colin hamilton | 31/05/2022 20:10:48 |
186 forum posts 94 photos | So I'm looking to make a rotisserie smoker. Not like a hog roast where the spit is passed through the animal but more like a carrousel where 4 trays rotate round. Basically a smaller version of the attached photo. It will be used at relatively low temp (max approx 180). As with all my builds its about recycling so I'm looking for 'good enough' engineering and the opportunity to make bits. So far it's a barrel for the cooking part and a cut down gas bottle for the fire box. I'm considering the main bearing options. I've got some spare bearings so was thinking of making some housed bearings which I would bolt onto the outside of the barrel but I'm a bit worried about the temp. Would bushes fair better? If yes would aluminium do (I already have some). The main shaft us going to be 19mm pipe and it will be rotating at about 3 rpm.
HOWARDT | 31/05/2022 20:15:41 |
1081 forum posts 39 photos | Ball bearings have a maximum operating temperature usually around 60deg C, and any grease content will run out. Plain bearings would do, even steel on steel with slow running, probably more than adequate for the purpose. |
AdrianR | 31/05/2022 20:35:19 |
613 forum posts 39 photos | You could always use a dry lube like Graphite or Molybdenum Disulphide on plain bearings |
SillyOldDuffer | 31/05/2022 20:36:25 |
10668 forum posts 2415 photos | Posted by HOWARDT on 31/05/2022 20:15:41:
Ball bearings have a maximum operating temperature usually around 60deg C,...
I hope that's not universally true - my car engine block runs hotter than that! But I agree about plain bearings. Apart from the temperature, the bearings in a garden rotisserie have a slow lazy life. Sounds ideal for a steel shaft running in self lubricating cast iron. However, I'd be tempted to try Aluminium for cheapness if the design allowed them to be easily replaced if they seized or wore badly. Smearing the journals with Graphite would provide enough lube. Dave |
old mart | 31/05/2022 20:36:43 |
4655 forum posts 304 photos | Plain bearings would be best, and if you are concerned with temperature, you can get a tube of ceramic bearing grease which will be more than adequate, and plenty left over for other jobs. |
John P | 31/05/2022 20:41:02 |
451 forum posts 268 photos | Aliexpress sell full ceramic bearings for somewhere around £4 each depending on size some will work up to 800 C only at low rpm (200) there are hundreds of them , type in " ball bearings high temperature" to scan through,not able to put reference on here as it will be taken down. John |
Martin Kyte | 31/05/2022 21:25:31 |
![]() 3445 forum posts 62 photos | Whats wrong with a between centres arrangement. Easy to dismantle. regards Martin |
bernard towers | 31/05/2022 21:29:19 |
1221 forum posts 161 photos | Lubricate with chicken fat!! |
Nigel Graham 2 | 31/05/2022 22:14:43 |
3293 forum posts 112 photos | Oh, this doesn't need anything too fancy especially if the shaft's bearing surface is just the raw pipe surface, but remember to lubricate the bearings well with grease before storing the rotisserie, as well as prior to use. Especially with aluminium bushes. |
mgnbuk | 31/05/2022 22:35:53 |
1394 forum posts 103 photos | Graphite bushes, run dry Nigel B. |
Hopper | 31/05/2022 23:15:59 |
![]() 7881 forum posts 397 photos | 3 rpm? Steel on steel should be fine. |
Paul Lousick | 01/06/2022 02:01:25 |
2276 forum posts 801 photos | A BBQ is always covered with fat/grease after cooking. So self lubricating. Steel on steel bearings will probably outlast other parts of the grill. |
colin hamilton | 01/06/2022 06:18:25 |
186 forum posts 94 photos | Brilliant thanks for the responses. Looks like I have plenty of options. |
not done it yet | 01/06/2022 09:43:49 |
7517 forum posts 20 photos | Do you have a suitable motor for this project? 10HP would easily cope. Possibly just a little smaller? Motor speed might be important? 2 or 4 pole motor? Two pole at 2800rpm might be the best? Three phase with VFD or a brushless DC might be best for wide speed variation choices? Add to this lot the huge fan required, to supply the combustion air, and you are nearly home. Automatic. ash pan, grate clearing, etc might be a high priority? Might also need a chain saw to cut down the oak trees for the smoking chips. Saw can be electric, of course - better for the environment than using fossil fuels. I think bearings are likely fairly low on your list of priorities.🙂
colin hamilton | 05/06/2022 11:38:35 |
186 forum posts 94 photos | ![]() Do you have a suitable motor for this project? 10HP would easily cope. Possibly just a little smaller? Motor speed might be important? 2 or 4 pole motor? Two pole at 2800rpm might be the best? Three phase with VFD or a brushless DC might be best for wide speed variation choices? Add to this lot the huge fan required, to supply the combustion air, and you are nearly home. Automatic. ash pan, grate clearing, etc might be a high priority? Might also need a chain saw to cut down the oak trees for the smoking chips. Saw can be electric, of course - better for the environment than using fossil fuels. I think bearings are likely fairly low on your list of priorities.🙂
Yep the things you mention I already have got covered off from when I built my hog roast machine. I'm really interested in improving the bearing set up hence my question but thanks for your input |
