petro1head | 22/03/2023 12:47:41 |
![]() 984 forum posts 207 photos | Looking to replace the nuts that hold the chuck to the lather with flanged ones Will stainless one be ok? Edited By petro1head on 22/03/2023 12:47:52 |
Hopper | 22/03/2023 12:53:37 |
![]() 7881 forum posts 397 photos | One thing about those fiddly nuts behind the chuck is you want them to be easy to get off. Those kind of locking flange nuts may not be so easy. And stainless threads can tend to gall and seize up. I would stick with what the lathe manufacturer used. |
HOWARDT | 22/03/2023 12:56:04 |
1081 forum posts 39 photos | Ideally from a strength point of view, particularly on a 5” or larger chuck, I would prefer steel nuts. Stainless nuts tend to have a lower yield, having said that I use M6 on my flange mounted chucks but only 100mmm. Also use plain flanged nuts if you want not the locking nuts shown in your photo, those will chew up the face with repeated release. |
Bo'sun | 22/03/2023 13:22:19 |
754 forum posts 2 photos | Flange nuts from a tee nut clamping system work fine for me. |
petro1head | 22/03/2023 13:42:56 |
![]() 984 forum posts 207 photos | Posted by Bo'sun on 22/03/2023 13:22:19:
Flange nuts from a tee nut clamping system work fine for me. Good idea |
mgnbuk | 22/03/2023 14:17:44 |
1394 forum posts 103 photos | Zoro list Grade 10 flanged nuts as well as Grade 8 in BZP steel. There are a number of sellers of Grade 8 BZP steel flanged nuts on Ebay (serrated or plain). Nigel B
Vic | 22/03/2023 18:07:54 |
3453 forum posts 23 photos | Posted by petro1head on 22/03/2023 12:47:41:
Looking to replace the nuts that hold the chuck to the lather with flanged ones Will stainless one be ok? Edited By petro1head on 22/03/2023 12:47:52 I use those, they’ve worked fine so far. |
Bill Phinn | 22/03/2023 18:17:51 |
1076 forum posts 129 photos | Grade 10 BZP flanged nuts [DIN 6923] are usually smooth rather than serrated. You might prefer that. The black oxide flanged nuts that come in 58 piece clamp kits are usually non-serrated as well, and their height is usually more generous to get a spanner on, but still not as generous as a DIN 6331 flanged nut. Unfortunately, DIN 6331 nuts are very expensive compared with the DIN 6923 variety. You've probably got limited space behind the chuck, though, so extra nut height won't be wanted. Edited By Bill Phinn on 22/03/2023 18:20:00 |
Howard Lewis | 22/03/2023 18:19:50 |
7227 forum posts 21 photos | Flanged (Washer Faced) nuts will be OK, if there is room for the flange.. But NOT the self locking ones shown. You do want to slacken them to take off the chuck at some time in the future, don't you? The M6, 10mm A/F nuts are easy to drop. Make up the extremely simple Widget designed my Danny M2Z. Very simple and effective. Howard |
Bill Phinn | 22/03/2023 18:21:41 |
1076 forum posts 129 photos | Posted by Howard Lewis on 22/03/2023 18:19:50:
I wouldn't describe a nut having a serrated flange as a self-locking nut, Howard. They're very easy to undo, even if they can leave marks on the surface of the clamped material. Edited By Bill Phinn on 22/03/2023 18:22:19 |
JasonB | 22/03/2023 18:42:21 |
![]() 25215 forum posts 3105 photos 1 articles | It would be easy enough to skim the serrations off most of the flange nuts found on the web, me I'm still happy to use nuts and separate washers as Mr Warco intended |
Journeyman | 22/03/2023 18:47:27 |
![]() 1257 forum posts 264 photos | I use flange nuts on my WM250. It saves faffing about with nuts and washers in the very tight space, about 15mm, between the flange and the headstock. Couldn't find smooth faced flange nuts so made a threaded mandrel and turned the serrations off. Mine are just bog standard BZP nuts. Seem to work quite well, I don't think they actually take much load, certainly not done up particularly tight. John |
Howard Lewis | 22/03/2023 18:52:42 |
7227 forum posts 21 photos | Bill, They may not be self locking in the sense that Nyloc ones are but rest assured that the serrations resist rotation for removal. We used similar bolts to retain Flywheel Housings, for exactly that reason! And as you say, are likely to mark nthe surface, confirming a certain amount of digging in. Such fixings ar eintended mfor clamping parts thatn are notb intended mto be separatedn frequently, if at all. For clamping a chuk to a backplate, the friction between the threads should suffice is correctlyntorqued mup. How mmany chucks come loose on the many mini lathes around the world? Howard Edited By Howard Lewis on 22/03/2023 18:54:08 |
petro1head | 22/03/2023 19:06:04 |
![]() 984 forum posts 207 photos | I found some High Tensile Din 6923 steel ones with a flat back so have ordered them |
Tony Pratt 1 | 22/03/2023 20:33:40 |
2319 forum posts 13 photos | Posted by Journeyman on 22/03/2023 18:47:27:
I use flange nuts on my WM250. It saves faffing about with nuts and washers in the very tight space, about 15mm, between the flange and the headstock. Couldn't find smooth faced flange nuts so made a threaded mandrel and turned the serrations off. Mine are just bog standard BZP nuts. Seem to work quite well, I don't think they actually take much load, certainly not done up particularly tight. John I did exactly the same John, after reading your web page 😀 Tony |
petro1head | 22/03/2023 20:54:56 |
![]() 984 forum posts 207 photos | Posted by Journeyman on 22/03/2023 18:47:27:
I use flange nuts on my WM250. It saves faffing about with nuts and washers in the very tight space, about 15mm, between the flange and the headstock. Couldn't find smooth faced flange nuts so made a threaded mandrel and turned the serrations off. Mine are just bog standard BZP nuts. Seem to work quite well, I don't think they actually take much load, certainly not done up particularly tight. John Is your lathe new? |
Journeyman | 23/03/2023 06:53:01 |
![]() 1257 forum posts 264 photos | Posted by petro1head on 22/03/2023
Is your lathe new? No, 2007 vintage, more detail on Journeymans Workshop John |
petro1head | 23/03/2023 08:11:26 |
![]() 984 forum posts 207 photos | From you photo it looks mint |
