Simon Robinson 4 | 16/03/2022 16:22:48 | |
102 forum posts | I have a 6 ft by 4 ft wooden tool shed with apex roof which gets very damp in winter. I’ve re-sealed the roof but there’s always dampness inside the shed despite being placed on a concrete patio on sleepers with reasonable space around it. Should the vents be on both ends of the shed just under the apex point or should there also be vents low down as well? Any other ideas? | |
DutchDan | 16/03/2022 16:26:08 | |
![]() 49 forum posts 16 photos | Advise I've read suggests placing one vent high and one low, the moist air is heavier and should exit from the lower vents. Not sure how much of a difference it'll make, but probably cheap enough to be worth a shot. | |
Baz | 16/03/2022 16:34:07 | |
1033 forum posts 2 photos | If it were me I would invest in a decent dehumidifier, dessicant one for preference and one that has a continuous drain facility. | |
Bazyle | 16/03/2022 18:04:12 | |
![]() 6956 forum posts 229 photos | Surprise ! the UK is damp in winter (and most of summer). If you make holes in a shed it will be damp. Best thing is to seal it up and just open the door after very frosty nights when the air will be dry and really hot days in summer. You especially don't want to open the door on a day when it has changed from cold to feeling warm because a wet warm front has moved over the country. | |
Dave Halford | 16/03/2022 18:41:57 | |
2536 forum posts 24 photos | What did you 'seal' the roof with? It should have been heavy duty felt, the expensive stuff. 6x4 sheds tend to be made cheap with the thin felt and thin walls made from fencing panel timber. Without gutters rain will run off the roof hit the patio and bounce up wetting the walls. | |
Ady1 | 16/03/2022 19:20:10 | |
![]() 6137 forum posts 893 photos | Posted by DutchDan on 16/03/2022 16:26:08:
Advise I've read suggests placing one vent high and one low, the moist air is heavier and should exit from the lower vents. Not sure how much of a difference it'll make, but probably cheap enough to be worth a shot. Works for prairie dogs, so their burrows get ventilated eek! eek! | |
John Haine | 16/03/2022 20:31:51 | |
5563 forum posts 322 photos | A condensing dehumidifier would be good. Moist air is not heavier.
David George 1 | 17/03/2022 08:13:38 | |
![]() 2110 forum posts 565 photos | I have a dessicant dehumidifier in my garage and it works great and provides a bit of background heat as well. David | |
Jon Lawes | 17/03/2022 08:33:52 | |
![]() 1078 forum posts | I use a condensing dehumidifier which actually warms and defrosts itself if it gets too chilly. This is quite useful for providing water for steaming as well.
Howard Lewis | 18/03/2022 08:47:19 | |
7227 forum posts 21 photos | Firstly, when the felt on the roof eventually failed, I replaced it with rubber. (Mine has a flat roof, faliing from 8' at the to to 7'6" at the back, over 6'9" ) It is 10' 9" long external, so not too big. The materials, and trims came from Rubber for Roofs. I gave the dimensions and the site calculates the material needed Order placed in the afternoon, everything, (Rubber sheet, adhesive, trims, ring shank nails, arrived 0800 next morning ). make sure that you position the nails correctly before hammering them in. They do not come out easily! INSULATE! Line the inner walls, but put glassfibre or mineral wool insulation between the inner and outer skins. If you can, insulate the roof in similar fashion. My shop has no windows, and inner lining to walls and roof is 12 mm ply, on 50 mm framing, with glassfibre between. On the back wall,there are two small fixed vents close to floor level, and a fixed vent near to roof level. This has an external hood to prevent any rain ingress, when the small, rarely used, intake fan is running. The moist air will exit at floor level and fresh, hopefully, drier, air enter through the high level vent. SECURITY The door is a fire door, with a 6 lever lock. I wanted a 5 lever, but the door came with the 6 lever. The weight necessitated a 100 mm wall for the door end. I made hinge bolts by turning the heads off three fairly hefty woodscrewss. they were screwed into place by using a drill chuck, until only about 18 mm protruded. Partially closing the door marked the post to show where to drill the holes. So, the lock will be difficult to pick, and the hinge bolts will prevent the door being lifted out if the hinge pins have been driven out. HTH Howard | |
James Alford | 18/03/2022 09:21:24 | |
501 forum posts 88 photos | I have a 17' by 19' wooden garage which is used as a workshop. Whether it is luck or not, I do not know, but it gets no damp or condensation. The walls and doors have foil-backed bubble-wrap insulation stapled over them with flake board on top. The roof is unlined. There is a modest amount of ventilation under the eaves and around the doors which are a "comfortable" fit. There are also a couple of holes drilled in the apex. The wooden floor is up off the ground, standing on beams. I put a sheet of plastic damp proof membrane over it and covered this with hardboard and those cheap inter-locking rubber mats. Originally, I also lined the roof with polystyrene covered with hardboard. This was a major cause of damp and was soon removed. It is not the warmest place on Earth, but it is dry and damp free. Regards, James. Edited By James Alford on 18/03/2022 09:21:43 Edited By James Alford on 18/03/2022 09:22:19 Edited By James Alford on 18/03/2022 09:22:43 | |
Jon Lawes | 18/03/2022 12:00:03 | |
![]() 1078 forum posts | I think it's crucial to have free flow of air through that gap. Maybe that is what you've achieved. | |
James Alford | 19/03/2022 09:03:11 | |
501 forum posts 88 photos | Posted by Jon Lawes on 18/03/2022 12:00:03:
I think it's crucial to have free flow of air through that gap. Maybe that is what you've achieved. I think that you are right. I do have a small computer fan over the vent holes in the apex, intended for use if I a using any noxious materials in there, but I have yet to turn it on, as much as anything else because the whole building acts like a resonating box and it is surprisingly loud. James. | |
Neil Wyatt | 19/03/2022 10:15:09 | |
![]() 19226 forum posts 749 photos 86 articles | Interesting to read how damp air actually rises. The condensation problem on my metal roof was terrible, even with a dehumidifier. I used the metallic bubble film. It has a reputation for not being hugely effective compared to other insulation, but I wanted something that wouldn't lose me headroom and could go between beams and the roof as much as possible. It's been really effective, I used a version with self-adhesive strips on it, but ended up using a roll and a half of double-sided tape as well for about 20m^2. I'm hoping it will help keep things cool in summer as well. Neil | |
Peter Cook 6 | 19/03/2022 14:16:53 | |
462 forum posts 113 photos | My little 6 x 4 shed (used to store the mower, shredder and other potentially useful junk) used to get damp. I installed a couple of passive vents, one low at the back, one High at the front and a cheap solar powered vent in the door. That has kept it dry ever since. | |
Simon Robinson 4 | 19/03/2022 15:00:31 | |
102 forum posts | Posted by Peter Cook 6 on 19/03/2022 14:16:53:
My little 6 x 4 shed (used to store the mower, shredder and other potentially useful junk) used to get damp. I installed a couple of passive vents, one low at the back, one High at the front and a cheap solar powered vent in the door. That has kept it dry ever since. What sized vents did you use? | |
Simon Robinson 4 | 19/03/2022 15:04:48 | |
102 forum posts | Posted by Neil Wyatt on 19/03/2022 10:15:09:
Interesting to read how damp air actually rises. The condensation problem on my metal roof was terrible, even with a dehumidifier. I used the metallic bubble film. It has a reputation for not being hugely effective compared to other insulation, but I wanted something that wouldn't lose me headroom and could go between beams and the roof as much as possible. It's been really effective, I used a version with self-adhesive strips on it, but ended up using a roll and a half of double-sided tape as well for about 20m^2. I'm hoping it will help keep things cool in summer as well. Neil Never though about it but car roofs must get a lot of condensation between the upholstery and metal roof. I’m not sure how they prevent condensation in vehicles otherwise the ceiling would soaking wet most of the time.
Simon Robinson 4 | 19/03/2022 15:08:41 | |
102 forum posts | Posted by James Alford on 18/03/2022 09:21:24:
I have a 17' by 19' wooden garage which is used as a workshop. Whether it is luck or not, I do not know, but it gets no damp or condensation. The walls and doors have foil-backed bubble-wrap insulation stapled over them with flake board on top. The roof is unlined. There is a modest amount of ventilation under the eaves and around the doors which are a "comfortable" fit. There are also a couple of holes drilled in the apex. The wooden floor is up off the ground, standing on beams. I put a sheet of plastic damp proof membrane over it and covered this with hardboard and those cheap inter-locking rubber mats. Originally, I also lined the roof with polystyrene covered with hardboard. This was a major cause of damp and was soon removed. It is not the warmest place on Earth, but it is dry and damp free. Regards, James. Edited By James Alford on 18/03/2022 09:21:43 Edited By James Alford on 18/03/2022 09:22:19 Edited By James Alford on 18/03/2022 09:22:43 I wonder if my mistake was painting the inside walls in white emulsion? It’s stops the wood from breathing and probably increases condensation as dampness can’t soak into the wood and evaporate through to the outside due to the paint. Both inside and outside are painted. | |
Simon Robinson 4 | 19/03/2022 15:12:46 | |
102 forum posts | Posted by Dave Halford on 16/03/2022 18:41:57:
What did you 'seal' the roof with? It should have been heavy duty felt, the expensive stuff. 6x4 sheds tend to be made cheap with the thin felt and thin walls made from fencing panel timber. Without gutters rain will run off the roof hit the patio and bounce up wetting the walls. It’s tongue and groove panels but the felt is thin and poor and nailed on which I’ve had to paint tar over. I think my big mistake was painting the inside of the shed in white emulsion because the moisture can’t absorb into the wood and evaporate to the outside due to the paint layer and so it just condenses. The outside is also painted but with Cuprinol. | |
Roger Best | 19/03/2022 15:31:04 | |
![]() 406 forum posts 56 photos | Maybe, vents will help, small 6" ones will make all the difference. Condensation will form on any cold metal object, cold being relative to the relative humidity. So you won't remove the problem entirely but if you wrap up your equipment it will help a lot. Best option is the proper insulation with dehumidifier. A little heat will improve that "relatively cold" parameter. Good luck. |
