Member postings for malcolm wright 3
Here is a list of all the postings malcolm wright 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Name of Tools Used for Mill Tool Holder Retaining Bolt
28/03/2023 22:29:34
amazon
This is a bit pricy but looks like what you need.
Thread: LED lamp help please
10/07/2022 20:47:59
The BAT41 is a Schottky diode which requires a forward voltage to switch on, i.e. 200mV at 25deg C.
It is only rated at 100mA so you might need something that will carry a bit more current. but before buying diodes I would check the data sheets for the solar panels as a lot of them have a built in diode.
Thread: From where I might be able to source some 1300 micron (1.3mm) mild steel sheet?
19/10/2021 20:05:21
These days sheet steel is generally below nominal thickness, so 1.5mm sheet would actually be 1.4mm.
Thread: Taps and Dies
13/07/2021 20:10:01
Metric coarse is standard for nuts & bolts etc, if a supplier does not state coarse or fine they will be coarse.
Thread: valve timing help needed!!!
28/01/2021 17:38:19
Check out Keith Appleton on youtube, he has several videos on valve timing.
