Robin | 12/10/2022 17:14:21 |
![]() 678 forum posts | I am mounting 2 XSY-AT1 VFD's using the 5mm bolt holes provided. I measure them with my new 200mm dial caliper. I drill them using 5 micron DRO scales for precise location. I go to insert a bolt and it doesn't fit. No room for the head. Curses, foiled again (I didn't mean to start a new chapter in the tea room, get it right next time maybe, Sorry!). Edited By Robin on 12/10/2022 17:19:21 |
Robert Holton | 12/10/2022 17:22:54 |
40 forum posts | That is an annoying problem. I presume you are fixing it to a bench, so why not grind the heads of your bolts to fit the machine, and then put nuts and washers on from underneath. Just a thought. Rob |
Martin Connelly | 12/10/2022 17:29:14 |
![]() 2549 forum posts 235 photos | They are clearly clearance holes for M3 plus a large washer Martin C |
not done it yet | 12/10/2022 17:38:18 |
7517 forum posts 20 photos | I go to insert a bolt and it doesn't fit. No room for the head. Maybe use a screw? Apart from possible errors with the new dial caliper or diameter selection? Which bit of the process are we talking about? Thoroughly amazing that they did not come predrilled properly. VFDs, btw, should be mounted inside a suitable electrical enclosure, not screwed to anything flammable. Likely all in the installation instructions…. But perhaps you are only sitting them on the bench at the moment Edited By not done it yet on 12/10/2022 17:53:42 |
Robin | 12/10/2022 17:51:50 |
![]() 678 forum posts | I have already painted myself into a corner. Luckily I spotted a liana hanging from a light fitting. This allowed me to swing up, Tarzan style, to get this aerial picture... |
alan ord 2 | 12/10/2022 19:34:43 |
![]() 145 forum posts 41 photos | Try cap head screws. |
Kiwi Bloke | 12/10/2022 20:54:58 |
912 forum posts 3 photos | Perhaps tap the holes, and fix from t'other side - to a sub-plate if no access from that side for fixing to whatever. One wonders how stuff can leave the factory with such howlers... |
Ian P | 12/10/2022 21:33:51 |
![]() 2747 forum posts 123 photos | I think its a bit unfair to blame the Chinese for this! The HuanYang inverters are a low cost commodity item and not perfect although the hole location is a bit of a howler. I can see also that if you have carefully prepared tapped holes than getting any standard M5 fixing is going to be a bit challenging. Judging from the picture I would say that if you reduced a slotted or Pozi head to 5.60mm diameter it would do the job. I have an expensive set of British made cast iron, machined all over (apart from the slots/holes) angle plates. A large proportion of the slots lengths are unusable because of the fillet between the internal faces. I cannot get to take a picture just now but have grabbed this picture off Google images that shows exactly (Well its 45 degree fillet on my plates but you get the idea). I see the same sort of out of proportion features, like massively wide slots on many pieces of workshop tooling and workholding items like lathe faceplates and machine vises. Ian P |
Michael Gilligan | 12/10/2022 21:46:32 |
![]() 23121 forum posts 1360 photos | If you don’t mind my mentioning this, Robin That hole appears to be ‘wrong’ in more than one way Aside from the position, it appears to be oval Are they all similar, and similarly orientated, or has each been ‘dragged’ differently ? … How did you decide which ‘centres’ to measure ? . . MichaelG. |
Robin | 12/10/2022 23:33:38 |
![]() 678 forum posts | The holes are round. Viewed from below there is a strange slot next to each mounting hole, possibly a mould opening fix which displaced it. I think I may have to make up some kind of counterbore to make way for a reduced bolt head. I have been playing with burrs in my Dremel but I am not very good at the arty farty, freehand stuff |
Michael Gilligan | 12/10/2022 23:43:37 |
![]() 23121 forum posts 1360 photos | Posted by Robin on 12/10/2022 23:33:38:
. Then count me “astonished’ by what I see in your photo … I only had a small glass of Talisker MichaelG. |
Peter Greene | 13/10/2022 01:13:53 |
865 forum posts 12 photos | Posted by Michael Gilligan on 12/10/2022 23:43:37:
Then count me “astonished’ by what I see in your photo Me too - it certainly looks like it's been "drawn" |
Hopper | 13/10/2022 01:20:06 |
![]() 7881 forum posts 397 photos | A 5mm hole is not meant for a 5mm bolt. It's a clearance hole. As Martin said above, 3mm screws with washers and nuts would do the job just fine in such a light-duty application. Or the electrician's favourite: zip ties. There used to be BS standards and the like specifying the amount of clearance around bolt holes to allow for the hexagons plus spanners, but obviously a thing of the past. |
Michael Gilligan | 13/10/2022 08:39:30 |
![]() 23121 forum posts 1360 photos | Posted by Hopper on 13/10/2022 01:20:06:
… As Martin said above, 3mm screws with washers and nuts would do … . Many a true word, said in jest MichaelG. |
Bazyle | 13/10/2022 09:25:13 |
![]() 6956 forum posts 229 photos | So it is a design or manufacture flaw, but if we are going to moan about small errors why is this thread called 'draw angle' when that is not the issue? |
Ian P | 13/10/2022 09:45:50 |
![]() 2747 forum posts 123 photos | Posted by Bazyle on 13/10/2022 09:25:13:
So it is a design or manufacture flaw, but if we are going to moan about small errors why is this thread called 'draw angle' when that is not the issue? +1 Very true Ian P |
Robin | 13/10/2022 09:52:33 |
![]() 678 forum posts | Posted by Bazyle on 13/10/2022 09:25:13:
So it is a design or manufacture flaw, but if we are going to moan about small errors why is this thread called 'draw angle' when that is not the issue? Hi It is called draft angles because I thought that was the problem in the mould before I spotted the rectangular cut-out next to the 5mm bolt hole. Looks like a puller to me Ever since I discovered zero backlash screws, DRO readouts and amazingly cheap precision measuring tools I have delighted in drilling holes exactly where holes need to be. When I see 5mm holes like these I drill for 5mm bolts and it is wonderful when it all goes together like it never did before. This is what makes it fun for me |
John Doe 2 | 13/10/2022 10:11:54 |
![]() 441 forum posts 29 photos | A hole too close for the bolt head: a school-boy error, which we all make from time to time ! Use a side cutting tool bit* and 'slot' the holes diagonally out towards the corners, keeping the width of the slot the same as the diameter you require, but thus allowing room for the bolt head and a washer.
(@MG: The picture of the bolt hole might look oval, but that is almost certainly owing to the distortion caused by the wide angle lens of the camera and the angle the shot was taken from.)
*I don't know the correct term. Edited By John Doe 2 on 13/10/2022 10:14:43 |
Martin Kyte | 13/10/2022 10:27:02 |
![]() 3445 forum posts 62 photos | Posted by Ian P on 12/10/2022 21:33:51:
I think its a bit unfair to blame the Chinese for this! The HuanYang inverters are a low cost commodity item and not perfect although the hole location is a bit of a howler. I can see also that if you have carefully prepared tapped holes than getting any standard M5 fixing is going to be a bit challenging. Judging from the picture I would say that if you reduced a slotted or Pozi head to 5.60mm diameter it would do the job. I have an expensive set of British made cast iron, machined all over (apart from the slots/holes) angle plates. A large proportion of the slots lengths are unusable because of the fillet between the internal faces. I cannot get to take a picture just now but have grabbed this picture off Google images that shows exactly (Well its 45 degree fillet on my plates but you get the idea). I see the same sort of out of proportion features, like massively wide slots on many pieces of workshop tooling and workholding items like lathe faceplates and machine vises. Ian P Why would you use a fixing that would fill the slot? Smaller diameter bolts not only don’t wedge but allow for some sideways adjustment when setting up, turning up some hefty thick washers is the name of the game. regards Martin |
Mike Poole | 13/10/2022 11:53:10 |
![]() 3676 forum posts 82 photos |
Mike |
