Confused by a magnet
Michael Gilligan18/12/2022 07:20:38
23121 forum posts
1360 photos
Browsing ebay last night, I spotted that Zoro is listing Eclipse Magnetics E1001/NEO at what appears reasonable price … but I’m confused by the product itself.
Farnell has the Eclipse data-sheet available: **LINK**
https://www.farnell.com/datasheets/2290329.pdf
… but I’m still confused.
Does the Zinc plated casing provide any useful functionality, or is it just a cheap way of making a small magnet look bigger ?
John Haine18/12/2022 07:43:21
5563 forum posts
322 photos
Virtue out of necessity I think. Usually they are plated with nickel, then copper then nickel I think as otherwise the material corrodes very quickly. Zinc is probably cheaper?
Michael Gilligan18/12/2022 08:09:14
23121 forum posts
1360 photos
Thanks, John … but it appears to be a casing rather than just a plating-job
DiogenesII18/12/2022 08:23:26
859 forum posts
268 photos
Perhaps a countersunk fixing could cause an unconstrained magnet to split if carelessly fixed.. ..is the housing to provide support..? 'containment'
Edited By DiogenesII on 18/12/2022 08:24:11
David Davies 818/12/2022 08:44:46
202 forum posts
Hi Michael,
I believe the”can” is there to complete the magnetic circuit. Once the “target” touches the face of the magnet a path exists for the magnetic flux to complete its circuit. For this to be so the “target” needs to be of sufficient diameter and aligned correctly to cover the can and magnet.
HTH
Kiwi Bloke18/12/2022 08:50:54
912 forum posts
Neodymium is too brittle, fragile and chemically 'active' to be used 'naked'. Hence the magnets are encased for mechanical and chemical protection, and the Zn plate is presumably to protect the case material against corrosion. It looks like the case also acts as a 'pot' magnet's peripheral pole piece, as suggested in the post above.
Edited By Kiwi Bloke on 18/12/2022 08:54:03
Michael Gilligan18/12/2022 09:08:47
23121 forum posts
1360 photos
Thanks, folks yes
That seems to make sense … now I’m just surprised to see how many ‘naked’ ones are around.
I suppose if anyone is going to do things right, it should be Eclipse
Edit: __ I’ve just ordered three, at Zoro’s attractive price.
Edited By Michael Gilligan on 18/12/2022 09:14:41
John Haine18/12/2022 10:11:35
5563 forum posts
322 photos
I think that neodymium nudity is very rare - every one I've ever seen is nickel plated at least. Once I managed to chip the coating off and the magnet quickly corroded.
**LINK** shows a pot magnet that definitely has a surrounding case - however you can clearly see the gap between the "pot" and the centre pole needed to make sure the flux isn't shorted. There is only a very thin line between the outside "pot" and the magnet face in the Eclipse photo though - but I notice that if you look at the screw hole it does look as if there's a plate at the bottom. You must tell us what you find Michael!
Hopper18/12/2022 10:25:50
7881 forum posts
397 photos
From the dreaded Wiki:
Sintered Nd2Fe14B [Neodymium] tends to be vulnerable to corrosion, especially along grain boundaries of a sintered magnet. This type of corrosion can cause serious deterioration, including crumbling of a magnet into a powder of small magnetic particles, or spalling of a surface layer.
This vulnerability is addressed in many commercial products by adding a protective coating to prevent exposure to the atmosphere. Nickel, nickel-copper-nickel and zinc platings are the standard methods, although plating with other metals, or polymer and lacquer protective coatings, are also in use.[21]
And
Magnets that get too near each other can strike each other with enough force to chip and shatter the brittle magnets, and the flying chips can cause various injuries, especially eye injuries.
So apart from corrosion and crumbling resistance, I guess if the posted countersunk variety were used naked in a contact situation, such as a cupboard door closer etc, the impact could shatter it without the zinc-plated envelope to hold it together.
Jon Lawes18/12/2022 10:28:06
1078 forum posts
Those Neodym magnets can really shatter into quite sharp shards.
Ady118/12/2022 10:56:53
6137 forum posts
893 photos
I've used the ebay 10mm ones over the years and they are extremely fragile
If you look at them the wrong way they break in half, but they still work fine
Edited By Ady1 on 18/12/2022 10:59:38
Tim Stevens18/12/2022 11:19:49
1779 forum posts
I agree with Ady 1 that Neo magnets from a well known web source are both fragile and rust prone once they are cracked. And some of them arrive like that - but they still work for attaching important (but temporary) papers to a tool box lid or the top of a mill column.
I suspect that as the Neo mix is chosen solely for its magnetic properties, it is not easy to form into shape by old-style methods. My guess is that sintering is used, and a quick flash of zinc is a good way to stop the rust while not affecting the dimensions significantly.
I await news from Michael G about what his magnets comprise when they arrive. If they arrive.
Cheers, Tim
peak418/12/2022 11:21:47
2207 forum posts
210 photos
Re Corrosion, see P92 of the eclipse Magnets & Magnetic Tools catalogue available for download from HERE
https://www.eclipsemagnetics.com/resources/?filter_related_product_type=2403&filter_resource_type=2398#resources
A very useful source of larger flat magnets, attached to a backing plate is redundant computer hard disk drives; there's two in each single platter drive.
Bill
Edited By peak4 on 18/12/2022 11:23:34
Michael Gilligan18/12/2022 11:33:53
23121 forum posts
1360 photos
Posted by John Haine on 18/12/2022 10:11:35:
I think that neodymium nudity is very rare - every one I've ever seen is nickel plated at least. […]
Sorry, John … cross-purposes … l was thinking more in terms of wearing [or not wearing] a jacket, rather than ‘body-painting’ blush
Yes, I will happily report on my purchase.
Edited By Michael Gilligan on 18/12/2022 11:35:50
Robert Atkinson 218/12/2022 12:18:18
1891 forum posts
37 photos
David Davies 8 is correct, the casing or "pot" is there to complete the magnetic circuit and increase the force. They are often called Pot magnets and existed before rare earth magnets.
The pot also protects a brittle magnet from direct impacts as a secondary benefit. Both magnet and pot are plated to prevent corrosion.
https://www.stanfordmagnets.com/what-are-the-types-of-pot-magnets.html
Robert G8RPI.
Andrew Tinsley18/12/2022 12:42:50
1817 forum posts
I looked up the magnets on the Zoro website. It describes the plating system and the reason why they are plated. Namely to protect against corrosion.
Andrew.
Michael Gilligan18/12/2022 14:53:11
23121 forum posts
1360 photos
Posted by Andrew Tinsley on 18/12/2022 12:42:50:
Andrew.
So did I, Andrew … my question was why there was a can around something which is commonly supplied ‘naked’ but plated.
peak418/12/2022 16:52:42
2207 forum posts
210 photos
Posted by Michael Gilligan on 18/12/2022 14:53:11:
Andrew.
See P93 of the catalogue I linked to in an earlier post, as well as Robert's link.
Bill
Michael Gilligan18/12/2022 17:03:22
23121 forum posts
1360 photos
Thanks, Bill
Sorry … I didn’t intend to revive the discussion by replying to Andrew blush
Having already looked at P93 and the other references, I was happy that my question had been answered.
When they arrive [at £1.75 each, post free] I will take a photo to better illustrate the construction.
Peter Greene18/12/2022 19:28:54
865 forum posts
12 photos
Lee Valley have been selling similar arrangements for years and have a somewhat explanation here.
(LV used to have such a nice, simple website with quite a lot of general background info pages - now it seems to have gone over to "Modern Busy" and if the background is still there, I don't have time to find it.)
Edited By Peter Greene 🇨🇦 on 18/12/2022 19:34:27
