Paul L | 03/04/2022 09:08:58 |
![]() 87 forum posts 26 photos | A friend of mine is a Band Leader and has snapped his conductor's baton. He has asked if i can repair it as it was a gift from his good Lady. As you can see in the photo the break is not clean. my idea is to cut it clean and insert a metal rod (its hollow) and bond it back together. Does anyone have any experience or suggestions as to how to get a clean cut through Carbon Fibre? Thanks in advance
Paul L | 03/04/2022 09:11:08 |
![]() 87 forum posts 26 photos | |
Clive Hartland | 03/04/2022 09:18:14 |
![]() 2929 forum posts 41 photos | I would suggest to grind it flat, use an aluminium tube inset and araldite it in place. |
Paul L | 03/04/2022 09:34:54 |
![]() 87 forum posts 26 photos | Thank you Clive, i hadn't considered grinding it.
David-Clark 1 | 03/04/2022 09:35:51 |
![]() 271 forum posts 5 photos | Horrible stuff to machine. Splinters and burrs are common. I would probably araldite a piece of metal in each end, Then face back to clean up while in a collet. Face right up to the collet face. Then drill and tap both parts and glue some threaded rod to pull it all together. Maybe glue a polished brass band over the join to hide it? |
Michael Gilligan | 03/04/2022 09:38:47 |
![]() 23121 forum posts 1360 photos | I agree with Clive … but might use more carbon fibre tube to keep the weight down …. would also note that you would be wise to check how far the cracks extend. From what I can see of the photo, the baton is more likely to be a ‘pultrusion’ than a ‘filament wound’ tube. MichaelG. |
John Haine | 03/04/2022 09:39:30 |
5563 forum posts 322 photos | I hold the tube in a collet in the lathe and use a pointed tool at low speed to nick through far enough to get a clean break. Square off with fine abrasive paper. Araldite + ali tube or rod to reinforce will be fine. Need the metal to be a nice fit in the CF tube. My 7kg clock bob has been hanging off an 8mm aluminium slug araldited into 10mm OD 8mm IS CF tube for over 3 years with no sign of coming adrift. Gluing in a slug also holds any longitudinal cracks together. Edited By John Haine on 03/04/2022 09:41:02 |
Ady1 | 03/04/2022 10:00:51 |
![]() 6137 forum posts 893 photos | Would heat work to seal the ends and then rub them flat? you would need a metal insert in the hole My jobs with fishing rod and umbrella carbon fibre have always been a bit of a nightmare Edited By Ady1 on 03/04/2022 10:02:40 |
Clive Brown 1 | 03/04/2022 10:07:36 |
1050 forum posts 56 photos | How much strength is required? I think that any type of internally reinforced butt joint will be quite weak as the fibres are discontinuous and will not carry bending stresses. An angled splice joint might be better but difficult to make unobtrusively. |
JasonB | 03/04/2022 10:07:55 |
![]() 25215 forum posts 3105 photos 1 articles | Diamond coated disc in a Dremel works well |
Paul L | 03/04/2022 10:16:09 |
![]() 87 forum posts 26 photos | Thanks for the suggestions. The baton is tapered and is 3.8mm at the break point. Normally the only stress it encounters is being wafted through thin air! I'm going to try the Dremel idea of Jason's, then ally welding rod and araldite. I may post the result later if its not too shameful. |
Ady1 | 03/04/2022 10:17:19 |
![]() 6137 forum posts 893 photos | Check out a couple of fishing rod repair sites? "fixing a carbon fibre rod tip" could yield decent returns |
SillyOldDuffer | 03/04/2022 10:18:54 |
10668 forum posts 2415 photos | Never tried to repair Carbon Fibre so I'm short of ideas. I think it's too difficult. Carbon fibre rod is made of extremely thin carbon fibres embedded in a brittle resin matrix. Rod is very strong along the fibres, much less sideways. This picture is of the suspension of my experimental clock pendulum, where I removed a section of matrix so the pendulum only swung on the flexible fibres, independent of the resin. The example is 0.8mm diameter, but the construction is the same in bigger diameters. Appearance depends on the matrix, which should be easy enough to recreate. Unfortunately, the strength of the rod depends on the fibres, which can't be reconnected. The best I can think of is like Clive's answer, except I'd use a steel rod rather than Aluminium tube. (Carbon fibre is stronger than steel!) I found cutting thin rod no problem with a wire-cutter or rolling a sharp Box Knife over it, but it gets harder to do it neatly as the rod diameter increases. Radio Control types recommend rolling the rod on a wet cloth with a razor blade. The problem is the brittle matrix tends to crack and chip, causing nearby fibres to stick out in an untidy fuzz. A Dremel cutting disc might do a better job: I've not tried it! My feeling is the item can be made to look good again, but the repair won't be strong enough to allow the baton to be waved about. How about the dead Hamster fix? When the child's favourite pet dies, take the corpse to a pet shop secretly and replace it with a near match. If all else fails, tell the friend to substitute a new one without telling his wife! Dave
Journeyman | 03/04/2022 10:52:48 |
![]() 1257 forum posts 264 photos | Many older batons, especially those for presentations, were made with a silver join which could be engraved. If the repair isn't as tidy as you would like a thin tube of suitable material could be fashioned to cover the join, could even be silver and engraved, very thin so no real weight. John |
Jon Lawes | 03/04/2022 11:31:14 |
![]() 1078 forum posts | How on earth did he snap it! I wonder if the cleaner solution would be to get another piece of carbon fibre and replace the shaft complete? Rods are easily found, used in everything from Model RC Aircrft and and Fishing rods as metioned before. |
pgk pgk | 03/04/2022 13:42:24 |
2661 forum posts 294 photos | Trim the broken ends and bond into a pair of threaded gizmos for the ultimate in collapsible batons or as suggested fishing rod joiners. If sleeving the break it may be worth looking at arrow shafting if there is suitable size. Pgk |
