Robert Atkinson 2 | 16/02/2023 20:32:21 |
![]() 1891 forum posts 37 photos | Having seen the discussion here: Robert. |
noel shelley | 16/02/2023 21:17:28 |
2308 forum posts 33 photos | Thanks for that, Ely isn't far from me either. Noel |
Bazyle | 16/02/2023 21:46:31 |
![]() 6956 forum posts 229 photos | Unless it is actually raining inside you workshop what is wrong with a cotton sheet, maybe with a wool blanket over that. |
Martin Kyte | 16/02/2023 21:46:34 |
![]() 3445 forum posts 62 photos | Me neither, just up the road |
samuel heywood | 17/02/2023 00:15:26 |
125 forum posts 14 photos | Posted by Bazyle on 16/02/2023 21:46:31:
Unless it is actually raining inside you workshop what is wrong with a cotton sheet, maybe with a wool blanket over that. I believe cotton readily absorbs & holds water? Ditto wool, though i seem to recall woollen holds onto absorbed water rather than giving it up again. Rust City? I may be wrong but merely cite it as a possibility.
Chris Mate | 17/02/2023 03:07:16 |
325 forum posts 52 photos | I am using motorcycle cover for lathe, must still get one for mill. |
Joseph Noci 1 | 17/02/2023 05:27:44 |
1323 forum posts 1431 photos | Posted by Chris Mate on 17/02/2023 03:07:16:
I am using motorcycle cover for lathe, must still get one for mill. Likewise:
Circlip | 17/02/2023 09:48:30 |
1723 forum posts | Lot to be said for a 50w (incandescent) lamp under the covers or one of the modern low wattage heater bars. Regards Ian. OR a Piano heater bar - 25w Edited By Circlip on 17/02/2023 09:53:27 |
jaCK Hobson | 17/02/2023 10:03:00 |
383 forum posts 101 photos | I now use a picknick blanket - waterproof membrane one side and wool-like on the other. |
Tony Pratt 1 | 17/02/2023 11:20:21 |
2319 forum posts 13 photos | I use a cover to keep off dust etc but no cover will stop rust through condensation, it’s just physics😉 Tony |
Bazyle | 17/02/2023 11:36:04 |
![]() 6956 forum posts 229 photos | We have had a lot of discussion on this. Condensation happens, especially as this week when warm wet air replaces a cold dry period. It falls like dew sometimes imperceptibly and causes just a little rust each time. You see this in some workshops as the top side of metal objects being rusty but the underside perfectly clean. |
Robert Atkinson 2 | 17/02/2023 12:33:26 |
![]() 1891 forum posts 37 photos | There are multiple causes of moisture anad rust in the workshop. My "workshop" is just a garage with no heating but two walls are shared with the house so some heat transfer. It has two main problems. The occasional drip from above from either condensation or rain being blown under roof lap joints under certain conditions. Sudden ingress of moist air when the door is opened. It's a roller shutter type. I tried a cotton cover but in current conditions it ends up holding moisture. Whenever the air is dry I remove the covers to release any trapped moisture. Moist air is lighter than dry so can be trapped. I have a plan for the roof and to better seal the top of the roller shutter but they will have to wait for better weather. |
Howard Lewis | 17/02/2023 13:52:16 |
7227 forum posts 21 photos | FWIW In my shop nothinbg is covered, but it is well insulated, ()Walls, and Roof, floor is 3/4 ply on 8 x 2 bearers, surrounded on 3 sides by a fence or a wall Small fixed vents at high and low level When there is persistent frost, a 60 watt tubvular heater, under the bench is switched on. The mini lathe (secondhand) came with a MDF cover, and lives in the garage. The bandsaw is now too heavy ( i e I'm too weak ) to lift from from floor level to the 9 inches or so into the shop. SAo it lives outside, under a professioinally made, box like cover made from curtainsider material (Cost £52 some years ago ) In none of the xzases is rust a problem. Helped by an occasional spray of oiul for the mini and the bandsaw. Howard |
Martin Kyte | 17/02/2023 15:35:27 |
![]() 3445 forum posts 62 photos | People keep talking about sudden ingress of moist air from outside and when the humidity is high outside etc. It’s not necessary so. For example air at 6 degrees and 82% RH contains 5 g of water per kg of air. Air at 18 degrees and 50% RH contains 6.45g of water per kg of air. So the 82% RH air is dryer than the 50% RH air in as far as it contains less water. So allowing the outside air in this case to enter the warmer workshop would actually make the workshop dryer. It’s not always the case but you have to do the numbers to know. Counter intuitive but there you are. Generally extract fans to expel warm wet air from a building serve you well. regards Martin |
Coggy Clapsaddle | 17/02/2023 16:11:35 |
16 forum posts 3 photos | I've been covering most of my machines with old sleeping bags for years, they can be picked up cheap from charity shops cheaply and sometimes if you ask they might have one or two out back with broken zips that are going into the rubbish, a small thank-you donation gets cheaply and helps them out. I've not suffered any rust problems on them yet. |
