petro1head | 02/02/2022 09:08:11 |
![]() 984 forum posts 207 photos | I have a Clarke 6" band sawthat I use for cutting metal Last night the blade James and burned the motor out So I need a new motor however I would like to prevent this happening g again. Any suggestion what I could do? And before you say it, yes don't leave it running on its own |
noel shelley | 02/02/2022 10:42:20 |
2308 forum posts 33 photos | You need a Direct Online Starter, rated to suit the full load amps as stated on the data plate ! Good ones are not cheap. On getting one it has to be set to the current rating for the motor. Fla = 2.8A You need a 2-4A unit set to 2.8A. A fuse WILL NOT help in this application. If buying secondhand check that the coil voltage is 240V not 415V. Good Luck Noel. |
petro1head | 02/02/2022 16:04:41 |
![]() 984 forum posts 207 photos | I have just had a quote for a replacement motor from Clarke £200!!!! This seems rediculously high |
Mike Poole | 02/02/2022 16:38:51 |
![]() 3676 forum posts 82 photos | Motors do broadly follow various standards, the motor plate will often have the frame size as one of the parameters and this will define the mountings and shaft size and height. TEC have built a reputation for decent quality and a reasonable price, WEG are also a contender for an attractive price and quality. Google will find suppliers of both. Mike |
Adrian R2 | 02/02/2022 16:48:03 |
196 forum posts 5 photos | Machine Mart sell Clarke motors - which one do you need? https://www.machinemart.co.uk/categories/?search=motor
petro1head | 02/02/2022 16:58:04 |
![]() 984 forum posts 207 photos | Not much info on the motor plate |
Adrian R2 | 02/02/2022 17:24:10 |
196 forum posts 5 photos | The summary for the 3/4HP (550W) 2 pole from MM says frame size 71 and 14mm shaft. Here endeth my knowledge on the subject!
petro1head | 02/02/2022 17:29:38 |
![]() 984 forum posts 207 photos | Cheers However the shaft dia is 16mm |
Mike Poole | 02/02/2022 18:12:22 |
![]() 3676 forum posts 82 photos | A 16mm shaft is a bit of an odd size, shafts are often 11mm,14mm then 19mm, double check that the shaft is not 5/8” which is 15.875mm. As the frame size is not on the plate then it would be useful to measure the bolt centres for the feet and the height of the shaft Centre from the foot mounting surface. There are plenty of drawings of motor dimensions to be found online and you may be looking at a motor around £100 Mike |
noel shelley | 02/02/2022 18:41:58 |
2308 forum posts 33 photos | Before you get to shaft size check the motor speed 1450 rpm or 2850 ! The first is a 4 pole motor the second is a 2 pole ! I could not read the RPM on the data plate, nor the current. Why not look for a second hand unit ? an adaptor could easily be made if the mountings are different. If you buy a new motor the guarentee will be void if you do not use a DOL starter or some form of over current protection. Be warrned ! Noel. |
petro1head | 02/02/2022 18:43:39 |
![]() 984 forum posts 207 photos | Motor speed is 1450 shaft size 15.9mm |
john fletcher 1 | 02/02/2022 18:50:49 |
893 forum posts | I have an "Alpine" saw to which I fitted with a DOL starter maybe 30/35 years ago and it appears to be a similar machine under a different name. I have just checked my saw and the motor is 4 pole capacitor start 1425 rpm half HP.. So, I think almost any !/2 HP cap start motor can be fitted, maybe a bit of work is required with mounting bolt holes and shaft diameter. I would look out for a second hand motor for £20 or £30 and fit a DOL. Before buying second hand, run the motor and check the direction of rotation, most are easily altered but some not. John |
J Hancock | 02/02/2022 19:06:17 |
869 forum posts | I would go for at least a 1hp motor , better that the belt slips than risk another burn out. |
petro1head | 02/02/2022 19:07:02 |
![]() 984 forum posts 207 photos | The motor is 1hp |
Samsaranda | 02/02/2022 19:53:15 |
![]() 1688 forum posts 16 photos | The motor in the photo is labelled as 500 watts, that equates to .75 hp not 1 hp. Dave W |
noel shelley | 02/02/2022 20:10:29 |
2308 forum posts 33 photos | Confusion between Ph 1 and Hp ? Noel. |
petro1head | 02/02/2022 20:44:08 |
![]() 984 forum posts 207 photos | Posted by Samsaranda on 02/02/2022 19:53:15:
The motor in the photo is labelled as 500 watts, that equates to .75 hp not 1 hp. Dave W What equation did you use? |
Pete Rimmer | 02/02/2022 21:17:33 |
1486 forum posts 105 photos | HP = KW x 1.341 so a 500w motor is equivalent to about 0.67hp |
petro1head | 03/02/2022 11:10:45 |
![]() 984 forum posts 207 photos | I think the confusion is its says pH 1. which is phase not hp. my pal has the same saw and his is 350w |
not done it yet | 03/02/2022 11:43:50 |
7517 forum posts 20 photos | I expect this is likely an imperial motor. Actually 15.87mm? 5/8”? How mm might spec their motors is debatable and possibly misleading. That 500W may be gross consumption, not real horse power delivered. That may make it only 1/2HP (or even less!). Ignore the temptation to fit a more powerful motor. That is not a sensible option. Something else would break or the motor would still burn out if/when a jam occurs. Running improperly tensioned belts is just plain ridiculous. Fitting an overload cut-out is the way to go. A fuse that would blow with a stall would likely blow when starting the motor. Follow the sensible suggestions, particularly that of the proper electricians. The post by Noel was all that you required. Follow that advice. Edited By not done it yet on 03/02/2022 11:53:00 |
