Richard B | 05/03/2023 18:36:45 |
31 forum posts 35 photos | I use a Record number 0 vice (2 1/2" jaw size) for much of my modelling and use fibregrip jaws - Irwin I think was the manufacturer. I'm on my last set of the fibregrips and cannot find anybody that sells them to suit the 2 1/2" jaw size. Anybody know of a supplier ? |
DMR | 05/03/2023 20:37:11 |
136 forum posts 14 photos | You need to ask Google for Record Imp vice jaws. Dennis |
Bill Davies 2 | 06/03/2023 00:26:40 |
357 forum posts 13 photos | It's a bit late (and cold) to check in my shed, but I think No. 0 is 2 -1/2 ins wide, Imp is 2-1/4 ins. Bill |
David Ambrose | 06/03/2023 08:28:58 |
55 forum posts 4 photos | I bought a 3 inch pair and milled them down to size. They were Warco I think, and the magnets weren’t in the milling zone. |
V8Eng | 06/03/2023 09:32:20 |
1826 forum posts 1 photos | Chronos keep a good range I do not know if they go down to 2 1/2” though (long time since I bought any). Edited By V8Eng on 06/03/2023 09:37:39 |
bernard towers | 06/03/2023 16:49:17 |
1221 forum posts 161 photos | toolstation stock magnetic ones |
Richard B | 06/03/2023 18:36:44 |
31 forum posts 35 photos | I've tried E bay, googled to death and all my usual suppliers - no joy. Seems 2 1/2" is no longer made. I rather like the fibregrip ones with steel frames that wrap around the jaws and stay in place. I think I'll have to get bigger ones and try to cut down or just use the fibre material and rivet to an old set, however the old steel frames are getting a little worn ! |
Grindstone Cowboy | 06/03/2023 21:45:32 |
1160 forum posts 73 photos | Partial thread hi-jack, sorry! Where can one obtain the red fibre material in thicknesses suitable for vice jaws? All I've found is quite thin. I have some Draper soft jaws (aluminium extrusions) faced with a soft rubbery material that are pretty much useless, but could be refaced with fibre if I could find some thick enough, say 1/4". Thanks, Rob |
bernard towers | 07/03/2023 14:09:19 |
1221 forum posts 161 photos | Can't find the fibre material but would imagine that HDPE sheet would be good. |
Michael Gilligan | 07/03/2023 15:30:56 |
![]() 23121 forum posts 1360 photos | Is this the stuff ? https://www.rhnuttall.co.uk/materials/vulcanised-fibre/ MichaelG. |
Richard B | 07/03/2023 16:39:40 |
31 forum posts 35 photos | Rob, No idea where to buy the material but if your vice is fairly standard Record type etc, then the Fibre grip soft jaws would be a good option if above 3" - plenty available. Come mounted to a thin steel frame - just tap the end flanges around the vice to secure. Here is a typical E bay listing for 3" ones Item number 302801094456 Just cut and paste it into the E bay search bar.
Richard B. |
Nicholas Farr | 07/03/2023 17:05:03 |
![]() 3988 forum posts 1799 photos | Hi, I believe the No. 0 vice Richard means is the one in the list in the scan below. The Fibre Grips he is looking for, I believe are in this scan below. I do not know where to get any from now though. Regards Nick. |
Grindstone Cowboy | 07/03/2023 17:15:28 |
1160 forum posts 73 photos | Thanks for the pointers, chaps, very useful. That looks like the correct material, Michael. Rob |
Bazyle | 07/03/2023 19:52:01 |
![]() 6956 forum posts 229 photos | I just use wood. Available in a range of hardness values from your local firewood stockist (aka skip). |
Martin Shaw 1 | 07/03/2023 21:28:50 |
185 forum posts 59 photos | Record are now owned by Irwin and you can get soft jaws for 1/2/3 size vices from RS, at some price increase from the displayed advert above. |
Daggers | 08/03/2023 09:56:31 |
52 forum posts | Try contacting knife making suppliers such as www.english-handmade-knives.co.uk they list red fibre sheet up to 3mm and black up to 6mm, although the 6mm is at the moment out of stock. But it might be worth a call as they also sell G10 which might do the job. You could also try bonding two 3mm thick strips to make 6mm.
Men Ifr | 14/05/2023 23:18:08 |
119 forum posts 10 photos | Hi all, bit of an old thread but I was also dissappointed with the draper / magnetic style and started making custom fit vice jaws I intend to make sets for all record vices once I get all the dimensions (jaw height is what I need). I can make a set up if you are interested and am looking for people who could measure the jaw height and provide photos once fitted. |
