Babbitt metal
Dougie Swan05/09/2022 17:14:24
269 forum posts
73 photos
Hi
I am considering making the bearings for my latest engine from babbit
I am thinking of casting two half round and soldering them together for machining
My question is can I solder babbitt or is the melting point too close to the solder melting point
Thanks in advance
Dougie
Michael Gilligan05/09/2022 17:44:17
23121 forum posts
1360 photos
Now there’s a question, Dougie
The answer is … it will depend which one !!
No, I am not trying to be funny
Wikipedia will explain: **LINK**
https://en.wikipedia.org/wiki/Babbitt_(alloy)
Dougie Swan05/09/2022 18:00:54
269 forum posts
73 photos
Well that was eye opening
Thanks Michael
Speedy Builder505/09/2022 18:11:24
2878 forum posts
248 photos
Can you hold the two halves of the bearing together with the bearing bolts and then machine them?
duncan webster05/09/2022 18:54:17
5307 forum posts
83 photos
Super Glue?
old mart05/09/2022 19:13:54
4655 forum posts
304 photos
Another way would be to make two bearings, bore them and cut them in two with a hacksaw offset from the centre and then filing or milling the bigger one of each back to the centreline.
Jeff Dayman05/09/2022 19:29:46
2356 forum posts
47 photos
Suggest a mechanical jig to hold the bits for machining, rather than soldering. Better yet forget the babbitt and go with SAE 660 bronze bushings, or cast iron bushings.
bernard towers05/09/2022 20:59:57
1221 forum posts
161 photos
Plus one for superglue I have used it and it works well (keep cool).
Henry Brown06/09/2022 11:21:06
618 forum posts
122 photos
In my experience Babbit or white metal is usually backed by steel or something rigid as it is very soft. The Co. I used to work for made them in all sizes from about 25mm to 600mm diameter, both split halves and unsplit, all for use in their gearboxes.
Martin Johnson 106/09/2022 12:32:20
320 forum posts
Do you already have some babbitt or whitemetal? If not expect eye watering prices. I purchased some a few years ago to make a steering nut.
Martin
Dougie Swan06/09/2022 13:21:01
269 forum posts
73 photos
Thanks for the replies
I have got some babbit, that's what made me think about the bearings, but I think I will probably stick with bronze
Dougie
not done it yet06/09/2022 13:28:04
7517 forum posts
20 photos
Babbit bearings, in my experience, have been supported within a steel structure - generally cast in situ and then machined.
The supporting material can be clamped, glued, soldered? (carefully). Perhaps I’ve only come across larger bearings of this type, but that is generally the way it is done. Shimmed bearing halves so that they can be scraped, and shims removed, to adjust the bearings for fit/wear.
OuBallie06/09/2022 14:03:12
1181 forum posts
669 photos
Something of interest are my Austin Seven two bearing conrods with cast in place bearing material.
Crank bearings are 1.3/8” diameter.
1935 Austin Seven Ruby ARQ
Considering age of car these are in nigh on perfect condition, other than the oil retaining ‘pits’.
No idea what has caused thise.
Geoff - Feeling somewhat human again
Edited By OuBallie on 06/09/2022 14:05:45
not done it yet06/09/2022 20:00:33
7517 forum posts
20 photos
I have four rods, for a 2 3/4” crank, needing to be re-metalled. Doubt I will ever get round to it as I have a good set of mains and rods. Unless needed, the 20kg of white metal can remain as two cast cylindrical lumps of metal.
When I had to rebuild my 73 year-old tractor, about 35 years ago, all I had to do was remove shims from between the con-rod and end-cap. Max crankshaft speed was only 1125rpm and it had only been worked hard for about 15 years on a 150 acre farm.
Martin Kyte06/09/2022 20:35:19
3445 forum posts
62 photos
Posted by OuBallie on 06/09/2022 14:03:12:
Nice to hear you feeling better.
regards Martin
