wayne ollerenshaw | 23/12/2022 19:41:39 |
40 forum posts 4 photos | Ok i have googled etc etc and still cant get my head in gear.
In simple, can and how do i reverse this motor please.
Les Jones 1 | 23/12/2022 22:26:27 |
2292 forum posts 159 photos | I SUSPECT that swapping over the blue wire that comes from the top middle terminal to the top left terminal with the brown wire that comes from the top right terminal to the bottom left terminal will reverse the motor. DO NOT try this without verifying that my assumptions are correct. 2 Verify that the main winding is connected between top middle terminal and the bottom left terminal 3 Verify that the start winding is connected between top left terminal and the bottom middle terminal. Les. |
Emgee | 23/12/2022 22:30:12 |
2610 forum posts 312 photos | Hi Wayne Yes you can reverse the motor, appears to be cap start so you need to establish the ends of the start winding so you can change them around, that will reverse the direction. Emgee Edited By Emgee on 23/12/2022 22:32:45 |
Pete Rimmer | 24/12/2022 06:56:27 |
1486 forum posts 105 photos | No sticker on the inside of the junction box cover Wayne? That's usually where the diagram is. |
vic newey | 24/12/2022 10:12:46 |
![]() 347 forum posts 173 photos | The terminals appear to be numbered, I can see a 3 and a 4 and bottom left UI ? Edited By vic newey on 24/12/2022 10:16:10 |
wayne ollerenshaw | 24/12/2022 11:39:45 |
40 forum posts 4 photos | Excellent chaps thanks. Once my head is straight and stopped wobbling ill see about the windings. Had a bottle to many last night. All best for tomorrow and new year chaps I need to sort my head out with electrics soon enough as my workplace want me to be the maintenance chap and go on a few courses. Head aches to come i reckon, not easy to to old dog new tricks haha |
noel shelley | 24/12/2022 13:24:26 |
2308 forum posts 33 photos | U1 and U2 are your run windings Z1 and Z2 are the start windings. To reverse the direction of rotation swap over Z1 and Z2. Noel. |
larry phelan 1 | 24/12/2022 16:54:01 |
1346 forum posts 15 photos | Too many bottles+ too many wires= bad mix ! Ask me how I know ! |
wayne ollerenshaw | 19/01/2023 22:18:08 |
40 forum posts 4 photos | Posted by noel shelley on 24/12/2022 13:24:26:
U1 and U2 are your run windings Z1 and Z2 are the start windings. To reverse the direction of rotation swap over Z1 and Z2. Noel. Thank you, i had to remove the block and i managed t JUST see the tags on the cables to swap them over.
Also thanks to the other for the help |
noel shelley | 20/01/2023 10:44:07 |
2308 forum posts 33 photos | Glad to have been able to help. If you can run it on a contactor/ overload protection, it is a good motor. Noel. |
