinary cutter will work fine good luck, regards Mike |
Nigel Graham 2 | 20/06/2023 10:20:39 |
3293 forum posts 112 photos | Sorry - I misunderstood the Vee-shape in my earlier post, to mean in the finger-clamp itself. Though not universal, many Vee-blocks are made with a small rectangular groove along the base of the Vee. I think this is more common on blocks made on a shaper (indicated by the tooling marks), but will provide some clearance for the tip of an end-mill used for the sloping sides. It can be cut with a slitting saw or if shallow enough, a slot-drill, as a first operation. A tilting vice is advantageous for this sort of work, but turn the block round for the finishing cuts to make the Vee-groove symmetrical by balancing any slight tilt-angle error. . One little detail addition to a finger-plate as shown by Jack Hobson, is a small tapped hole in the broader vertical face, to take a simple end-stop for repeated work. This is also applicable to larger Vee-blocks and machine vices. |
Oldiron | 20/06/2023 11:56:47 |
1193 forum posts 59 photos | Posted by Speedy Builder5 on 20/06/2023 08:28:54:
Sometimes a simple wooden jig will suffice. Choose a hard wood like oak or ash. These are a couple of door stops I made for an older A little off topic but I take the chance of being called pedantic. Calling a Toyota a Jeep is like calling a Ford a Vauxhall or a Bridgeport a Proxxon. I get really annoyed when people call my Nissan a Jeep. Ok will run & hide now. regards |
Speedy Builder5 | 20/06/2023 12:10:34 |
2878 forum posts 248 photos | Oldiron - I didn't think many members would know what an FJ40 was ! |
jon hill 3 | 20/06/2023 12:50:39 |
166 forum posts 40 photos | Thanks guys, lots of useful ideas. Jason B I didnt think these style of cutters could be bought so cheaply, good to know. I think I might have confused my terminology when refering to gear hobbing cutters, what I meant was a horizontal milling cutter for cutting v-grooves. If such a thing exists I presume it could be adapted to run on my ML10 on a suitable shop made mandrel possibly with tailstock support ? |
Nigel Graham 2 | 20/06/2023 13:35:50 |
3293 forum posts 112 photos | Yes, there are horizontal milling-cutters for cutting chamfers and Vee-grooves. You can't "adapt" them, but they do need a close sliding fit on a suitable mandrel run between centres. On a horizontal mill the cutter is often keyed to the mandrel but for using on a lathe or light mill, it's easier and probably safer to rely on just the friction of the nut and spacers against the clamping surface each side of the cutter. ARC, among others, sell short arbors with R8 or Morse-taper shanks, intended to be used with a drawbar on lathes or vertical mills. (Most lathes have Morse taper spindles.) The arbor has a tail-end centre-drilling for tailstock support. These suppliers may have the cutters too. You'd need make a suitable draw-bar, and a length of studding with nuts and a washer will suffice for occasional, light use.
Oldiron | 20/06/2023 13:50:45 |
1193 forum posts 59 photos | Posted by Speedy Builder5 on 20/06/2023 12:10:34:
Oldiron - I didn't think many members would know what an FJ40 was ! Very true. I never did understand why Toyota used the FJ (Fleetvan Jeep) designation when Jeep was a totally different company. I had an FJ60 for many years untill it rotted away under me. Now worth a lot of money if you can find a good one. I am a bit of a Classic 4x4 nerd. Still running my 1996 Patrol everyday which still runs a treat and is in excellent condition. ATB regards |
not done it yet | 20/06/2023 14:04:33 |
7517 forum posts 20 photos | Posted by Oldiron on 20/06/2023 11:56:47:
Sometimes a simple wooden jig will suffice. Choose a hard wood like oak or ash. These are a couple of door stops I made for an older A little off topic but I take the chance of being called pedantic. Calling a Toyota a Jeep is like calling a Ford a Vauxhall or a Bridgeport a Proxxon. I get really annoyed when people call my Nissan a Jeep. Ok will run & hide now. regards Not a lot different than calling all vacuum cleaners “Hoovers”? Bad enough when one cell is called a battery.🙂 Edited By not done it yet on 20/06/2023 14:04:49 |
roy entwistle | 20/06/2023 14:53:10 |
1716 forum posts | Nobody yet mentioned the difference between bulbs and lamps or pipes and tubes
Edited By roy entwistle on 20/06/2023 14:53:46 |
Michael Gilligan | 20/06/2023 14:53:20 |
![]() 23121 forum posts 1360 photos | Posted by Oldiron on 20/06/2023 13:50:45:
[…] I never did understand why Toyota used the FJ (Fleetvan Jeep) designation when Jeep was a totally different company. […] . Because, aside from being a Company Name, Jeep is a verbalisation of GP … which, in the US Military, stood for General Purpose MichaelG. |
