fizzy | 10/07/2022 21:14:28 |
![]() 1860 forum posts 121 photos | In the photo there are two plug sockets, one 12v abd one 249v. I dont have a cable for either of them - put them safe somewhere! Is there a generic name for these plugs which would enable me to purchase new ones? Rhe 240v looks just like what we used to use on our casette player back in the dark ages. Thanks. I make steam boilers for a living and this will keep my drinks cool in the workshop so definately on topic! |
Alain Foote | 10/07/2022 21:20:09 |
69 forum posts 10 photos | I may have a spare 240V one in the workshop, will look tomorrow. Alain |
Peter Cook 6 | 10/07/2022 21:31:26 |
462 forum posts 113 photos | The 240v one is a "figure of eight" otherwise known as an IEC C7. |
peak4 | 10/07/2022 21:53:36 |
![]() 2207 forum posts 210 photos | In which photo? |
martin haysom | 10/07/2022 22:27:28 |
![]() 165 forum posts | i can't see the photo |
Pete Rimmer | 10/07/2022 22:37:06 |
1486 forum posts 105 photos |
Figure 8 240v socket. Need a straight-on pic of the 12vdc socket to ID it properly. |
Steambuff | 10/07/2022 23:07:34 |
![]() 544 forum posts 8 photos | If that is a Camping Gaz Cool box, I got a spare 12v one from Amazon. https://www.amazon.co.uk/gp/product/B00AES021K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Not Cheap!!!! |
peak4 | 10/07/2022 23:34:53 |
![]() 2207 forum posts 210 photos | If you do a search for 12v Cool Box Lead on eBay, you will find a variety of suppliers, both UK and further afield.
fizzy | 10/07/2022 23:43:19 |
![]() 1860 forum posts 121 photos | thanks - the 240v is a c7 - will investigate the 12v one as this is most used by mr
fizzy | 10/07/2022 23:44:32 |
![]() 1860 forum posts 121 photos | omg - the amazon one look correct but what an insane rip-off
fizzy | 10/07/2022 23:45:26 |
![]() 1860 forum posts 121 photos | £4.89 on ebay !!
Bazyle | 10/07/2022 23:48:38 |
![]() 6956 forum posts 229 photos | Note that the fig8 lead has a little nick out of it between the pins as a polarising key. Some leads don't have this. Of course for AC it doesn't matter so you can modify to fit. |
John Hinkley | 11/07/2022 07:35:46 |
![]() 1545 forum posts 484 photos | Hi, fizzy, Just had a look in my odds and sods drawer and came across a redundant SKY box mains lead. It has the 240v plug you're looking for. If you want it, PM me with your address and I'll pop it in the post. John
Alain Foote | 11/07/2022 07:38:02 |
69 forum posts 10 photos | Sorry fizzy, but couldn’t find a spare in the workshop. Looks like you are sorted now anyway. |
noel shelley | 11/07/2022 09:47:19 |
2308 forum posts 33 photos | Memory tells me there are two types of this plug, one has cutouts on each side, the other has flat sides. The flat sided one will NOT fit in the socket that needs the cutouts ! Noel. |
John Hinkley | 11/07/2022 10:13:45 |
![]() 1545 forum posts 484 photos | If you enlarge the photo of the panel posted by Pete Rimmer, above, that shows that this is the Marilyn Monroe shape. I've assumed fizzy's (socket) is the same. John P.S. The flat-sided one is the shape of the 12V input. Edit: added P.S. Edited By John Hinkley on 11/07/2022 10:14:57 |
Oldiron | 11/07/2022 10:59:23 |
1193 forum posts 59 photos | When I lost my 12v lead to my cooler box I used a spare fig8 plug temporarily. I just touched the sides on the belt sander till it slid in the recess & marked one side so I knew which way round to plug it in. I used it a couple of times ok until the errant lead showed up from its hiding place. regards |
Bazyle | 11/07/2022 11:34:42 |
![]() 6956 forum posts 229 photos | Be mindful that these things are about 40W so are not meant to be run off 12v when the car engine is not running although Fizzy isn't (I assume) running a mobile workshop. |
Nicholas Farr | 11/07/2022 14:37:44 |
![]() 3988 forum posts 1799 photos | Hi, I think these types of socket are common, below is of one called Wanderer and manufactured by Laurina. The AC lead won't go in the 12V DC one, unless you do what oldiron did with his lead. Regards Nick. |
fizzy | 11/07/2022 17:03:25 |
![]() 1860 forum posts 121 photos | Thanks all. I found an old lapop plug lead which has sorted the 240v side. The 12v is as others have suggested, one flat side and the other with a nick in it . Ive ordered one off tbay so fingers crossed! |
