Name of tools used to loosen or tighten the retaining bolt on mill tool holders.
Will Robertson | 24/03/2023 19:23:00 |
![]() 162 forum posts 41 photos | I'm really sorry to ask such a basic question. What's the right name for the tools used to loosen or tighten the retaining bolt on these tool holders for the mill? It's a European mill and metric. |
Jelly | 24/03/2023 19:33:22 |
![]() 474 forum posts 103 photos | The name I'm familiar with is the highly unimaginative "Shell Mill Arbour Spanner", although as most shell mill arbours use a nut with four cut-outs, they also get called a "Cross Spanner".
If you're struggling to source a two lobed spanner for it, you might find that a drum key (as used for opening 205 drums) will work on yours depending on dimensions (hard to have a sense of scale, but those look a bit like iso 50 holders) else I'd probably manufacture a beefy pin spanner from some scrap or buy a cross spanner and grind two lobes off. Edited By Jelly on 24/03/2023 19:40:02 |
old mart | 24/03/2023 19:39:30 |
4655 forum posts 304 photos | They may not have a name because they are likely to be proprietry tools which only fit those cutters. I would unscrew them with a drift and see if it was easy to make something more spanner friendly. The heads will have to be low profile, though, I made a strange mark across the work surface when the SHCS on a new shell mill contacted before the inserts did, due to an over thick washer. |
SillyOldDuffer | 24/03/2023 19:42:46 |
10668 forum posts 2415 photos | Pin spanner? They're easy to make. Dave |
not done it yet | 24/03/2023 21:26:28 |
7517 forum posts 20 photos | Posted by SillyOldDuffer on 24/03/2023 19:42:46:
Pin spanner? They're easy to make. Dave Or “peg”? Usual reference is about trying to‘fit a square peg in a round hole’.🙂 |
Nick Wheeler | 24/03/2023 22:33:55 |
1227 forum posts 101 photos | Posted by old mart on 24/03/2023 19:39:30:
They may not have a name because they are likely to be proprietry tools which only fit those cutters. I would unscrew them with a drift and see if it was easy to make something more spanner friendly. Weld a couple of suitably sized/spaced blocks to a piece of steel strap to make a custom spanner. That's what, five minutes work in total? Edited By Nick Wheeler on 24/03/2023 22:34:29 |
Dave Halford | 24/03/2023 22:42:45 |
2536 forum posts 24 photos | Looks like a plumbers basin wrench might fit the bigger nut with a little grinding |
Will Robertson | 25/03/2023 17:34:01 |
![]() 162 forum posts 41 photos | Thank you very much!
John Reese | 28/03/2023 18:03:29 |
![]() 1071 forum posts | I don't think that spanner has a specific name. It is quite easy to make one on the lathe and mill. Just about a half hour to make it. Less if you have a piece of tubing about the right size. Don't bother figuring out a handle. Just cross drill for a tommy bar. |
Martin Cargill | 28/03/2023 19:09:38 |
203 forum posts | We used to make tools for that job from old 1/2" sockets with two pieces of key steel welded to the outside.
Nick Wheeler | 28/03/2023 19:26:59 |
1227 forum posts 101 photos | Posted by Martin Cargill on 28/03/2023 19:09:38:
Noted. That's even better than my suggestion. |
malcolm wright 3 | 28/03/2023 22:29:34 |
5 forum posts |
This is a bit pricy but looks like what you need.
not done it yet | 29/03/2023 07:21:03 |
7517 forum posts 20 photos | Posted by Martin Cargill on 28/03/2023 19:09:38:
A simple solution if one has a welder. Another alternative is to turn a lump of steel to a suitable diameter and mill across the centre and sides to provide the pegs. Maybe a hole through the bar for a tommy bar. Job done. Either way, I would most certainly not be shelling out £130 for a fancy tool - unless I had a very large number of these bolts or nuts (in different sizes) to loosen/tighten on a regular basis. |
Will Robertson | 03/04/2023 23:26:58 |
![]() 162 forum posts 41 photos | I eventually found the right set of 8 tools - the seller was selling them as "Spannschlussel" so I don't think he was sure of the formal name for them either - Spannschlüssel covers a fairly wide range of tools in German. Would also have been fun to make them on the lathe and mill. |
