petro1head | 23/03/2023 10:04:40 |
![]() 984 forum posts 207 photos | I have noticed on a few YouTube vids people using a 6 jaw chuck I am curious as to the advantage of this |
Martin Kyte | 23/03/2023 10:07:52 |
![]() 3445 forum posts 62 photos | Far more support to the workpiece. More jaw less gap. Collets are better still. regards Martin |
Hopper | 23/03/2023 10:39:59 |
![]() 7881 forum posts 397 photos | Good holding power for precision work on bigger lathes with high cutting forces. But if the stock is a bit out of round or rough, a three-jaw will often give better grip. You absolutely don't need a six jaw chuck on the average hobby lathe. |
Henry Brown | 23/03/2023 10:50:22 |
![]() 618 forum posts 122 photos | When I was on the handles we only used 4 jaw chucks for big work where large depth of cut/high feed was used, 3 jaw chucks were occasionally used for light work and capstans for round and hex repetition stuff. The 120" chuck on the Webster & Bennett vertical borer that they had only used 4 jaws or the chuck was used as a faceplate. I can't remember seeing 6 jaws in the UK workshops I've been in and as Hopper says they are only really any use for good symetrical stock if they work on the scroll mechanism that most 3 jaw chucks have. Edited By Henry Brown on 23/03/2023 10:52:39 |
petro1head | 23/03/2023 10:54:12 |
![]() 984 forum posts 207 photos | Thanks, like i say, it was just out of interest, not going to buy one |
Martin Kyte | 23/03/2023 11:09:19 |
![]() 3445 forum posts 62 photos | Our mechanical workshop has several. They are particularly useful for reducing distortion when holding bored out components with thin walls. Chuck a bit of tube in a 3 jaw and bore it. When it comes off the machine the bore will be trilobite to a degree. regards Martin |
Andrew Tinsley | 23/03/2023 12:03:35 |
1817 forum posts 2 photos | I use one for the opposite reasons given above, they are ideal for turning large diameter rings that are of thin section. Much better than a 4 jaw at holding shape. I was given an old stock, unused Pratt Burnered 6 jaw with five sets of jaws all different. It must have cost a fortune. I would not buy one for the amount of work that it has done. But is very useful when needed. Andrew. Edited By Andrew Tinsley on 23/03/2023 12:04:05 |
Martin Kyte | 23/03/2023 12:19:00 |
![]() 3445 forum posts 62 photos | Posted by Andrew Tinsley on 23/03/2023 12:03:35:
I use one for the opposite reasons given above, they are ideal for turning large diameter rings that are of thin section. Much better than a 4 jaw at holding shape. I was given an old stock, unused Pratt Burnered 6 jaw with five sets of jaws all different. It must have cost a fortune. I would not buy one for the amount of work that it has done. But is very useful when needed. Andrew. Edited By Andrew Tinsley on 23/03/2023 12:04:05 I thought that was exactly what I said? regards Martin |
Robert Atkinson 2 | 23/03/2023 13:50:44 |
![]() 1891 forum posts 37 photos | Posted by Martin Kyte on 23/03/2023 11:09:19:
Our mechanical workshop has several. They are particularly useful for reducing distortion when holding bored out components with thin walls. Chuck a bit of tube in a 3 jaw and bore it. When it comes off the machine the bore will be trilobite to a degree. regards Martin How do you make an extinct arthropod out of a bit of tube?
Martin Kyte | 23/03/2023 13:58:38 |
![]() 3445 forum posts 62 photos | Not only that but an educated one too. I obviously meant Tri-lobate. Blasted auto correct , at it again. 😵💫 |
Clive Foster | 23/03/2023 14:02:28 |
3630 forum posts 128 photos | Posted by Robert Atkinson 2 on 23/03/2023 13:50:44:
Sedimentary my dear Robert. The drill sharpening device one my Clarkson Tool and Cutter grinder has a 6 jaw chuck to accurately hold all the drill sizes within its range. 6 jaws are needed to retain concentricity when gripping on teh webs. The sharpener rotates to generate the drill point so, presumably this geometry requires the drill point to be concentric to the rotation axis regardless of size. A simple Vee trough and top clamp will hold a goodly range of sizes but the point height must vary with size. Clive Edited By Clive Foster on 23/03/2023 14:05:01 |
Harry Wilkes | 23/03/2023 15:16:52 |
![]() 1613 forum posts 72 photos | Without going into the pro's n con's you find on youtube on creator fits a 6 jaw chuck then other do bit like when someone put a steering wheel on their mill everyone got on the band wagon H |
Grindstone Cowboy | 23/03/2023 15:26:22 |
1160 forum posts 73 photos | +1 on what Harry says - afraid it's the nature of the beast that is Youtube. Rob |
Dave Halford | 23/03/2023 17:08:50 |
2536 forum posts 24 photos | Rotagrip lists them as a drill grinding chuck. |
Mike Poole | 23/03/2023 17:18:43 |
![]() 3676 forum posts 82 photos | I notice Stefan Gotteswinter uses a 6 jaw chuck, he doesn’t seem to be a man who would not have a very good reason to use one when required. |
old mart | 23/03/2023 17:40:41 |
4655 forum posts 304 photos | The six jaw chucks intended for holding drills have very thin teeth as they are then able to grip smaller drills. The type with conventional jaws work well with thin wall tubes as already mentioned, quicker than machining special soft jaws to reduce the distortion with a three jaw chuck. The cheap six jawed chucks only have internal jaws, and the high end ones with both sets cost an arm and a leg, one reason why I have never bought one. They can suffer the same shortcomings as self centralising four jaw chucks, if the workpiece is a perfect cylinder, the clamping will vary and if the workpiece is not a perfect cylinder the same happens, something not present in a three jaw chuck. |
noel shelley | 23/03/2023 18:00:52 |
2308 forum posts 33 photos | Yep ! six jaw on drill grinders, though early Brierleys had 4 Jaw ! Noel. |
Andrew Tinsley | 23/03/2023 19:02:42 |
1817 forum posts 2 photos | Thanks Old Mart, Now I know what the very slim set of jaws are for. It had puzzled me for years! Andrew. |
old mart | 23/03/2023 19:38:47 |
4655 forum posts 304 photos | Cutwel used to list an eight jaw chuck on their website. |
