re-use of gas springs
Frances IoM10/12/2022 23:01:15
1395 forum posts
30 photos
the NOx cylinder query prompts me to ask if there is any safe way to re-use the rams (+ tube) from gas springs - I have a few pairs of such, some were 'freebies' unbid-for that were bundled into lots I had an interest in - they are car parts ? for hatchbacks but too big + powerful for any use I can forsee
peak410/12/2022 23:49:33
2207 forum posts
210 photos
They are regularly used as a tensioner, rather than a coil spring, by folks who are building belt grinders.
The machines are often used for knifemaking and frequently feature a 2"x72" belt.
If I'm re-using something similar, normally a car shock absorber/damper, I just cut into the outer cylinder with a hacksaw, which releases the pressurised gas in a reasonably controlled manner.
Just keep it pointing downwards and cut the uphill bit, to save getting showered in the oily contents.
As an aside, if you ever get involved in dealing with a car fire, keep out of the line of fire behind the car, as I'm informed, by those who practice this stuff professionally, that they can explode and shoot out the ram like a crossbow bolt.
Bill
Pete Rimmer11/12/2022 01:15:10
1486 forum posts
105 photos
The rods are great for all kinds of stuff. I have used them for DTI mount arms.
Office chair rams are another great source of thick walled steel tubing with ground finish. You can turn off the end of the outer tube to release them but be damn sure that they are no longer charged with gas.
Peter Greene11/12/2022 01:36:40
865 forum posts
12 photos
This type of device can be used as a counterbalance for the (moving) head of small mills.
old mart11/12/2022 14:50:26
4655 forum posts
304 photos
I have some surplace ones, and agree with Peter, that they have potential with assistance with mill heads, if the overall lengths and stroke would match. I have thoughts about the knee of the Tom Senior light vertical which needs the longer handle fitted when the heavy rotary table is fitted. I bought a gas strut for replacing the seat strut on my Suzuki 400 Burgman, and after googling, found a firm which makes custom lengths, strokes, force and end fittings at very reasonable prices. I checked the force on the existing inadequate strut on the bathroom scales using a pad to protect the glass top and added 25% to custom strut power, and it is a great improvement.
old mart12/12/2022 18:10:15
4655 forum posts
304 photos
If a custom made strut is needed, I have found the firm who supplied my seat strut exactly the size I wanted.
Michael Gilligan12/12/2022 18:40:13
23121 forum posts
1360 photos
Posted by old mart on 12/12/2022 18:10:15:
That’s useful to know yes
… duly bookmarked.
Nick Wheeler12/12/2022 19:11:55
1227 forum posts
101 photos
You can also buy them too strong, and lower the pressure until you get what you need.
Ebenezer Good12/12/2022 22:40:34
48 forum posts
I ordered some from Ebay for my jeeps rear hatch, they are a lot more powerful than the originals, it now reminds me of Arkwright's till!
I've collected a few old shock absorbers with plans to use them for something but all I do is move them out of the way every few years.
Joseph Noci 113/12/2022 04:48:49
1323 forum posts
1431 photos
Posted by Ebenezer Good on 12/12/2022 22:40:34:
Thought I was alone in that...
Grindstone Cowboy13/12/2022 05:39:44
1160 forum posts
73 photos
Something I noted today, as the rear hatch of my car closed onto my head, is that they ain't as powerful in very cold weather.
Rob
Nick Wheeler13/12/2022 09:04:48
1227 forum posts
101 photos
That's the difference between new and knackered ones. You get the same effect with the shock absorbers; even ones that pass the 'bounce test' can be doing very little.
I have the rods from two pairs of front struts that look useful. They're 20mm hard chrome plated rods about 400mm long, and were free. One of the potential jobs is to make a taper turning attachment for my WM250
Douglas Johnston13/12/2022 11:49:29
814 forum posts
36 photos
Posted by Pete Rimmer on 11/12/2022 01:15:10:
How does one discharge the gas in order to cut them up safely, or do you just set the horizontal bandsaw up and run like hell ?
Doug
Frances IoM13/12/2022 12:02:43
1395 forum posts
30 photos
"How does one discharge the gas in order to cut them up safely, or do you just set the horizontal bandsaw up and run like hell ?" that's what I should have asked directly as the rods look too useful to sit around taking up space.
Nick Wheeler13/12/2022 13:20:01
1227 forum posts
101 photos
Posted by Frances IoM on 13/12/2022 12:02:43:
Chop the end off the cylinder with an angle grinder. There isn't much gas and/or oil in a good one, and tired ones are usually anti-climactic
But, ensure you're wearing goggles, and don't stand in line with the cut. If you're breaking down bigger gas springs, like the macpherson struts I mentioned, drill a small hole first.
